    lr-pcsx-rearmed not detect controller
    lr-pcsx-rearmedrpi3b+
    5 Posts 4 Posters 1.0k Views
      snock
      Updated to 4.7.2 on a 3b + rpi. The psx emulator is the only one that does not detect the controller, when I get to the menu of a game it is as if I were continuously moving the stick to choose an option.
      Previously it is working for me without problem, I have not touched anything in the configuration.
      Fixed, in options disable multipad. I never modified that option and it worked.
      NakynawN 1 Reply Last reply Reply Quote 0
      • NakynawN
        Nakynaw @snock
        @snock I just upgraded to 4.7 and on PSX my Xbox 360 controller does not seem to be recognised, even though it works for retroarch menu.
        Can I please ask a bit more precisions (noobie proof) about the multipad disabling option?
        I used to be able to use both the pad and the joystick with my controller on PSX. Is it still possible?
        PI4B 8GRAM (Canakit Extreme) - Retropie 4.6.7 (my first Pi ever : september 2020)
        OC : arm=2k, v3d=830, hdmi4kp60=1, turbo=1, OV=6
        T windgW 2 Replies Last reply Reply Quote 0
          Thiago Delmunde @Nakynaw
          @nakynaw Is same to me! I've updated the emulator and my controller (PS4 controller) to te PSX stopping to recognized. To be more specfic, one a game is ok, only de SpiderMan2.
          • windgW
            windg
            This post is deleted!
            • windgW
              windg @Nakynaw
              @nakynaw
              First, try to update the ir-pcsx-rearmed core and check again . instructions:https://retropie.org.uk/docs/Updating-RetroPie/.
              If after the update the problem is still there, follow this steps:
              To disable the multitap:
              Open the RetroArch menu while the game is running and from the options, enable the Show other input settings.
              After that, restart the game and open again the RetroArch menu and from the options set to off the Mutitap1 and Multitap2 and you are ready.
