    Any speed tweaks for NHL96 in DosBox_SDL2?
    dosboxconfigurationdosbox configgames sdlretropie 4.7
    3 Posts 2 Posters 615 Views
    • jamrom2J
      jamrom2
      RPi3b+ (default, not overclocked)
      Retropie 7.4
      Dosbox_SDL2 (latest version)
      I have it running and was fairly easy to do so. BUT... unless I run it in Lo-res version, it's a slide-show. I run it in Hi-Res, but just about everything it turned off, which kinda ruins the game.
      In my config file I made specific to NHL 96, I set these values:
      machine=vesa_nolfb - just figured it might help, but no noticeable effect
      core=dynamic
      cputype=auto
      cycles=max
      Any other tweaks I can do to get a little more speed out of the game settings in DosBox... or is this pretty much what I should expect. Such a great game to have running, if you like Hockey, but it's pretty much unplayable.
      Thanks!
      JR
        Steams71 @jamrom2
        @jamrom2 You could try changing the cycles from max to 100000. I feel setting a high cycles gives better results than the max setting.
        • jamrom2J
          jamrom2 @Steams71
          @steams71 I messed around with a few different cycles, it somewhat helps...but it just seems this game is on the cusp of the Pi's performance envelope. I found around 16,000 - 18,000 is the best it can do and not have audio issues.
          I turned off all the fun caveats of the game and just run it as a clean ice, bare bones game.
          I'm not thrilled...but I'm very happy to have it running and playable on my build.
          Thanks for the help!
