    [Guide][DIY] Wine and Retropie - Legacy driver - Raspberry Pi 3B+
    box86legacy driverpi3 b+wine
    46 Posts 6 Posters 8.1k Views
      thepigamer @ExarKunIv
      @exarkuniv
      Is it RetroPie from PINN?
      Did you succeed in setting FAKE-KMS in raspi-config and starting emulationstation afterwards?
      Can you try exiting emulationstation, starting an xterm session (startx xterm) and running your "raspbian"-bound diablo 2 shell script? (with diablo 2 specific mesa drivers handy?)
      You might have to start startx xterm with classic fake-kms drivers and once its started override the drivers with the ones from diablo 2...
      See my Raspberry Pi tutorials at https://thepigamer.blogspot.com/p/tutorial-list.html
      • ExarKunIvE
        ExarKunIv @thepigamer
        @thepigamer so it seems that my problem was i did not install mesa correctly.
        i fixed that issue
        so now i got it to start.
        not sure if the sound was working or not. since i have BGM and i was launching it by command line. so the music did not turn off. lol
        but im getting there
        T 1 Reply Last reply Reply Quote 1
          seadog mcgrog @thepigamer
          @thepigamer thank you so much. I got a bit busy this week but I will give this a shot. I'll let you know how it goes
            @exarkuniv
            WTG,
            Here I confirm that the legacy driver blocks ARM-diablo2 from launching in RetroPie (I tried on my 3B+ so if there was some troubleshooting I could help you but it's a nogo :-( ).
            Diablo 2 mesa drivers don't start while trying to run it. So hopefully RetroPie team will release a fake-kms compliant RetroPie for older Pi's otherwise Pi 3B+ and older users will have to run Diablo 2 only from Raspbian/LXDE based distros.
            There is still some way to go from having it starting from startx xterm to having a bash script which launches itself from ports section or from a custom section.
            if xterm needs to be launched first (as in startx LD_LIBRARY_PATH.... wine libd2game_arm_sa.exe.so does not work) you will have to resort doing advanced scripting. this part of my guide may help you:
            xterm -hold -e `cd /home/pi/RetroPie/roms/wine/installed/HOMM4_eng;WINEPREFIX=/home/pi/winex86 /home/pi/wine-pol/bin/wine ./heroes4.exe;killall xinit;exit` &
            matchbox-window-manager
            exit
            You will have to replace the heroes 4 launching command by diablo 2 launching command.
            If you need further help with that don't hesitate to answer or PM me.
            • ExarKunIvE
              @thepigamer still no sound,
              i just realized that i did not mentioned how i installed it.
              i used piKiss to install it all. and im on a Pi4
              so i know that changes it all up.
                @exarkuniv
                Im blind from now (D2+retropie doesn't work on Pi3b+)
                I have 2 tracks to try to help you:
                1. if you are using HDMI check hdmi_group and hdmi_drive in /boot/config.txt
                2. try to get Alsa to work in xterm :
                  Download a .wav sample file
                  Install Alsa (I think
                  sudo apt-get install alsa-utils
                  Not sure though)
                  Install pulseaudio (sudo apt-get install pulseaudio)
                  And try alsamixer command to check your sound is linked.
                  Then try playing your .wav file inside xterm
                  With paplay xxx.wav and aplay xxx.wav
                  If both work diablo2 will work too.
                Pikiss shouldn't change anything, just make all easier.
                • ExarKunIvE
                  @thepigamer ok ill give that a shot.
                  i did not think that Pikiss changed it, from looking at the script.
                    @exarkuniv
                    Oh one last thing... that might sound stupid... but make sure sound is enabled in your arm wineprefix (sound can be tested with winecfg)... :-)
                    ExarKunIvE 1 Reply Last reply Reply Quote 1
                    • ExarKunIvE
                      @thepigamer i did see the audio tab when i was looking at the winecfg, i did try the test button. but all it did was make a little pop sound.
                      im thinking i have something else going on with my stuff
                        @exarkuniv
                        Pop sound means it works.
                        Which sound device shows winecfg? Alsa or pulse?
                        Does Diablo 2 output sound in Raspbian? it might be a problem with Diablo 2 itself.
                        • ExarKunIvE
                          @thepigamer in Raspbian it works and sounds great, no issues with anything
                          and it says winalsa.drv for winecfg, and it is set for system defaults for all outputs
                            @exarkuniv
                            I would focus on getting aplay and paplay to work.
                            That article hereafter tells you to set hdmi_drive=2 but I guess you already did it.
                            Tag "Sound does not work at all, or in some applications" could however help you
                            https://raspberrypi.stackexchange.com/questions/44/why-is-my-audio-sound-output-not-working
                            Hope it can help. Ive also had problems when trying to install sound from scratch... it's not easy when its not base installed :-/
                            ExarKunIvE 2 Replies Last reply Reply Quote 0
                            • ExarKunIvE
                              @thepigamer thanks for the info, and yes for now ill work on getting aplay and paplay to work.
                              • ExarKunIvE
                                @thepigamer at this point i have no idea. i think its something to deal with the file that is used to launch the game. i looked at the last thing you linked and going off of what that said, my sound is working fine.
                                maybe someone who i has more experentce on this or even got it working, but im lost.
                                time for me to move on to something else.
                                thanks for all your help
                                  @exarkuniv
                                  Hello,
                                  Maybe this can be a track for you:
                                  https://bbs.archlinux.org/viewtopic.php?id=252174
                                  This is an archlinux thread but such packages might exist as well in debian.
                                  Using winetricks might help you change from alsa to pulse or vice-versa in order to try it ahead.
                                  For some reason box86 redirects sound quite well, no idea why arm-wine has so many problems with this.
                                  That would indeed be cool to run D2 with wine-arm from RetroPie and get a full compatibility.
                                  • ExarKunIvE
                                    @thepigamer thanks for that, i will have to take a look into it
                                    for right now i just have raspbian with desktop installed and then retropie installed on top of that.
                                    and i have it working good.
                                    i might use a new card and try messing around more with what you have given me to see if there is a different way
                                      @exarkuniv
                                      might be something like
                                      sudo apt-get install -y alsa-lib alsa-plugins libasound2-plugins
                                      • ExarKunIvE
                                        @thepigamer after some work i have come across what is causing the sound to stop working,
                                        but so far no clue in a work around
                                        it seems when i do a OS update the sound is killed. if i leave the OS alone and only update the EMUs and ports i still have sound.
                                        so i when and manuly updated the OS and what not.
                                        i have found that raspberrypi-kernel is what kills the sound for diablo2
                                        no sure what it is changing
                                        if i have that alone i still have sound.
                                        so for now im leaving it
                                        thanks for all your help on this
                                          @exarkuniv Pi 4 users usually don't have to recompile kernel. And in this case it's a bad thing.
                                          I keep a copy of my ready-to-install 3G/1G kernel for my pi3 on my ext4 sd card so whenever something changes on my kernel, I just retype "kernel-install.sh" to revert to the old kernel.
                                          That might be a good idea to try to recompile your kernel when you get some time and keep a compiled version handy. On Pi3 it takes a single night to compile... you might have it ready in one afternoon on Pi4.
                                          https://www.raspberrypi.org/documentation/linux/kernel/building.md
                                          I won't advise you to just install my Pi3B+ kernel because I don't know if it will start on your Pi4.
                                          • ExarKunIvE
                                            @thepigamer not sure if its recompiling it completely, i was just apt-get update and updating what comes up, thats how i found that raspberrypi-kernel is where the sound breaks.
                                            which is why when i do the update through the Retropie setup and let it update the OS and drivers that the sound stops.
                                            since when im dont with my build its not going to be on the network, im not going to worry about it. since everything working just fine. i was more on a mission to find out what was causing the problem
