    Help with Nespi4 shutdown script
    nespi4shutdown scriptcrashing
    2 Posts 1 Posters 522 Views
      rtarroyo
      Hello everyone, I recently got a Nespi4 case for my Pi4 - 4gb model.
      Everything is fine, so I decided to try their shutdown script, for the buttons, installed it from their github:
      https://github.com/RetroFlag/retroflag-picase/blob/master/README.md
      Command I Used:
      wget -O - "https://raw.githubusercontent.com/RetroFlag/retroflag-picase/master/install.sh" | sudo bash
      Result:
      Shutdown Buttom turns it off instantly (dont know if it should do that)
      Reset Button resets, so okay
      Reseting system from emulationstation also works
      And finally, shutting down from emulationstation crashes the system, image below:
      Already tried re-installing the script.
      Any help is welcome.
      Thanks in advance
        rtarroyo @rtarroyo
        @rtarroyo BTW
        The internal switch is turned on to safe shutdown and im running the latest version of Retropie, installed it today
