    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 508.1k Views
    • ExarKunIvE
      ExarKunIv @daanv98
      @daanv98
       /dev/input/js2
       /dev/input/event5
      means that the mapping it working
      your error is something with the game and/or it working with xboxdrv
      sadly i dont have any dosgames on my system. i messed it up while messing with compiling other ports. so i cant help much.
      and i have gotten away from using that mapping style.
      # DOS configuration of Abuse for 8bitDo
      # This configuration file is for use with Abuse, a DOS game.
      [xboxdrv]
      silent = true
      detach-kernel-driver = true
      deadzone-trigger = 15%
      deadzone = 4000
      mimic-xpad = true
      dpad-as-button = true
      trigger-as-button = true
      [evdev-absmap]
      ABS_X=x1
      ABS_Y=y1
      ABS_Z=x2
      ABS_RZ=y2
      ABS_HAT0X=dpad_x
      ABS_HAT0Y=dpad_y
      [evdev-keymap]
      BTN_SOUTH=a
      BTN_EAST=b
      BTN_NORTH=x
      BTN_WEST=y
      BTN_TL=lb
      BTN_TL2=lt
      BTN_TR=rb
      BTN_TR2=rt
      BTN_SELECT=back
      BTN_START=start
      BTN_THUMBL=tl
      BTN_THUMBR=tr
      [calibration]
      x1 = -32767:0:32767
      y1 = -32767:0:32767
      x2 = -32767:0:32767
      y2 = 32767:0:-32767
      [ui-axismap]
      x1=KEY_LEFT:KEY_RIGHT
      y1=KEY_DOWN:KEY_UP
      x2=REL_X:13
      y2=REL_Y:13
      [ui-buttonmap]
      rt=BTN_LEFT
      b=BTN_RIGHT
      x=KEY_ENTER
      back=KEY_F5
      start=KEY_ESC
      lt=KEY_LEFTCTRL
      # EC #
      • ExarKunIvE
        ExarKunIv
        this way just seemed easyer for me and it was easy to get it to launch with the games
        #!/bin/bash
        sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv >> /dev/shm/runcommand.log 2>&1 --evdev /dev/input/event0 --config /opt/retropie/configs/all//xdrive/abuse.cfg &
        "/opt/retropie/supplementary/runcommand/runcommand.sh" 0 _PORT_ "abuse" ""
          daanv98 @ExarKunIv
          @ExarKunIv I finally got it to work!! First i tried this in the command line:
          sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv \--evdev /dev/input/event4 \--silent \--detach-kernel-driver \--force-feedback \--mimic-xpad \--dpad-as-button \--deadzone 4000 \--trigger-as-button \--evdev-no-grab \--device-name "Player Red" \--evdev-absmap ABS_X=x1,ABS_Y=y1 \--evdev-keymap BTN_TOP=a,BTN_PINKIE=b,BTN_THUMB2=x,BTN_TOP2=y,BTN_TRIGGER=lt,BTN_THUMB=rt,BTN_BASE4=start,BTN_BASE3=back \--ui-axismap x1=REL_X:-3,y1=REL_Y:3 \--ui-buttonmap rt=BTN_LEFT,lt=BTN_RIGHT,start=KEY_ENTER,back=KEY_ESC,a=KEY_SEMICOLON,b=KEY_APOSTROPHE,x=KEY_LEFTBRACE,y=KEY_RIGHTBRACE \--ui-buttonmap guide=void \
          Notice that there are no spaces between \ and --. This worked right away!
          Then I started looking at the runcommand-onstart file. I noticed that the first line referred to 'dosbox'. I changed it to 'pc'. And it works now! My file now looks like this:
          if [ "$1" = "pc" ]
          then
          sudo killall >> /dev/shm/runcommand.log 2>&1 xboxdrv
          sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv >> /dev/shm/runcommand.log 2>&1 \
            --silent \
            --force-feedback \
            --mimic-xpad \
            --dpad-as-button \
            --deadzone 4000 \
            --evdev-no-grab \
            --ui-axismap x1=REL_X:-07,y1=REL_Y:07 \
          fi
          Huge thanks for your time! I appreciate it.
          • ExarKunIvE
            ExarKunIv @daanv98
            @daanv98 glad you got it working, happy i could help out
              jaamulberry
              Is there an updated link as the github link ends up at a dead page?
              • ExarKunIvE
                ExarKunIv @jaamulberry
                @jaamulberry here it was moved to the main Docs page
