    Help with Golly! Ghost! Overlay using lr-MAME2016
    lr-mame2016mame artworkmame overlaysmame2016
    14 Posts 4 Posters 2.7k Views
    • TPRT
      TPR
      I'm using @roslof very helpful MAME compatibility guide and I have a question about getting the overlay for Golly! Ghost! to work. I can get the artwork to appear just fine in 2003-plus by dropping the artwork into the folder:
      /home/pi/RetroPie/BIOS/mame2003-plus/artwork/
      but it does not seem to work if I drop the artwork file into:
      /home/pi/RetroPie/BIOS/mame2016/artwork/
      Do I have the artwork in the wrong place? I've tried several different versions of the overlay, all of which seem to work in 2003-plus but not in 2016. I'm assuming my artwork folder is wrong and after about an hour of Googling around, I can't find any reference that can help me.
      Note that I can't get the game to play properly in 2003-plus but the artwork appears, however in 2016, the game plays properly but I cannot get the artwork to appear.
      In @roslof's doc it says: "A MUST to get background artwork. Works REALLY well." so obviously someone has gotten it to work!
      Please help! Thank you!
      roslofR 1 Reply Last reply Reply Quote 0
      • roslofR
        roslof @TPR
        @tpr said in Help with Golly! Ghost! Overlay using lr-MAME2016:
        I placed mine in /home/pi/RetroPie/BIOS/mame2016/artwork
        My artwork filename is gollygho.zip
        IMPORTANT: The artwork ZIP contains 28 files including a lay file named "default.lay". I don't think the more modern mame2016 can use the older art format that I believe 2003-Plus uses.
        Since this is not a ROM, I am now sharing this artwork file for you here.
        TPRT M 2 Replies Last reply Reply Quote 1
        • TPRT
          TPR @roslof
          @roslof THANK YOU!!!! That worked perfectly fine. Do you happen to have a source for the overlays that work in 2016? Looking around the internet, sites like Mr. Do!'s & progettosnaps don't work for that version of MAME. And I can't seem to find the 2016 specific ones anywhere.
          Also, I just want to note that your spreadsheet has been incredibly helpful! Thank you so much for all the time it must have taken to put that together.
          DreamcastKidD roslofR 2 Replies Last reply Reply Quote 0
          • DreamcastKidD
            DreamcastKid Banned @TPR
            @tpr
            i do mine a little differently, and has always worked for me
            for lr-mame2016 and lr-mame2013, lr-mame2013-plus
            i just simply use a .png file overlay and a .cfg file and put it in ... /opt/retropie/configs/all/retroarch/overlay/
            eg. for the Arcade Game Wyvern-F0
            wyvernf0.cfg
            contents of wyvernf0.cfg is as follows ...
            overlays = 1
            overlay0_full_screen = true
            overlay0_descs = 0
            then in /opt/retropie/configs/all/retroarch/config/MAME 2016
            i also have another wyvernf0.cfg file .. contents of this one contain all my personal settings for the game, but it's the last 3 lines that ares the important ones that references the overlay
            all_users_control_menu = "false"
            video_crop_overscan = "false"
            custom_viewport_width = "740"
            custom_viewport_height = "1024"
            custom_viewport_x = "270"
            custom_viewport_y = "0"
            aspect_ratio_index = "23"
            video_shader_enable = "false"
            input_overlay_enable = "true"
            input_overlay_opacity = "1.000000"
            input_overlay = "~/.config/retroarch/overlay/wyvernf0.cfg"
            roslofR 1 Reply Last reply Reply Quote 1
            • roslofR
              roslof @DreamcastKid
              @dreamcastkid said in Help with Golly! Ghost! Overlay using lr-MAME2016:
              @tpr
              wyvernf0.cfg
              overlays = 1
              overlay0_descs = 0
              Right, that works fine as a static retroarch overlay, but don't do that for Golly Ghost. The MAME background is dynamic. Sections of the overlay turn on and off as ghosts appear. For games like this, consider removing any retroarch overlays and follow my advice for all the goodness. There are number of games that work especially well with the MAME system. Consider it an additional tool and not a full substitution for Retroarch overlays.
              DreamcastKidD 1 Reply Last reply Reply Quote 0
              • DreamcastKidD
                DreamcastKid Banned @roslof
                @roslof said in Help with Golly! Ghost! Overlay using lr-MAME2016:
                oh, i didn't realize you could have dynamic backgrounds
                cool :)
                Oh well, for my purposes ... static overlays do the job fine for me :)
                I only use them for vertical games to add artwork to the sides.
                TPRT 1 Reply Last reply Reply Quote 0
                • TPRT
                  TPR @DreamcastKid
                  cool :)
                  Yeah, that's a bit different from what I was talking about. The overlays I needed are the ones where the artwork is overlayed on top of the gameplay to create part of the gameplay field. For example, a game like Armor Attack is basically unplayble without the graphic overlay as you can't tell where your vehicle is going:
                  But I do appreciate your comments on adding bezels and other graphic elements. When I get to that point in my build, I'll take a look at it.
                  • roslofR
                    roslof @TPR
                    Unlike ROMsets, the newer (.lay) artwork works for most of the later MAMEs. If I recall, Mr. Do should be fine for 2015, 2016, lr-mame...
                    Using symlinks, I ended up sharing a single folder for all MAME artwork supported by the newer MAMEs, so I don't have to fuss with putting some in 2016, others in 2015... You get the idea.
                    • DreamcastKidD
                      I have Armor Attack overlay setup exactly the same way i described in my previous post :)
                      eg. armora.png (transparent png) and the armora.cfg file in /opt/retropie/configs/all/retroarch/overlay/
                      • TPRT
                        TPR @roslof
                        @roslof Do you happen to remember where you got the Golly Ghost overlay from? Or did you make it yourself? I'm just trying to find another source in case I run into an issue like that again. I must have downloaded about 10 different versions of the overlay and the only one that worked was yours!
                        • roslofR
                          roslof @TPR
                          I just confirmed it's from Mr. Do's MAME Artwork page.
                          Downloads/ In-game Arcade Artwork.
                          WAIT several seconds for the full page to load. Search for "Golly! Ghost!" and the exact file is still there.
                          • TPRT
                            TPR @roslof
                            @roslof I'm going to go check again. Call me crazy, but I swear I downloaded that exact one and it didn't work! :D
                            • roslofR
                              roslof @TPR
                              @tpr nah, no crazy here.
                              It's actually under "Golly! Ghost!" <--with exclamation marks.
                                markellis26 @roslof
                                @roslof
                                I have the exact same problem but I can't find mame 2016 folder under the bios folder on my image-virtualman 128gb arcade but it must be there as it is an option to use to open the rom file!
                                Any idea why, or where it could be??
                                M
