    Where is Retroarch 'Device Index'?
    device index
    2 Posts 2 Posters 4.7k Views
    • E
      earthprime
      My generic usb N64 controller is recognized as a 'PS3 Controller'. I removed the PS3 Controller.cfg from the autoconfig folder (thinking that would fix it), but retroarch just says "PS3 Controller config not found, using fallback". The 'Device Index' in the INPUT setting also shows 'PS3 Controller' and it wont let me change it. Its like Retroarch is saying "Your N64 USB controller is a PS3 controller whether you like it or not".
      Retroarch is pulling this info from somewhere. Where can I locate the 'Device Index' to see the entry for 'PS3 Controller'?
        The 'device index' is the order number assigned by RetroArch for the controller, from list of the controllers detected. If you have just one controller connected, it will always be 1.
        You can change the device index associated with a player from the Controls menu in the RGUI, under 'Port # Controls'. Given that you only have 1, you'll not be able to change it from the interface, since no other controller is present in the list.
        It's not RetroArch that's determining the name, is the operating system that gives RetroArch the list of controllers with their names and characteristics. If your USB controller is telling the OS my name is PS3 Controller, this is now I identify myself, then this is what RetroArch shows.
