    Easiest way to load games onto Pi Zero
    7 Posts 6 Posters 2.7k Views
      dalehitchy
      Het everyone.
      I had a Pi 3 and previously transferred over games via FTP. Just got the pi zero and wondering whats the easiest / best way to transfer games over. All i have at the moment is on mini to standard usb cable which I have a controller plugged into. Is it possible to do it currently with what I have. I think before on the pi 3 there was an option to just plug in a usb stick and it will automatically just copy games to sd card. is this still an option. If so do i listerally just plug a usb in and thats it?
      HollowSavantH 1 Reply Last reply Reply Quote 0
        The best and easiest way for me is insert the microSD in a SD adapter and then insert on my laptop SD slot. Transfer everything I want to the microSD.
        [EDIT: I have Linux Mint on my laptop.]
          edmaul69 @meleu
          @meleu doesnt work on a pc. You only see the boot folder.
            meleu @edmaul69
            @edmaul69 sorry. My tip is incomplete. My laptop is running Linux Mint. Windows can't read the SD formatted for RetroPie.
            • HOWH
              HOW
              So any tips how to acheive without another Linux device? Thanks in advance :)
              senkunS 1 Reply Last reply Reply Quote 0
              • senkunS
                senkun @HOW
                @HOW said in Easiest way to load games onto Pi Zero:
                putty, drag and drop, if you have wifi dongle.
                @dalehitchy said in Easiest way to load games onto Pi Zero:
                I believe that's still possible, been a long while since I did that. Make sure you have a folder named retropie on the stick. Try it out and see, can't hurt.
                https://github.com/retropie/retropie-setup/wiki/Transferring-Roms
                • HollowSavantH
                  HollowSavant @dalehitchy
                  @dalehitchy so if anyone comes looking for this thread years in the future, the roms file locations, which a previous user failed to state, is located at "/media/pi/retropie/home/pi/RetroPie/roms/" within the SDcard itself. you just need to pick the folder for which your rom is supported(GBC, GBA, etc). so for pokemon crystal it will look like this: /media/pi/retropie/home/pi/RetroPie/roms/gbc/pokemon_crystal.gbc
                  you will need to be using some type of linux OS to be able to see this folder as windows cannot see above the boot folder.
