    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 516.6k Views
    • RionR
      Rion @mediamogul
      @mediamogul said in Guide: Advanced Controller Mappings:
      @Rion said in Guide: Advanced Controller Mappings:
      So what am i doing wrong?
      It looks like everything is right on your end. It's very helpful to see that your command launches directly from the command line without error. That should mean that it's also launching from rc.local and is just being ignored. I've never had that happen, but it could be that the original controller event is taking precedent and when you go to map in ES it reads the original event first. This isn't supposed to happen because xboxdrv is designed to render the original event inert to avoid these types of situations. It could be that it's unable to do this because of something unique to the NES30 setup.
      Try deleting the original NES30 mapping from es_input.cfg, reboot and see if it can then read the xboxdrv virtual event. Just make sure you have something else mapped to control ES as a backup if it doesn't work. If it does work and the original NES30 event is conflicting, that conflict will of course still show up in other software as well.
      Well i tested what you said. Did the hole thing using a clean install.
      Still same problem. The only GamePad Emulationstation recognizes is NES 30 PRO and this is even without adding the Gamepad to /etc/udev/rules.d/99-bluetooth.rules by just paring the gamepad in RetroPie Setup using bluetooth - Configure Bluetooth Devices
      When i drop down to command line and write this after reboot there is no Virtual X360 Gamepad registered
      cat /proc/bus/input/devices
      I: Bus=0003 Vendor=0603 Product=00f2 Version=0110
      N: Name="NOVATEK USB Keyboard"
      P: Phys=usb-3f980000.usb-1.4/input0
      S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:0603:00F2.0001/input/input0
      U: Uniq=
      H: Handlers=sysrq kbd leds event0
      B: PROP=0
      B: EV=120013
      B: KEY=10000 7 ff9f207a c14057ff febeffdf ffefffff ffffffff fffffffe
      B: MSC=10
      B: LED=1f
      P: Phys=usb-3f980000.usb-1.4/input1
      S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:0603:00F2.0002/input/input1
      U: Uniq=
      H: Handlers=kbd event1
      B: PROP=0
      B: EV=13
      B: KEY=7fff8000 0 2000000 3878 d801d001 1e0000 0 0 0
      B: MSC=10
      I: Bus=0005 Vendor=3820 Product=0009 Version=0100
      N: Name="8Bitdo NES30 Pro"
      P: Phys=b8:27:eb:5b:f5:53
      S: Sysfs=/devices/platform/soc/3f201000.uart/tty/ttyAMA0/hci0/hci0:11/0005:3820:0009.0003/input/input2
      U: Uniq=e4:17:d8:db:66:6b
      H: Handlers=event2 js0
      B: PROP=0
      B: EV=1b
      B: KEY=ffff0000 0 0 0 0 0 0 0 0 0
      B: ABS=30627
      B: MSC=10
      But if i map it again without rebooting its there.
      U: Uniq=
      B: PROP=0
      B: EV=120013
      B: MSC=10
      B: LED=1f
      U: Uniq=
      B: PROP=0
      B: EV=13
      B: MSC=10
      B: PROP=0
      B: EV=1b
      B: ABS=30627
      B: MSC=10
      I: Bus=0000 Vendor=0000 Product=0000 Version=0000
      N: Name="NES30 PRO Advanced Controller Configuration"
      P: Phys=
      S: Sysfs=/devices/virtual/input/input7
      U: Uniq=
      H: Handlers=event3 js1
      B: PROP=0
      B: EV=20000b
      B: KEY=7fdb0000 0 0 0 0 0 0 0 0 0
      B: ABS=3001b
      B: FF=1 3f870000 0 0
      Then i start emulationstation again. Then its there but there are now not one but two gamepads detected. But Emulation station only responds to NES30 PRO Advanced Controller Configuration so that one good thing.
      So why is this happening? Why are the commands a put in to /etc/rc.local ignored?
      Is it because the Gamepad have not connect via Bluetooth yet? Cause it usually takes a while before that happens.
      Just right when Emulationstation loads up.
      But i have tried all the options in Configure Bluetooth Devices->Configure bluetooth connect mode from default, boot & background.
      Please help.. Me...
      When i check the log in /var/log/boot.log there is an error that it cant find "/dev/input/event2"
      -- [ ERROR ] ------------------------------------------------------
      /dev/input/event2: No such file or directory
      /etc/rc.local: 27: /etc/rc.local: --device-name: not found
      xboxdrv 0.8.8 - http://pingus.seul.org/~grumbel/xboxdrv/
      Copyright © 2008-2011 Ingo Ruhnke <grumbel@gmail.com>
      Licensed under GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
      This program comes with ABSOLUTELY NO WARRANTY.
      This is free software, and you are welcome to redistribute it under certain
      conditions; see the file COPYING for details.
      [  OK  ] Started usbmount@dev-sda1.service.
      Edit: @Floob Do you think you can have a look at this? I know you have a lot more experience with the 8bit do Gamepads then most of us.
      FBNeo rom filtering
      Mame2003 Arcade Bezels
      Fba Arcade Bezels
      Fba NeoGeo Bezels
        mediamogul Global Moderator @Rion
        I'm not sure, but that is a very good suspect and would make sense. Earlier in this thread, this was also brought up as a possibility. I suggested forcing the controller to load by adding a command to do so before the xboxdrv command in rc.local. Adding a sleep command of a few seconds between the two probably wouldn't hurt either. I don't own a Bluetooth controller, so I've never had to attempt this, but after looking at back at that discussion, the following command might work:
        rfcomm bind 0 XX:XX:XX:XX:XX:XX 1
        substituting your controller's Blutooth address for "XX:XX:XX:XX:XX:XX" of course.
        • RionR
          Rion @mediamogul
          Did not work but a sleep 5 before helped sort of... But it completely hangs in the terminal window.
          Your Xbox/Xbox360 controller should now be available as:
            /dev/input/js1
            /dev/input/event3
          Press Ctrl-C to quit, use '--silent' to suppress the event output
          X1:     0 Y1:     0  X2:     0 Y2:     0  du:0 dd:0 dl:0 dr:0  back:0 guide:0 start:0  TL:0 TR:0  A:0 B:0 X:0 Y:0  LB:0 RB:0  LT:  0 RT:  0
          So it reacts to my button presses but wont respond to Ctrl-C on my Keyboard that is attached. Is should just continue and start emulationstation but for some reason it wont.
          My /etc/rc.local look like this. The silent command is there... strange...
          #!/bin/sh -e
          # rc.local
          # This script is executed at the end of each multiuser runlevel.
          # Make sure that the script will "exit 0" on success or any other
          # value on error.
          # In order to enable or disable this script just change the execution
          # bits.
          # By default this script does nothing.
          # Print the IP address
          _IP=$(hostname -I) || true
          if [ "$_IP" ]; then
            printf "My IP address is %s\n" "$_IP"
          fi
          sleep 5
          	--evdev /dev/input/event2
          	--silent \
          	--detach-kernel-driver \
          	--force-feedback \
          	--deadzone-trigger 15% \
          	--deadzone 4000 \
          	--trigger-as-button \
          	--device-name "NES30 PRO Advanced Controller Configuration" \
          	--evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RZ=y2,ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
          	--evdev-keymap BTN_SOUTH=a,BTN_EAST=b,BTN_NORTH=x,BTN_WEST=y,KEY_#312=lt,KEY_#313=rt,BTN_TL=lb,BTN_TR=rb,BTN_THUMBL=tl,BTN_THUMBR=tr,BTN_SELECT=back,BTN_START=start \
          	--ui-buttonmap guide=void \
          exit 0
          FBNeo rom filtering
          Fba Arcade Bezels
          Fba NeoGeo Bezels
            @Rion
            That is most strange. As an experiment, you might try putting your xboxdrv command right before emulationstation is called in /opt/retropie/configs/all/autostart.sh rather than /etc/rc.local, as I believe it loads at a later time. That might give the controller the time it needs to pair.
            • RionR
              Rion @mediamogul
              @mediamogul
              Removed the commands from /etc/rc.local and instead added like you suggested to autostart.sh
              And the same thing happens again when i do that.... This is starting to get a bit frustrating...
              Edit:
              I think i found something here on the official Raspberry forums. A man named teeth_03 seams like he hade the same problem and solved it but i cant figure out how he did it even tough he describes it.
              My Bin/Bash Kung-Fu is not as strong as i hoped.
              It's like learning a parrot to talk. Its just repeats what you said and don't know why lol
              FBNeo rom filtering
              Fba Arcade Bezels
              Fba NeoGeo Bezels
                @Rion
                I just have noticed that your xboxdrv config has a small error.
                The line...
                should be:
                	--evdev /dev/input/event2 \
                I don't know if that was the source of your problem, but it would have caused the command to end at that point before any mapping occurs.
                As far as the thread you posted, teeth_03 mentions that he didn't use the autostart.sh script, but one that launches Emulation Station. As I understand it, autostart.sh is the script that launches ES in Retropie. My only guess is that he's alluding to a script of his own creation or one that is used in some other distribution.
                • RionR
                  Rion @mediamogul
                  @mediamogul
                  Sorry about the missing "/" is just a type error. I forgot to add it when i posted. Its there in rc local.
                  Maby i just have to give up on a system-wide mapping for now and go with Key-Mapping For Individual Emulators instead.
                  I wanted to have a system wide configuration for the versability and for emulators like vice for c64.
                  But even if i can't get a system-wide mapping working on boot i can still configure the controller for Key-Mapping For Individual Emulators? Or am i mistaken?
                  FBNeo rom filtering
                  Fba Arcade Bezels
                  Fba NeoGeo Bezels
                    It shouldn't be a problem. I hate that the system-wide config isn't working out for you. I might pick up one of the 8Bitdo models in the near future to test with. They seem like a nice wireless option to have around.
                    RionR 1 Reply Last reply Reply Quote 1
                    • RionR
                      Rion @mediamogul
                      @mediamogul
                      They are of great build quality. The SFC30/SNES30 models is as close to the real controller you can buy.
                      Thank you for all your help. I will revisit this at a later time. I will probably bugg you some more when i start mapping the individual emulators that don't have full gamepad support. 😊
                      FBNeo rom filtering
                      Fba Arcade Bezels
                      Fba NeoGeo Bezels
                        Not a problem. I'm sure we'll have better luck after the controller has fully paired.
                        • W
                          weirdocollector
                          Hi again!
                          I've finally tried to use what I learned from this thread (and another one about mapping the Atari800 emulator buttons) and the wiki to my Retropie installation, but it does not seem to work.
                          I've created the following /opt/retropie/configs/all/runcommand-onstart.sh file
                          #!/bin/sh
                          ## Uncomment one or all of the following if you need to find some information about the emulator or roms
                          ## Name of the emulator
                          #echo $1 >> /dev/shm/runcommand.log
                          ## Name of the software used for running the emulation
                          #echo $2 >> /dev/shm/runcommand.log
                          ## Name of the rom
                          #echo $3 >> /dev/shm/runcommand.log
                          ##Executed command line
                          #echo $4 >> /dev/shm/runcommand.log
                          ### The FUN begins
                          #Get ROM name striping full path
                          rom="${3##*/}"
                          ### Set variables for your joypad and emulator
                          ### Basic Configurations - Standard controller mappings
                          XboxOne="/opt/retropie/supplementary/xboxdrv/bin/xboxdrv \
                              --evdev /dev/input/by-id/usb-Microsoft_Controller_7EED8E7D89A9-event-joystick \
                              --silent \
                              --force-feedback \
                              --deadzone 4000 \
                              --mimic-xpad \
                              --evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_RX=x2,ABS_RY=y2,ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
                              --evdev-keymap ABS_HAT0X-=du,ABS_HAT0X+=dd,ABS_HAT0Y-=dl,ABS_HAT0Y+=dr \
                              --evdev-keymap BTN_SOUTH=a,BTN_EAST=b,BTN_NORTH=x,BTN_WEST=y,BTN_TL=lb,BTN_TR=rb,BTN_TL2=lt,BTN_TR2=rt,BTN_THUMBL=tl,BTN_THUMBR=tr,BTN_MODE=guide,BTN_SELECT=back,BTN_START=start \
                          ### Extended Configurations
                          ### Specific emulator configuration or any other parameters you will need only for some emulators
                          atari800="--axismap -Y1=Y1,-Y2=Y2 \
                          	--dpad-as-button \
                          	--ui-axismap X1=KEY_KP4:KEY_KP6,Y1=KEY_KP8:KEY_KP5 \
                          	--ui-axismap X2=KEY_1:KEY_2,Y2=KEY_3:KEY_4,lt+X2=KEY_5:KEY_6,lt+Y2=KEY_7:KEY_8,rt+X2=KEY_9:KEY_0,rt+Y2=KEY_KPASTERISK:KEY_EQUAL \
                          	--ui-buttonmap a=KEY_RIGHTCTRL,b=KEY_F2,x=KEY_EQUAL,y=KEY_KPASTERISK,lb=KEY_F9,rb=KEY_F5,du=KEY_KP8,dd=KEY_KP5,dl=KEY_KP4,dr=KEY_KP6,start=KEY_F4,back=KEY_F3,lt=KEY_HOME,rt=KEY_HOME,tl=KEY_HOME,tr=KEY_HOME \
                          	--ui-buttonmap lt+a=KEY_ENTER,lt+b=KEY_ESC,lt+du=KEY_UP,lt+dd=KEY_DOWN,lt+dl=KEY_LEFT,lt+dr=KEY_RIGHT,lt+start=KEY_F1 \
                          	--ui-axismap lt+X1=KEY_LEFT:KEY_RIGHT,lt+Y1=KEY_UP:KEY_DOWN \
                          	--ui-buttonmap guide=void"
                          fourway="--four-way-restrictor"
                          invert="--ui-buttonmap du=KEY_DOWN,dd=KEY_UP"
                          ### Kill Command
                          xboxkill="sudo killall >/dev/null xboxdrv"
                          ### Execute the driver with the configuration you need
                          # $1 is the name of the emulation, not the name of the software used
                          # it is intellivision not jzintv
                          case $1 in
                          	atari800)
                                  $xboxkill
                                  joycommand="$XboxOne $atari800 &"
                                  eval $joycommand
                          esac
                          were I've tried to map my XboxOne controller to the Atari800 emulator control keys.
                          I've mapped half the dpad (that is treated as an ABS event) to the main direction keys, and I've used the mapping of the Atari800 buttons from this thread:
                          https://retropie.org.uk/forum/topic/3651/mapping-certain-keys-from-atari800-emu-to-the-gamepad/7
                          It seems all OK to me, as the same Xbox One controller configuration is succesfully used in the rc.local file, but when I start the Atari800 emulator from Emulationstation, and select a game from the list, I just get the emulator menu (the one in which you can choose the cartridge type), and I cannot move the cursor using the controller.
                          I've made the script executable, and configured xboxdrive to run at user level.
                          Could anybody point me to what I'm doing wrong ?
                          Thanks a lot !
                            MadHorse
                            Hi @weirdocollector ,
                            Hi think the problem is the & at the end of the variable XboxOne, when the command is executed in the eval $joycommand part, it will run only the Basic XboxOne configuration in the background, and will not pass the specific command for the emulator.
                            The & to run the program in background is already part of the joycommand variable, so it is also not needed.
                            Please, try to edit the command removing & from the XboxOne variable and let us know if it's working.
                            W 2 Replies Last reply Reply Quote 0
                              MadHorse
                              Hi,
                              i would like to thank @meleu for the information you gave me about the standard output redirection and about the runcommand.info, i don't know why i never tried to open it before :).
                              And thank to @mediamogul for his guide, his help, and for adding the runcommand-onstart.sh to the Universal Controller Calibration & Mapping Using xboxdrv wiki page.
                              Thank you all.
                              • W
                                weirdocollector @MadHorse
                                @MadHorse said in Guide: Advanced Controller Mappings:
                                Thanks a lot !
                                I'm now away from my RetroPie: I'll try ASAP and let you know.
                                Thanks again!
                                  mediamogul Global Moderator @MadHorse
                                  Not a problem. Please feel free to add to it with any other ideas or techniques you may have going forward.
                                  • W
                                    Hi !
                                    I've tried again after renoving the '&' at the end of the 'XboxOne' variable, but it still doesn't work.
                                    I've noticed that the first time I launch the Atari800 emulator from Emulationstation, the menu in which it is possible to choose the cartridge type appears, but it is not possible to change the time or lauch the game from this menu, even using the keyboard (up/down keys or return).
                                    If I press F5 it goes to the Atari800 start screen, and after this I can press F1, enter the main menu, and launch the game from there.
                                    Once the game has lauched, the XboxOne controller does not work in game.
                                    Any suggestion on this ?
                                    Should I have to remove the XboxOne controller configuration in the rc.local ?
                                    Thanks in advance for any help.
                                    P.S.: I'd also like to thank Mediamogul and all the nice and clever people that has made this thread a reality.
                                      MadHorse
                                      hi @weirdocollector,
                                      probably you also need to remove the \ character at the end of the last line of the XboxOne basic configuration.
                                      You don't need to remove the configuration from rc.local, we start with a sudo killall >/dev/null xboxdrv that kill any other instance of xboxdrv, but you have to remember to add the same configuration at the end of the runcommand-onend.shotherwise the controller will not work anymore when you exit from the emulator.
                                        spud11
                                        Hello
                                        I'm new to this forum and was hoping please for some help in mapping a Zero delay USB Encoder Arcade joystick for the small arcade table I've built. I'm using the latest Raspberry Pi 3 and have RetroPie 4.0.2 installed. With the ordinary Xpad driver installed with RetroPie, I've got the joystick working in Emulationstation and Retroarch and in some of the libretro cores (but not all of these seem to work) and so was hoping to use some of the emulators instead of libretro cores. I was hoping the xboxdrv driver would mean less individual mapping for the emulators.
                                        I've installed the xboxdrv driver and disabled it via RetroPie-Setup.
                                        I've read through every post of this thread, and have some familiarity with Linux but am struggling with the mappings. I've got 6 buttons - those that should correspond to A, B, X and Y plus a Start and Select button. There is only 1 joystick, but I'm not sure if I should be mapping that to analog (left stick) or to the D-Pad please on the virtual XBox controller.
                                        My apologies for the long post. I wasn't sure how to do "inline" comments (like Rion and mediamogul have done, for example).
                                        Here is the output.
                                        cat /proc/bus/input/devices:
                                        I: Bus=0003 Vendor=0079 Product=0006 Version=0110
                                        N: Name="DragonRise Inc.   Generic   USB  Joystick  "
                                        P: Phys=usb-3f980000.usb-1.2/input0
                                        S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0079:0006.0001/input/input0
                                        U: Uniq=
                                        H: Handlers=js0 event0
                                        B: PROP=0
                                        B: EV=1b
                                        B: KEY=fff 0 0 0 0 0 0 0 0 0
                                        B: ABS=3001f
                                        B: MSC=10
                                        [Note: no other devices connected at the time.]
                                        ls /dev/input/by-id/:
                                        usb-DragonRise_Inc._Generic_USB_Joystick-event-joystick
                                        usb-DragonRise_Inc._Generic_USB_Joystick-joystick
                                        evtest /dev/input/event0
                                        Input driver version is 1.0.1
                                        Input device ID: bus 0x3 vendor 0x79 product 0x6 version 0x110
                                        Input device name: "DragonRise Inc.  Generic  USB  Joystick  "
                                        Supported events:
                                          Event type 0 (EV_SYN)
                                          Event type 1 (EV_KEY)
                                            Event code 288 (BTN_TRIGGER)
                                            Event code 289 (BTN_THUMB)
                                            Event code 290 (BTN_THUMB2)
                                            Event code 291 (BTN_TOP)
                                            Event code 292 (BTN_TOP2)
                                            Event code 293 (BTN_PINKIE)
                                            Event code 294 (BTN_BASE)
                                            Event code 295 (BTN_BASE2)
                                            Event code 296 (BTN_BASE3)
                                            Event code 297 (BTN_BASE4)
                                            Event code 298 (BTN_BASE5)
                                            Event code 299 (BTN_BASE6)
                                          Event type 3 (EV_ABS)
                                            Event code 0 (ABS_X)
                                              Value    127
                                              Min        0
                                              Max      255
                                              Flat      15
                                            Event code 1 (ABS_Y)
                                              Value    127
                                              Min        0
                                              Max      255
                                              Flat      15
                                            Event code 2 (ABS_Z)
                                              Value    130
                                              Min        0
                                              Max      255
                                              Flat      15
                                            Event code 3 (ABS_RX)
                                              Value    127
                                              Min        0
                                              Max      255
                                              Flat      15
                                            Event code 4 (ABS_RY)
                                              Value    127
                                              Min        0
                                              Max      255
                                              Flat      15
                                            Event code 16 (ABS_HAT0X)
                                              Value      0
                                              Min       -1
                                              Max        1
                                            Event code 17 (ABS_HAT0Y)
                                              Value      0
                                              Min       -1
                                              Max        1
                                          Event type 4 (EV_MSC)
                                            Event code 4 (MSC_SCAN)
                                        Properties:
                                        Testing ... (interrupt to exit)
                                        I then tested the buttons and axes which produced the following:
                                        Buttons:
                                        (EV_KEY), code 288 (BTN_TRIGGER)
                                        (EV_KEY), code 289 (BTN_THUMB)
                                        (EV_KEY), code 290 (BTN_THUMB2)
                                        (EV_KEY), code 291 (BTN_TOP)
                                        (EV_KEY), code 298 (BTN_BASE5)
                                        (EV_KEY), code 295 (BTN_BASE2)
                                        I've tried to map the first 4 buttons above to A, B, X and Y, respectively, and the last 2 I've tried to map to Start and Select, respectively.
                                        Axes:
                                        (EV_ABS), code 3 (ABS_RX)
                                        (EV_ABS), code 0 (ABS_X)
                                        The ABS_RX axes correspond to the joystick moving up and down; the ABS_X axes correspond to the joystick moving left and right.
                                        ABS_Y, ABS_Z, ABS_RY, ABS_HAT0X and ABS_HAT0Y are not mapped.
                                        BTN_TOP2, BTN_PINKIE, BTN_BASE, BTN_BASE3, BTN_BASE4, BTN_BASE6 are not mapped.
                                        In the etc/rc.local file, I mapped the Virtual Xbox 360 as follows:
                                            --evdev /dev/input/by-id/usb-DragonRise_Inc._Generic_USB_Joystick-event-joystick \
                                        	--silent \
                                        	--force-feedback \
                                        	--deadzone 4000 \
                                        	--mimic-xpad \
                                        	--device-name "8-Way Arcade Joystick" \
                                        	--evdev-absmap ABS_X=x1,ABS_RX=y1 \
                                        	--evdev-keymap BTN_TRIGGER=a,BTN_THUMB=b,BTN_THUMB2=x,BTN_TOP=y,BTN_BASE2=back,BTN_BASE5=start \
                                        	--ui-axismap
                                        	--ui-buttonmap lb=void,rb=void,tl=void,tr-void,guide=void,dpad_x=void,dpad_y=void,lt=void,rt=void \
                                        The above code produced no change at all. It reboots into EmulationStation and if I try to configure the joystick I get the usual DragonRise one - no virtual XBox Driver.
                                        If I change the mapping to below, when I reboot I get the message during boot up that it has mapped to the virtual XBox controller (js1 and Event1, for example, assuming no keyboard is attached) and to press CTRL-C but unfortunately it's crashed without going any further - no error message and no Emulationstation. If I press any keys, it just produces symbols and I have to reboot again.
                                        	--silent \
                                        	--force-feedback \
                                        	--deadzone 4000 \
                                        	--mimic-xpad \
                                        	--dpad-as-button \
                                        	--dpad-only \
                                        	--ui-axismap lt=void,rt=void
                                        	--ui-buttonmap lb=void,rb=void,tl=void,tr-void,guide=void \
                                        Could I please ask for some help? Thanks.
                                          mediamogul Global Moderator @spud11
                                          @spud11 said in Guide: Advanced Controller Mappings:
                                          Welcome to the party.
                                          https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#code
                                          In most cases, mapping to the left stick is the best option.
                                          Each line except for the last should have a space and a backslash added so that it can be read as one single command, as follows:
                                          --silent \
                                          --force-feedback \
                                          --deadzone 4000 \
                                          --mimic-xpad \
                                          That might be all that is needed to get you going. Everything else looks fine.
                                            spud11 @mediamogul
                                            @mediamogul Thanks, mediamogul, for the code and the nice welcome! I'll have a go with that code once I get home, and will try the "blocks of code" with my next email too.
