    NES usb controller loads random states and scrolls through roms automatically
    load statecontroller helpsave states
    3 Posts 2 Posters 548 Views
    • L
      lakerice
      Hi, I've tried to find posts where the original NES controller type (mine is USB) loads different load states whenever I call it, but I can't. For example, I'm playing Zelda 2 and my controller was mapped to save state by pressing up and select and load state with down and select; I'll save at a certain point and then it will load another state from another point I had saved. If I keep pressing load state it just shows me load state 3, 4, 6, 8, etc. Very annoying considering how hard that game is :)
      The controller also skims through my roms automatically whenever I go back to my NES rom list, as well as even going back to another screen sometimes when I am trying to access options like Retroarch or other Pi settings.
      I am using a 3B Pi with Retropie version 4.7.1.
      Does anyone know why this happens? Is there a known setting that can fix this? I have been using this controller for a while, but recently it has been doing this odd behaviour, especially after updating the OS.
        Can you test the controller on another system (PC ?) and see if it behaves similarly ? Could be a hardware problem.
        • L
          lakerice @mitu
          @mitu So sorry for the delay...busy week and didn't have much time to play. Just tried my ps3 controller and yep, you're right it's simply the controller itself.
