    Save / Load State not working correctly. Select is not recognized when pressed for saves
    save state
    3 Posts 2 Posters 336 Views
      Bucko1980
      I am running a retropie 4.7.1 and using a pair of USB wireless SNES Controllers that are configured according the the directions.
      I am using a Kano Kit power supply that i think is 3.5 amps.
      Built the retropie from the image downloaded from this site.
      Currently connected I have the two usb wireless controllers and a USB Keyboard.
      For some reason the select button is not working when loading/saving states. if I press the left shoulder it saves in slot 0, but i have not found a way to use the right shoulder button and/or select to select the save i want to load or to load a specific state.
      I have reconfigured the controller input a few times and no luck.
      Any suggestions. Select does nothing when it is pressed with either left shoulder or right shoulder.
        Bucko1980 @Bucko1980
        @bucko1980
        Already figured out my own issue. I had the hot key as the upper left shoulder button and it needs to be select.
        ClydeC 1 Reply Last reply Reply Quote 1
          Clyde @Bucko1980
          @bucko1980 Thanks for sharing your solution!
