    Roms keep copying over to the SD card from the USB stick
    pi zerousb stickfile transfer
    28 Posts 3 Posters 3.1k Views
      mitu Global Moderator @gordonfreemanjr
      @gordonfreemanjr said in Roms keep copying over to the SD card from the USB stick:
      It takes now the Pi over 40 minutes to boot. It’s very weird: the USB contains roms from 7 systems, about 30-34 GB of data, including the media files. There must something I’ve done wrong.
      It depends on the # of roms and files withing the ROM folders. A Pi zero is a slow system anyway.
      The “can’t parse Setting file” and a bunch of other parsing errors have disappeared. The only ones left are these referring to systems I’m not using: PC, Sega CD, Atari. There must to be some track of formerly present roms somewhere within the system.
      Please post the ES log file, as asked before.
        gordonfreemanjr @mitu
        @mitu Yes, sorry, I was figuring that out :)
        Apparently the log file is too large for Pastebin. Here's the link to the txt file via WeTransfer:
        https://we.tl/t-IIvd3mQC1n (still better than pasting it here).
        Look like the system spends ages looking for deleted roms. Maybe you'll see something more.
        Thanks!
        RPi 4 4GB
        Retropie v 4.7.1
          I see a few systems have an empty gamelist.xml, which you can probably delete to get rid of the log message, but that's not a problem and wouldn't account for slowing down.
          You can turn on the 'Parse Metadata Only' option in EmulationStation and the system would load only what's in the gamelist.xml, without checking the file on disc. That would make loading much faster, but with the amount of deleted/missing entries you have, the game lists would be wrong.
          You can of course delete the gamelist.xml files and let EmulationStation re-create them, so you'll not have missing entries. That means you'll probably have to re-scrape again - that's where the SkyScraper cache comes in handy, since it would generate the gamelists (with the media/artwork) without actually re-scraping the data online.
            That’s fine, I have a copy of the cache. I can easily recreate the gamelists.
            a. When I do and the gamelists are finally OK: how do I make ES parse them only to speed up the boot process? In the GUI?
            b. Where exactly should I delete the missing systems from, so the Pi stops looking fot their respective gamelists?
            Thanks!
            RPi 4 4GB
            Retropie v 4.7.1
              There is a setting in the EmulationStation's menu called Parse Gamelists Only.
              You don't need the roms' folders, just the gamelist.xml files that are empty. Their names and location are in the log file you posted.
              G 2 Replies Last reply Reply Quote 0
                @mitu Ok, so having copied the backup cache in, 3 systems are visible on the Vacuum list and 6 are missing from it. I tried rescraping with „only missing” option, so maybe it updates the existing cache in a way it’s discoverable by the vacuum script, but no luck.
                I’m thinking about rescraping with both „only missing” and „refresh cache” flags on, but I’m not sure if it does any good.
                RPi 4 4GB
                Retropie v 4.7.1
                  gordonfreemanjr @gordonfreemanjr
                  Got it to work with the commnand line. I’m regenerating gamelists now, will let you know how it turns out.
                  RPi 4 4GB
                  Retropie v 4.7.1
                    @mitu Case is closed. Everything is working perfectly. Thanks for your time and help!
                    RPi 4 4GB
                    Retropie v 4.7.1
