    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 516.6k Views
      spud11 @mediamogul
      @mediamogul Hi. Thanks for your help. Unfortunately, the code did not work insofar as nothing changed. No errors or anything. Should I provide a log and, if so, which one please? Thanks again for your help.
        mediamogul Global Moderator @spud11
        @spud11
        There is no log to speak of. However, you can execute the command directly from a command prompt, minus the & at the end. There it should give some verbose feedback as to what is going on.
          spud11 @mediamogul
          @mediamogul Hi. Thanks for that. I ran the code in Putty. (I used "exit" rather than the "&" at the end of the code.) It produced the following error:
          --  [ ERROR ] --------------------------------------------------------------
          error: invalid argument  '--ui-buttonmap lb=void,rb-void,tl=void,tr-void,guide=void,dpad_x=void,dpad_y=void,lt=void,rt=void'
                string2btn(): couldn't convert string "tr-void" to XboxButton
          I then changed the "tr-void" to "tr=void" and it produced a similar error as above but the string2btn() line changed to the following:
          string2btn(): couldn't convert string "dpad_x" to XboxButton
            @spud11 said in Guide: Advanced Controller Mappings:
            I've never tried to void the dpad, but I do know thatdpad_x=void and dpad_y=void aren't valid entries for --ui-buttonmap. However, I believe you might be able to void them under --ui-axismap such as:
            --ui-axismap dpad_x=void,dpad_y=void
            If that doesn't work, you might try omitting them from the configuration altogether.
              spud11 @mediamogul
              @mediamogul Thanks. I'll try both options when I'm home and let you know how I go.
                spud11 @mediamogul
                @mediamogul Hi. Thanks so much. The code without the --ui-axismap did the trick. I've set it out below for anyone who has a Zero Delay Arcade Encoder. For sake of completeness, I've attached an image of the encoder too.
                --evdev /dev/input/by-id/usb-DragonRise_Inc._Generic_USB_Joystick-event-joystick \
                --silent \
                --detach-kernel-driver \
                --force-feedback \
                --deadzone-trigger 15% \
                --deadzone 4000 \
                --trigger-as-button \
                --mimic-xpad \
                --device-name "8-Way Arcade Joystick" \
                --evdev-absmap ABS_X=x1,ABS_RX=y1 \
                --evdev-keymap BTN_TRIGGER=a,BTN_THUMB=b,BTN_THUMB2=x,BTN_TOP=y,BTN_BASE2=back,BTN_BASE5=start \
                --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void \
                Again, thanks so much, mediamogul. I couldn't have done it without your help. I'm now in the process of trying to change the arcade joystick to port 0 (rather than it defaulting to the DragonRise).0_1476787083532_Joystick.PNG .
                • W
                  weirdocollector
                  Hi again.
                  I'm finally back to my RetroPie, ands I'm still struggling with the xboxdrv drive configuration, that continues to refuse to work as expected.
                  I've applied all the suggested syntax modifications to my /opt/retropie/configs/all/runcommand-onstart.sh, which is the now the following:
                  #!/bin/sh
                  ## Uncomment one or all of the following if you need to find some information about the emulator or roms
                  ## Name of the emulator
                  echo $1 >> /dev/shm/runcommand.log
                  ## Name of the software used for running the emulation
                  echo $2 >> /dev/shm/runcommand.log
                  ## Name of the rom
                  #echo $3 >> /dev/shm/runcommand.log
                  ##Executed command line
                  echo $4 >> /dev/shm/runcommand.log
                  ### The FUN begins
                  #Get ROM name striping full path
                  rom="${3##*/}"
                  ### Set variables for your joypad and emulator
                  ### Basic Configurations - Standard controller mappings
                  XboxOne="/opt/retropie/supplementary/xboxdrv/bin/xboxdrv \
                      --evdev /dev/input/by-id/usb-Microsoft_Controller_7EED8E7D89A9-event-joystick \
                      --silent \
                      --force-feedback \
                      --deadzone 4000 \
                      --mimic-xpad \
                      --evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_RX=x2,ABS_RY=y2,ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
                      --evdev-keymap ABS_HAT0X-=du,ABS_HAT0X+=dd,ABS_HAT0Y-=dl,ABS_HAT0Y+=dr \
                      --evdev-keymap BTN_SOUTH=a,BTN_EAST=b,BTN_NORTH=x,BTN_WEST=y,BTN_TL=lb,BTN_TR=rb,BTN_TL2=lt,BTN_TR2=rt,BTN_THUMBL=tl,BTN_THUMBR=tr,BTN_MODE=guide,BTN_SELECT=back,BTN_START=start"
                  ### Extended Configurations
                  ### Specific emulator configuration or any other parameters you will need only for some emulators
                  atari800="--axismap -Y1=Y1,-Y2=Y2 \
                  	--dpad-as-button \
                  	--ui-axismap X1=KEY_KP4:KEY_KP6,Y1=KEY_KP8:KEY_KP5 \
                  	--ui-axismap X2=KEY_1:KEY_2,Y2=KEY_3:KEY_4,lt+X2=KEY_5:KEY_6,lt+Y2=KEY_7:KEY_8,rt+X2=KEY_9:KEY_0,rt+Y2=KEY_KPASTERISK:KEY_EQUAL \
                  	--ui-buttonmap a=KEY_RIGHTCTRL,b=KEY_F2,x=KEY_EQUAL,y=KEY_KPASTERISK,lb=KEY_F9,rb=KEY_F5,du=KEY_KP8,dd=KEY_KP5,dl=KEY_KP4,dr=KEY_KP6,start=KEY_F4,back=KEY_F3,lt=KEY_HOME,rt=KEY_HOME,tl=KEY_HOME,tr=KEY_HOME \
                  	--ui-buttonmap lt+a=KEY_ENTER,lt+b=KEY_ESC,lt+du=KEY_UP,lt+dd=KEY_DOWN,lt+dl=KEY_LEFT,lt+dr=KEY_RIGHT,lt+start=KEY_F1 \
                  	--ui-axismap lt+X1=KEY_LEFT:KEY_RIGHT,lt+Y1=KEY_UP:KEY_DOWN \
                  	--ui-buttonmap guide=void"
                  fourway="--four-way-restrictor"
                  invert="--ui-buttonmap du=KEY_DOWN,dd=KEY_UP"
                  ### Kill Command
                  xboxkill="sudo killall >/dev/null xboxdrv"
                  ### Execute the driver with the configuration you need
                  # $1 is the name of the emulation, not the name of the software used
                  # it is intellivision not jzintv
                  case $1 in
                  	atari800)
                          $xboxkill
                          joycommand="$XboxOne $atari800 &"
                          eval $joycommand
                  esac
                  As you may have noticed, I've uncommented some of the lines at the start of the script, in order to get the runcommand.log file, and getting some hints about what's wrong with it.
                  I've rebooted my Pi, but I got no runcommand.log file into the /dev/shm/ directory; I've also tried to run directly the script with ./runcommand-onstart.sh, and I got an empty runcommand.log file.
                  What am I doing wrong ?
                  Thanks for any help.
                  • W
                    weirdocollector
                    Hi again!
                    I've made some progress.
                    Launching the script ./runcommand-onstart.sh atari800, I get the following error message:
                    -- [ ERROR ] ------------------------------------------------------ error: invalid argument '--evdev-absmap ABS_HAT0X-=du,ABS_HAT0X+=dd,ABS_HAT0Y-=dl,ABS_HAT0Y+=dr' string2axis(): couldn't convert string "du" to XboxAxis
                    The problem seems to be that I do not know how to map the Xbox One controller hat (that is considered an analog input), to the du, dd, dl, dr keys.
                    Do someone know how the correct mapping can be done ?
                    I've looked at the xboxdrv documentation, but I couldn't extrapolate anything useful.
                      mediamogul Global Moderator @weirdocollector
                      @weirdocollector
                      The error is from du, dd, dl, dr being used in --evdev-absmap. du, dd, dl, dr can only be used with --ui-buttonmap alongside --dpad-as-button.
                      W 1 Reply Last reply Reply Quote 1
                        Pyjamarama
                        @mediamogul You do a terrific job. I have gone through your guide many times but without success.
                        I think I mess up in the rc.local
                        The evtest displays lots of entries when a press a button and lots lots lots :) when I move a stick or analog trigger.
                        So I think my problem lies in how to populate the rc.local from the results of evtest
                        Can you post me your rc.local ?
                        I think I can get an idea reading yours and evtesting my retropie.
                        Thank you!
                        • W
                          weirdocollector @mediamogul
                          @mediamogul
                          Hi,
                          I've tried the following:
                          --ui-buttonmap du=ABS_HAT0X-, dd=ABS_HAT0X+, dl= ABS_HAT0Y-, dr=ABS_HAT0Y+
                          preceded by alongside --dpad-as-button, but it still get an error.
                          How can I map the hat (seen as an analog input) to the dd, du, dl, dr keys ?
                            @Pyjamarama said in Guide: Advanced Controller Mappings:
                            This also happens with one of my controllers. In my case it meant that the axis input was so sensitive that it was being activated whenever any button was pressed. To prevent this from carrying over to the virtual controller, I had to add the --deadzone 4000. However, you'll still need a way to discern the actual button information from all the extra information you're given in evtest. This takes a bit of work, as you'll have to barely tap each button and then scroll up to the very top of the resulting input and see what the first listing was before all the garbage.
                              @weirdocollector said in Guide: Advanced Controller Mappings:
                              Mapping the dpad hatswitch from a physical controller to the xboxdrv virtual controller is done as follows:
                              --evdev-absmap ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y
                              From there you would normally map keys to it like any other axis:
                              --ui-axismap dpad_x=KEY_LEFT:KEY_RIGHT,dpad_y=KEY_UP:KEY_DOWN
                              However, if you want to the dpad to be seen as button presses rather than an axis with the new virtual controller, you would add:
                              --dpad-as-button
                              Once this has been added you can now key-map the dpad with --ui-buttonmap such as:
                              --ui-buttonmap du=KEY_UP,dd=KEY_DOWN,dl=KEY_LEFT,dr=KEY_RIGHT
                              W 1 Reply Last reply Reply Quote 2
                              • W
                                @mediamogul
                                Thanks mediamomogul!
                                Now the script works, but I have another problem.
                                If I enter the Atari5200 emulator, the controller commands doesn't work, but if I go to my SSH console and I type (in the /opt/retropie/configs/all directory) ./runcommand-onstart.sh atari800 + Return, while the emulator is running, the controller starts working as expected (yay!).
                                It seems that the script is finally correct, but it doesn't seem to start when the atari emulator il launched.
                                Am I forgetting something ?
                                  @weirdocollector
                                  I'm afraid I'll have to defer this question to @MadHorse, who has a better understanding of this area. In the mean time, go ahead and post the full contents of your runcommand-onstart.sh file and I'll see if anything jumps out.
                                  • W
                                    @mediamogul
                                    Thanks !
                                    Here is my runcommand-onstart.sh script:
                                    #!/bin/sh
                                    ## Name of the rom
                                    ### The FUN begins
                                    rom="${3##*/}"
                                        --silent \
                                        --force-feedback \
                                        --deadzone 4000 \
                                        --mimic-xpad \
                                    	--dpad-as-button \
                                    ### Kill Command
                                    case $1 in
                                    	atari800)
                                            $xboxkill
                                            eval $joycommand
                                    esac
                                    Thanks for any help !
                                    • W
                                      weirdocollector
                                      Ok, I've found the problem...
                                      The runcommand-onstart.sh script passes as first parameters ($1) the string atari5200, and not the string atari800, making the case into the script to skip the execution of the driver.
                                      In my script I've changed all the occurrances of atari800 into atari5200and it now works !!
                                      Thanks to everybody for all the help !
                                        @weirdocollector
                                        Well done sir! Case scripting is an area that I haven't had time to fully explore yet, so these posts are always very informative.
                                          meleu @mediamogul
                                          @mediamogul sorry for acting like a lazy guy here, but can you share with us a way to set only one button to act like pressing two buttons?
                                          The goal is to put a button on a bartop to do "exit emulator" function (usually start+select).
                                          Thanks in advance.
                                            mediamogul Global Moderator @meleu
                                            @meleu
                                            Not a problem. Let's say that the keyboard key you're looking to map to 'start+select' is the 'Escape' key. Also, we'll assume that 'Back' is being used as a stand-in for 'Select', due to the lack of a 'Select' button option on the virtual XBox controller. The mapping would read as:
                                            --ui-buttonmap back+start=KEY_ESC
                                            If you ever run into software that uses a key combination to exit, such as 'ctrl+escape', the alteration is nothing more complicated than:
                                            --ui-buttonmap back+start=KEY_LEFTCTRL+KEY_ESC
                                            or possibly:
                                            --ui-buttonmap back+start=KEY_RIGHTCTRL+KEY_ESC
