    need help with Famicom games not showing up also pcengine
    romsfoldernamessystemshome screen
    3 Posts 2 Posters 824 Views
    • PlushBansheeP
      PlushBanshee
      hi so i made folders
      (fsd) Famicom
      (pcenginecd) PC Engine CD
      (tg16) PC Engine TG16
      (sgfx) PC Engine SuperGrafx
      i know that i could just place all thee Famicom games and merge them with (nes)
      but i see images of Famicom having its own system on thee menu and i really don't like mixing systems
      into one is there a way to fix this i should also mention i put Famicom BIO's in thee bio folder but still didn't if it
      thanksfor reading also if its possible does Super Famicom has its own folder in roms
        Just creating the folder doesn't mean they'll show up, EmulationStation needs to know about them to look for game there.
        (fsd) Famicom
        this exists by default on any RetroPie installation - it's named fds.
        RetroPie uses the pcengine folder for PC-Engine games. If you wish to add them to separate folders, you can add them duplicating the pcengine folder as indicated in the docs - https://retropie.org.uk/docs/Add-a-New-System-in-EmulationStation/.
        Note that not all themes support all variants of consoles, so they might be missing images/artwork if you add your own systems.
        PlushBansheeP 1 Reply Last reply Reply Quote 1
        • PlushBansheeP
          PlushBanshee @mitu
          @mitu thank you for thee replay it really help so much thank you again
