    Hatari works but Lr-Hatari doesn’t
    atari stemulatornot working
    20 Posts 2 Posters 1.5k Views
    • UnknownU
      Unknown
      Hi I’m having a little trouble with Atari ST. The Hatari emulator works and runs fine, but for some reason Lr-Hatari doesn’t work. I think we can rule out bad bios and ROMs because both emulators require Bios and the ROMs file names are the same. Can anyone help?
      You can't beat the classics(unless you copy them).
        Please add more info about your setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        A verbose log - as explained i the link above - would be helpful to diagnose the issue.
        UnknownU 2 Replies Last reply Reply Quote 1
        • UnknownU
          Unknown @mitu
          @mitu My apologies, I’m running a pi4 8gig model with the standard RetroPie image with an overclock. I will get you the log as soon as I can.
          • UnknownU
            Unknown @mitu
            @mitu I can’t find any files in “/dev/sum/“ . My system seems to not be creating a run command log. Do you have any idea why?
              mitu Global Moderator @Unknown
              @unknown It's /dev/shm/runcommand.log, not /dev/sum.
              UnknownU 1 Reply Last reply Reply Quote 1
              • UnknownU
                Unknown @mitu
                @mitu Pardon my typo, I meant “shm”
                  The /dev/shm/runcommand.log should be present immedately after launching a game, but it's not kept between reboots. Are you sure it's not present on your system after launching a game?
                  • UnknownU
                    Unknown @mitu
                    @mitu So it is deleted every time the system is shut off?
                      Yes, /dev/shm is a memory backed folder, so whatever is there is not stored on disc/sdcard since it's stored directly into RAM.
                      • UnknownU
                        Unknown @mitu
                        @mitu said in Hatari works but Lr-Hatari doesn’t:
                        Well that explains a lot. Here is the log:
                        Parameters:
                        Executing: LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-$
                        [INFO] RetroArch 1.8.8 (Git 9552f87)
                        [INFO] Redirecting save file to "/home/pi/RetroPie/roms/atarist/Missing - One Droid.srm".
                        [INFO] Redirecting save state to "/home/pi/RetroPie/roms/atarist/Missing - One Droid.state".
                        [INFO] Capabilities:  NEON VFPv3 VFPv4
                        [INFO] Built: Nov  2 2020
                        [INFO] Version: 1.8.8
                        [INFO] Git: 9552f87
                        [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-hatari/hatari_libretro.so"
                        [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/Hatari/Hatari.cfg.
                        [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/Hatari/atarist.cfg.
                        [INFO] [Overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/Hatari/Missing - One Droid.cfg.
                        [INFO] [Environ]: SET_CORE_OPTIONS.
                        [INFO] [Remaps]: remap directory: /opt/retropie/configs/atarist/
                        [INFO] [Environ]: GET_LOG_INTERFACE.
                        [WARN] SYSTEM DIR is empty, assume CONTENT DIR /home/pi/RetroPie/roms/atarist/Missing - One Droid.zip
                        [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/roms/atarist/".
                        [INFO] [Environ]: CORE_ASSETS_DIRECTORY: "/home/pi/.config/retroarch/downloads".
                        [libretro INFO] Retro SYSTEM_DIRECTORY /home/pi/RetroPie/roms/atarist/
                        [libretro INFO] Retro SAVE_DIRECTORY /home/pi/RetroPie/roms/atarist/
                        [libretro INFO] Retro CONTENT_DIRECTORY /home/pi/.config/retroarch/downloads
                        [INFO] [Environ]: SET_PIXEL_FORMAT: RGB565.
                        [INFO] [Environ]: SET_INPUT_DESCRIPTORS:
                        [INFO] [Environ]: SET_DISK_CONTROL_INTERFACE.
                        [libretro INFO] Resolution 832 x 520.
                        [INFO] Content loading skipped. Implementation will load it on its own.
                        [libretro ERROR] TOS image '/home/pi/RetroPie/roms/atarist//tos.img' not found. Content cannot be loaded
                        [INFO] Removing temporary content file: /home/pi/RetroPie/roms/atarist/Missing - One Droid (Europe).ipf.
                        [ERROR] Failed to load content
                        [INFO] Content ran for a total of: 00 hours, 00 minutes, 00 seconds.
                        [INFO] Unloading game..
                        [INFO] Unloading core..
                        [libretro INFO] Retro DeInit
                        [INFO] Unloading core symbols..
                        [INFO] [Core Options]: Saved core options file to "/home/pi/.config/retroarch/config/Hatari/Hatari.opt"
                        [INFO] [Video]: Does not have enough samples for monitor refresh rate estimation. Requires to run for at least 4096 frames.
                          @unknown said in Hatari works but Lr-Hatari doesn’t:
                          You've reset the RetroArch's configuration and the emulator cannot find the BIOS file
                          You shouldn't reset the RetroArch's configuration, this erases any configurations added by RetroPie, including the BIOS folder location which is set as detailed in the Docs.
                          • UnknownU
                            Unknown @mitu
                            @mitu Can I fix the reset by running basic install, and reinstalling the emulator Lr-Hatari? I was unaware of this reset.
                              How come ? The configuration is not reset unless you explicitly do so.
                              • UnknownU
                                Unknown @mitu
                                @mitu I recall messing with setting trying to figure out my Colecovision problem. I may have accidentally told it to reset then.
                                  @unknown It depends how you did the reset. Resetting the configuration for Colecovision shouldn't affect the other cores.
                                  You can try removing the \\retropie\configs\atarist\retroarch.cfg and then re-install the lr-hatari core. It should add the default retroarch.cfg for the Atari ST system.
                                  • UnknownU
                                    Unknown @mitu
                                    @mitu Ok I did what you said and it still isn't working. Here is the new log:
                                    I have my "tos.img" in the bios folder and am unsure why the emulator can't find it.
                                      Because it's not looking there. If you look in the log you posted, you'll see that SYSTEM_DIRECTORY is empty.
                                      You must have reset RetroArch after you started it from the main RetroPIe system, in which case you should look into \\retropie\configs\all and replace retroarch.cfg with retroarch.cfg.rp-dist, the default RetroPie configuration.
                                      • UnknownU
                                        Unknown @mitu
                                        @mitu If I delete the retroarch config file and reinstall retroarch will RetroPie put the correct file in place?
                                          @unknown Yes, but you don't have to. The retroarch.cfg.rp-dist file is the default configuration that RetroPie would generate, you can replace retroarch.cfg with it without reinstalling.
                                          • UnknownU
                                            Unknown @mitu
                                            @mitu Thank you it fixed all my problems I was having. You have been most helpful.
