    Tribute 64 and A and B Binding to Same Key
    n64mupen64plustributetribute64retrobit
    16 Posts 4 Posters 1.9k Views
      Krystalis
      Pi Model or other hardware: Raspberry Pi 3 B+
      Power Supply used: 5V generic
      RetroPie Version Used: 4.7.1
      Built From: Pre Made SD Image from RetroPie website, Flashed with Etcher
      USB Devices connected: Keyboard
      Controller used: Tribute 64 USB
      Error messages received:
      Verbose log (if relevant):
      Guide used:
      File:
      Emulator: Mupen64Plus
      Attachment of config files:
      How to replicate the problem: Load N64 content and play with the Tribute 64 controller
      Basically I've properly bound the Tribute 64 controller and it works fine in menus, with A and B recognized as separate keys.
      However, when I load N64 content into Mupen64Plus, the A and B key are treated as one and the same-- if I've correctly bound A to A and B to B, I will, say, both jump and examine signs in Super Mario 64 with B, but A will be completely unresponsive.
      If I reverse the bindings during setup for the giggles, A and B will now be both bound to A.
      This controller also works fine with RetroArch 1.9.0 PC, where I tested this before setting up my Pi 3 B+.
      This exact problem was also happening when I was trying out different images with Batocera, so it seems to be largely an OS agnostic problem. They do both share EmulationStation and Libretro, but now it feels like I'm missing something obvious with LibRetro or ES and could use some pointers.
      Thanks!
      IanDaemonI CyberRazorCutC 2 Replies Last reply Reply Quote 0
      • IanDaemonI
        IanDaemon @Krystalis
        @krystalis Are they using the same driver? Same version of RetroArch?
        • Cocktail Cabinet Games
        • Check out the MAME RoW
          Krystalis @IanDaemon
          @iandaemon Being honest, that'd be hard to tell for me ATM. I flashed over the image of Batocera I had with RetroArch, and right now I'm taking a break from troubleshooting and am too drained to flash Batocera back to check RA versions.
          Either way, I know you can bind keys on a per core basis on PC, separately from automapping, and it feels like that might be the part I'm missing here. But I can't find the option to change inputs based on a core basis on RetroPie and Batocera.
          IanDaemonI 1 Reply Last reply Reply Quote 0
          • IanDaemonI
            @krystalis Can you get to the Retroarch menu?
            Main menu -> Settings -> Input?
              @iandaemon The one with the green and black UI with white font? Yeah, I can.
                Is mupen64plus the standalone emulator or the libretro core (RetroArch) ? You can look at the configuration generated by EmulationStation in
                • \\retropie\configs\n64\InputAutoCfg.ini for the standalone emulator
                • \\retropie\configs\all\retroarch-joypads for the libretro based emulators.
                Post the RetroArch .cfg here in the topic, surrounded by code tags (```).
                  Krystalis @mitu
                  @mitu I'll be honest and say it's the one from the home menu, but I'm not entirely sure which one's which, so I'm posting both.
                  retroarch.cfg
                  input_remapping_directory = "/opt/retropie/configs/n64/"
                  input_player1_joypad_index = "0"
                  # input_player4_joypad_index = ""
                  # input_player2_joypad_index = ""
                  # input_player3_joypad_index = ""
                  input_joypad_driver = "udev"
                  # input_player8_analog_dpad_mode = ""
                  # video_smooth = ""
                  #include "/opt/retropie/configs/all/retroarch.cfg"```
                  The controller config I didn't keep after my
                  SWITCH CO.,LTD. Controller (Dinput).cfg
                  input_driver = "udev"
                  input_device = "SWITCH CO.,LTD. Controller (Dinput)"
                  input_vendor_id = "9571"
                  input_product_id = "1397"
                  input_b_btn = "2"
                  input_start_btn = "12"
                  input_up_btn = "h0up"
                  input_down_btn = "h0down"
                  input_left_btn = "h0left"
                  input_right_btn = "h0right"
                  input_a_btn = "1"
                  input_r_btn = "5"
                  input_l2_btn = "6"
                  input_r2_btn = "7"
                  input_l_x_plus_axis = "+0"
                  input_l_x_minus_axis = "-0"
                  input_l_y_plus_axis = "+1"
                  input_l_y_minus_axis = "-1"
                  input_r_x_plus_btn = "9"
                  input_r_x_minus_btn = "3"
                  input_r_y_plus_btn = "0"
                  input_r_y_minus_btn = "8"
                  I've also tested it by directly copying and replacing and saving the controller config, the one directly above, with the contents found here:
                  https://github.com/libretro/retroarch-joypad-autoconfig/blob/master/xinput/Retro-Bit Tribute64 - USB (D-Input).cfg
                  But it doesn't seem to have made any difference.
                    mitu Global Moderator @Krystalis
                    @krystalis said in Tribute 64 and A and B Binding to Same Key:
                    Hm, you posted only the RetroArch configurations, these do not apply to the standalone Mupen64plus emulator, if you're using it. To determine which emulator you're using, check out the Runcommand launch menu splash dialog, it shows you the name of the emulator.
                    I see that the auto-config configuration generated for RetroArch, A and B have different input codes, so there's no mapping error there.
                    Can you try and run a diagnostic command and see how Linux sees the input buttons ? Exit EmulationStation, make sure the N64 controller is the only one connected, then run
                    jstest /dev/input/js0
                    press the A/B buttons and see if they produce different results. You can stop the test by pressing Ctrl+C.
                    EDIT: is this the controller in question (I ssume the one with the 'USB Port') ?
                      Krystalis @mitu
                      @mitu That's the one, yeah.
                      FWIW, I did the self test and the inputs seemed to respond just fine. If I only pressed one or the other, they responded correctly. If I pressed them both, they would both turn on.
                      I'll assume I'm using Mupen as a RA core because I haven't altered the install. I'm just using the basic stuff supplied for the emulator for testing purposes, and haven't installed anything extra.
                      Also, if you're curious, and forgive the potato TV taken with phone picture:
                      https://imgur.com/EKVEuy6
                        That looks fine. Are you sure you're using the Libretro core to run the game ? Can you check the ini file I mentioned earlier and post its contents ?
                          Krystalis @mitu
                          @mitu I was using the Libretro core. Though not entirely sure how to explain this, but goblins. I reflashed the image and I got the new Ozone RA UI which allowed me to download controller profiles and it was picked up as a Nintendo 64 USB device and it worked fine from there.
                          IDK, so long as its fixed itself.
                            Can you find the controller's .cfg file and compare to the you had before ? I'm curious what's the difference.
                            • CyberRazorCutC
                              CyberRazorCut @Krystalis
                              @krystalis I had a problem with mapping my Tribute 64, but this sorted it out for me. It might be of help to you.
                                Krystalis @mitu
                                @mitu I believe this is the one. I modified it from the default profile RA gave me after updating all profiles, because C right and up were swapped, and so were Z, L and R.
                                input_device_display_name = "Nintendo 64 USB Controller"
                                input_b_btn = "1"
                                input_y_btn = "2"
                                input_a_btn = "2"
                                input_l_btn = "6"
                                input_r_btn = "7"
                                input_l2_btn = "5"
                                input_b_btn_label = "A"
                                input_y_btn_label = "B"
                                input_A_btn_label = "B"
                                input_up_btn_label = "D-Pad Up"
                                input_down_btn_label = "D-Pad Down"
                                input_left_btn_label = "D-Pad Left"
                                input_right_btn_label = "D-Pad Right"
                                input_l_btn_label = "Left Shoulder"
                                input_r_btn_label = "Right Shoulder"
                                input_l2_btn_label = "Z Trigger"
                                input_start_btn_label = "Start"
                                input_l_x_minus_axis_label = "Analog Left"
                                input_l_x_plus_axis_label = "Analog Right"
                                input_l_y_plus_axis_label = "Analog Down"
                                input_l_y_minus_axis_label = "Analog Up"
                                input_r_x_plus_btn_label = "C Right"
                                input_r_x_minus_btn_label = "C Left"
                                input_r_y_plus_btn_label = "C Bottom"
                                input_r_y_minus_btn_label = "C Top"```
                                  Krystalis @CyberRazorCut
                                  @cyberrazorcut Saw that, tried it. But again, both keys were binding to the same key, so it was a bit beyond that diagram.
                                  TBH I don't know how its fixed but I'm also not looking that gift horse in the mouth.
                                  CyberRazorCutC 1 Reply Last reply Reply Quote 0
                                  • CyberRazorCutC
                                    @krystalis I thought it might be more than just that diagram. I did have to do a minor edit to the config file for the controller, but I can't remember what it was. I hope you get it sorted.
