    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 501.9k Views
      mediamogul Global Moderator
      Glad to see things working out here. I'll add the information about --device-name to the guide .
        spud11 @mediamogul
        @mediamogul That's a good idea.
        I'm still having a bit of trouble as per 3 posts ago. Hoping you might still be able to help, if possible, please.
          mediamogul Global Moderator @spud11
          @spud11
          Have those particular virtual controllers been mapped through Emulation Station like any other controller? If not, it could be that there's no automatic configuration for them at /opt/retropie/configs/all/retroarch/autoconfig for RetroArch to draw on.
            spud11 @mediamogul
            @mediamogul Hi. Yes, they are in fact both mapped:
            Player_3_-_4-Way_Joystick_xboxdrv.cfg
            input_driver = "udev"
            input_device = "Player_3_-_4-Way_Joystick_xboxdrv"
            input_b_btn = "1"
            input_y_btn = "3"
            input_select_btn = "8"
            input_start_btn = "9"
            input_up_axis = "+0"
            input_down_axis = "-0"
            input_left_axis = "+1"
            input_right_axis = "-1"
            input_a_btn = "0"
            input_x_btn = "2"
            Player_4_-_4-Way_Joystick_xboxdrv.cfg
            input_device = "Player_4_-_4-Way_Joystick_xboxdrv"
            input_b_btn = "1"
            input_y_btn = "3"
            input_a_btn = "0"
            input_x_btn = "2"
            And thinking about it, I'll need to map the corresponding 8 way configs to Users 7 and 8 in Retroarch too, given that all other roms will rely on those 8 way configs. Personally, I'd just prefer for the xpad (rather than xboxdrv) driver to work for normal 8 way mame-libretro joystick games, but when I added the hash to the below, xboxdrv wouldn't load at all:
            			*) # Configuration for every other ROMs on this emulator
            				$xboxkill
            				# joycommand="$basic $joy3unrestricted & $basic $joy4unrestricted &"
            				# eval $joycommand
            I've also tried to edit, without success, the individual amidar.zip.cfg file which is as follows by adding the extra line at the top:
            input_player3_joypad_index = 5
            video_allow_rotate = "true"
            video_rotation = "3"
            aspect_ratio_index = "19"
            video_aspect_ratio_auto = "false"
            video_aspect_ratio = "1.75"
              @spud11
              You may just want to map those final two controllers for keyboard input. I have most of my controllers mapped like that anyway. RetroArch will still respect all the controller button mappings, but have a separate set for keyboard keys as well. An example of one and two player keyboard controls from my own retroarch.cfg is:
              input_player1_a = "a"
              input_player1_b = "b"
              input_player1_y = "y"
              input_player1_x = "x"
              input_player1_start = "t"
              input_player1_select = "e"
              input_player1_l = "l"
              input_player1_r = "r"
              input_player1_left = "left"
              input_player1_right = "right"
              input_player1_up = "up"
              input_player1_down = "down"
              input_player1_l2 = "d"
              input_player1_r2 = "f"
              input_player1_l3 = "c"
              input_player1_r3 = "v"
              input_player2_a = "k"
              input_player2_b = "m"
              input_player2_y = "o"
              input_player2_x = "n"
              input_player2_start = "num9"
              input_player2_select = "num0"
              input_player2_l = "p"
              input_player2_r = "q"
              input_player2_left = "g"
              input_player2_right = "h"
              input_player2_up = "i"
              input_player2_down = "j"
              input_player2_l2 = "s"
              input_player2_r2 = "u"
              input_player2_l3 = "w"
              input_player2_r3 = "z"
                dunnieboy
                So far I am mainly using this for dosbox to capture the mouse. Are there reason to use this as the main controller rather than the xpad default mapping ?
                The systems I am suing are :
                DosBOX
                Vice (C64)
                Amiberry (amiga)
                Daphne (Dragon's Lair)
                Mame 2003
                I am currently initiating the xboxdrv in the .sh of each game for DosBOX.
                  spud11 @mediamogul
                  @mediamogul Hi. I had my input references slightly wrong ( input_player1_joypad_index = 4 ). I'm assuming the 4 corresponds to User 5's input in Retroarch (which in my case is now mapped to Player_3_-4-Way_Joystick_xboxdrv) and 5 corresponds to User 6's input in Retroarch (mapped to Player_4-_4-Way_Joystick_xboxdrv). So I have amended the input indexes below to reflect that.
                  Adapting your code, to change the settings for Amidar only at the moment, I would just change amidar.zip.cfg as follows:
                  input_player2_joypad_index = 5
                  After that, I would just remap the buttons in game with the TAB menu?
                  Thanks.
                    @spud11 said in Guide: Advanced Controller Mappings:
                    After that, RetroArch just assumes the keyboard presses are coming from it's own "Retropad" controller as the proper button presses, so it'll work without any further remapping.
                      spud11 @mediamogul
                      @mediamogul Thanks, mediamogul. Will try later in the day and let you know how I go.
                        spud11 @mediamogul
                        @mediamogul Hi. I've now tried the approach of mapping the keys, but no luck. Nothing works automatically.
                        The joypad index numbers are correct - 4 and 5 - reflect the 2 4-way xboxdrv scripts.
                        I also inserted the same values (as above) in the main retroarch.cfg file. They worked in the Retroarch menu in emulationstation, as the "x" and "y" keys had become "a" and "b", as per the script.
                        I'm clearly missing something along the line somewhere, but just not sure what. Now that I've mapped the keys in Retroarch, should I also be changing the xboxdrv scripts in some way too?
                          @spud11
                          You'll need to make sure the intended controllers are mapped to the corresponding keyboard keys that match your new RetroArch entries.
                            spud11 @mediamogul
                            @mediamogul Hi. Thanks for your patience.
                            If that means going into the Retroarch menu, going to user 5 (being the 1st of the 4-way joysticks) and mapping those keys to that joystick's buttons, I did that, but unfortunately it had no result either.
                            I've also tried the non-libretro advmame emulator. As an experiment, in the runcommand-onstart.sh, I switched from "mame-libretro" to "mame-advmame", mapped the joystick buttons using the TAB menu in game which did work, but once I exited the game and re-started it again, the joysticks were assigned new js numbers which weren't the same as before and so the controls were messed up.
                            I'm already using the joystick-selection tool which maps the 4 DragonRise xpad drivers to Players 1-4, so they don't change each time. The result is that I can't "fix" the xboxdrv joysticks to players 1 to 4.
                            Just trying to think of alternatives. What if, in the advmame TAB menu, I changed the keys to UP, DOWN etc to keyboard controls, then in the runcommand_onstart.sh, remapped the joystick buttons to the keyboard inputs?
                              @spud11 said in
                              That's the first part of it. Then you need to use xboxdrv to map those controllers to send out the corresponding keyboard keys when each button is pressed.
                              That's the same idea as the method above, but it would be limited to only working in Advance MAME.
                                spud11 @mediamogul
                                @mediamogul Hi mediamogul.
                                I'll try using Advmame rather than Retroarch to begin with, so will map advmame to the keys using the TAB menu.
                                I'm not near my Pi at the moment, but I was just wondering if you could please look at the syntax to see if anything stands out as being obviously wrong please as I haven't used the ui settings in this way before:
                                --silent \
                                --detach-kernel-driver \
                                --deadzone=4000 \
                                --deadzone-trigger 15% \
                                --force-feedback \
                                --mimic-xpad \
                                --trigger-as-button \
                                --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void \
                                --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick \
                                --device-name "Player_3_-_4-Way_Joystick_xboxdrv" \
                                --evdev-absmap ABS_X=x1,ABS_Y=y1 \
                                --four-way-restrictor \
                                --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start \
                                --ui-axismap X1=KEY_LEFT:KEY_RIGHT,Y1=KEY_UP:KEY_DOWN \
                                --ui-buttonmap a=KEY_A,b=KEY_B,x=KEY_X,y=KEY_Y,back=KEY_E,start=KEY_T \
                                The last 2 lines are the added lines. I'm assuming that I still need the --evdev-absmap line to map the axes, but that the --ui-axismap is sort of superimposed on top of it, so that the axes are mapped to the up, down, left, right keys on the keyboard.
                                Thanks.
                                  @spud11
                                  Everything looks good.
                                  That's correct.
                                  • H
                                    Hubz
                                    Is there any place where we're keeping mappings for systems and various controllers? I've got a Wii U Pro Controller I've been setting all mine up as and would be happy to share. I just spent a few hours figuring out mapping it for VICE which was a pain in the ass and I'd like to share to save someone else the trouble :P
                                    mediamogulM ExarKunIvE 2 Replies Last reply Reply Quote 0
                                      mediamogul Global Moderator @Hubz
                                      @Hubz
                                      It's not a bad idea, but there are so many physical button variations in all the controllers out there and so many personal preferences as to how the end result should be that any collection would really only serve as a list of examples to start from. I've always encouraged people to post their finished examples here, but I'll be the first to admit that it's far from organized.
                                      • ExarKunIvE
                                        ExarKunIv @Hubz
                                        @Hubz
                                        i second your thought.
                                        i have a 8bitdo NES30 pro
                                        and i would love you share my mappings too help people
                                        • H
                                          Hubz @ExarKunIv
                                          Here's my xboxdrv config for the Wii U Pro Controller -
                                          basicWiiUPro="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv
                                          --evdev /dev/input/event0
                                          --silent
                                          --force-feedback
                                          --deadzone 4000
                                          --device-name "WiiUProXboxDrv1"
                                          --calibration x1=-32767:0:32767,y1=-32767:0:32767,x2=-32767:0:32767,y2=-32767:0:32767
                                          --trigger-as-button
                                          --mimic-xpad
                                          --dpad-as-button
                                          --evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_RX=x2,ABS_RY=y2
                                          --evdev-keymap BTN_EAST=a,BTN_SOUTH=b,BTN_NORTH=x,BTN_WEST=y,BTN_TL=lb,BTN_TR=rb,BTN_THUMBL=tl,BTN_THUMBR=tr,BTN_SELECT=back,BTN_START=start,BTN_DPAD_UP=du,BTN_DPAD_DOWN=dd,BTN_DPAD_LEFT=dl,BTN_DPAD_RIGHT=dr,BTN_TL2=lt,BTN_TR2=rt"
                                          • H
                                            Hubz @Hubz
                                            I prefer using Y and B instead of B and A on my controllers so these are mapped for that. At least these could be used as a starting point for others.
                                            scummVM="--axismap -Y1=Y1,-Y2=Y2
                                            --ui-axismap x1=REL_X:10,y1=REL_Y:10
                                            --ui-buttonmap b=BTN_LEFT,y=BTN_RIGHT,back=KEY_LEFTCTRL+KEY_Q,start=KEY_F5
                                            --ui-buttonmap guide=void,x=KEY_ENTER,a=KEY_1,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void,back=void
                                            --ui-axismap x2=void"
                                            amstradcpc="--axismap -Y1=Y1,-Y2=Y2
                                            --ui-buttonmap a=KEY_UNKNOWN,b=KEY_UNKNOWN,start=KEY_1,back=KEY_2,x=KEY_UNKNOWN,y=KEY_SPACE,lt=KEY_UNKNOWN,rt=KEY_UNKNOWN,lb=KEY_UNKNOWN,rb=KEY_UNKNOWN,tl=KEY_UNKNOWN,tr=KEY_UNKNOWN
                                            --ui-axismap x2=KEY_1:KEY_2,Y2=KEY_3:KEY_4"
                                            amiga="--axismap -Y1=Y1,-Y2=Y2
                                            --ui-axismap x2=REL_X:10,y2=REL_Y:10
                                            --ui-axismap x1=KEY_LEFT:KEY_RIGHT,y1=KEY_DOWN:KEY_UP
                                            --ui-buttonmap du=KEY_UP,dd=KEY_DOWN,dl=KEY_LEFT,dr=KEY_RIGHT
                                            --ui-buttonmap lt=BTN_LEFT,rt=BTN_RIGHT,start=KEY_F12,back=KEY_F11,y=KEY_SPACE,a=KEY_LEFTCTRL,b=KEY_LEFTALT,x=KEY_LEFTSHIFT
                                            --ui-buttonmap guide=void,tl=void,tr=void
                                            c64="--ui-axismap x2=void
                                            --ui-buttonmap lt=KEY_C,rt=void,start+back=KEY_Q,start=KEY_F12,back=KEY_ESC,y=KEY_V,a=KEY_BACK,b=KEY_ENTER,x=KEY_W
                                            --ui-buttonmap lb=KEY_Z,rb=KEY_X,guide=void,tl=KEY_C,tr=void"
                                            apple2="--ui-buttonmap du=KEY_UP,dd=KEY_DOWN,dl=KEY_LEFT,dr=KEY_RIGHT
                                            --ui-buttonmap lt=KEY_Y,rt=KEY_N,lb=KEY_F3,rb=KEY_ESC,start=KEY_1,back=KEY_2,y=void,a=KEY_ENTER,b=void,x=KEY_SPACE
                                            intellivision="--ui-axismap X1=KEY_S:KEY_D,Y1=KEY_X:KEY_E,X2=KEY_1:KEY_2,Y2=KEY_3:KEY_4,lt+X2=KEY_5:KEY_6,lt+Y2=KEY_7:KEY_8,rt+X2=KEY_9:KEY_0,rt+Y2=KEY_MINUS:KEY_EQUAL
                                            --ui-buttonmap a=KEY_LEFTSHIFT,b=KEY_HOME,x=KEY_LEFTCTRL,y=KEY_LEFTALT,lb=KEY_F1,rb=KEY_F12,lt=KEY_HOME,rt=KEY_HOME,tl=KEY_HOME,tr=KEY_HOME,du=KEY_E,dd=KEY_X,dl=KEY_S,dr=KEY_D,start=KEY_KPENTER
                                            --ui-buttonmap back=cycle-key:KEY_F6:KEY_F5
                                            --ui-buttonmap guide=void"
                                            atari800="--buttonmap tl^toggle=tl
                                            --buttonmap tr^toggle=tr
                                            --ui-axismap X1=KEY_KP4:KEY_KP6,Y1=KEY_KP5:KEY_KP8
                                            --ui-axismap X2=KEY_1:KEY_2,Y2=KEY_3:KEY_4,lt+X2=KEY_5:KEY_6,lt+Y2=KEY_7:KEY_8,rt+X2=KEY_9:KEY_0,rt+Y2=KEY_KPASTERISK:KEY_EQUAL
                                            --ui-buttonmap y=KEY_RIGHTCTRL,b=KEY_F2,x=KEY_EQUAL,a=KEY_KPASTERISK,lb=KEY_F9,rb=KEY_F5,du=KEY_KP8,dd=KEY_KP5,dl=KEY_KP4,dr=KEY_KP6,start=KEY_F4,back=KEY_F3,lt=KEY_HOME,rt=KEY_HOME,tl=KEY_HOME,tr=KEY_HOME
                                            --ui-buttonmap lt+a=KEY_ENTER,lt+b=KEY_ESC,lt+du=KEY_UP,lt+dd=KEY_DOWN,lt+dl=KEY_LEFT,lt+dr=KEY_RIGHT,lt+start=KEY_F1
                                            --ui-axismap lt+X1=KEY_LEFT:KEY_RIGHT,lt+Y1=KEY_UP:KEY_DOWN
                                            --ui-axismap tl+x1=REL_X:10,tl+y1=REL_Y:10
                                            --ui-buttonmap tr+b=BTN_LEFT,tr+a=BTN_RIGHT
                                            atari5200="--buttonmap tl^toggle=tl
                                            videopac="--axismap -Y1=Y1,-Y2=Y2
                                            --ui-buttonmap a=KEY_UNKNOWN,b=KEY_UNKNOWN,start=KEY_1,back=KEY_2,x=KEY_UNKNOWN,y=KEY_UNKNOWN,lt=KEY_UNKNOWN,rt=KEY_UNKNOWN,lb=KEY_UNKNOWN,rb=KEY_UNKNOWN,tl=KEY_UNKNOWN,tr=KEY_UNKNOWN
