Journey and it’s audio sample mame2003plus
Just been tinkering around. Fired up Journey in mame2003plus. Game plays just fine until it’s time to play the song, then it crashes to desktop.
To further add to the mystery, when I enter the game setup menu, I can test the “cassette tape” just fine. The song plays loud, clear, and true. Turning the cassette player on and off emulates the cassette player perfectly.
But in game it crashes it.
I tried it on an older version of mame on my pc and it played just fine. However after one play through it glitches out.
Has anyone had any success playing Journey and the audio sample associated with it on the Pi?
@phoenixflood yes journey works fine with the sample. We'll need details about your setup to trouble shoot this issue.
Mame2003-plus commit version
Retroarch version
Retropie version.
And what platform you're onAlso a log would be helpful to diagnose.
Mame2003plus build is c1741ed.
Retroarch version is 1.8.8
Retropie is 4.7.6
On a Pi4 8gbI’ve read in another thread that it’s the sample length that’s causing an issue?
@phoenixflood the sample length issue was solve awhile ago. The sample plays as it should during gameplay, though attract music does not work for me.. so I leave that set at the default "no" in the service menu. I've confirmed on a rpi3 and a android build and it plays normally during game play.
Can you post a log from the core.
@mahoneyt944 Yup, here it is.
And yeah it crashes in attract mode. I'll play it again to double check it crashes during the concert round.
I just tried the same rom and sample in mame2010, and the sample played in attract mode though.
Regardless, here's the log from mame2003plus when it crashed in attract mode.
Parameters: Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/journey.zip" --verbose --appendconfig /dev/shm/retroarch.cfg [INFO] RetroArch 1.8.8 (Git 9552f87) [INFO] Redirecting save file to "/home/pi/RetroPie/roms/arcade/journey.srm". [INFO] Redirecting save state to "/home/pi/RetroPie/roms/arcade/journey.state". [INFO] === Build ======================================= [INFO] Capabilities: NEON VFPv3 VFPv4 [INFO] Built: Nov 2 2020 [INFO] Version: 1.8.8 [INFO] Git: 9552f87 [INFO] ================================================= [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so" [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/MAME 2003-Plus.cfg. [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/arcade.cfg. [INFO] [Overrides] game-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/journey.cfg. [INFO] Config: appending config "/home/pi/.config/retroarch/config/MAME 2003-Plus/journey.cfg" /opt/retropie/supplementary/runcommand/runcommand.sh: line 1283: 3580 Segmentation fault /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/journey.zip" --verbose --appendconfig /dev/shm/retroarch.cfg I really appreciate your time and help with this, as sure I can just set this rom to run on mame2010, but mame2003plus is such a cleaner emulator to use.
@mahoneyt944 And here's my crashlog from gameplay from getting to the concert.
I did do a cassette test before and it played the sample. It just doesnt want to do it ingame or attract mode.
Thanks again for your help and advice.
Parameters: Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/journey.zip" --verbose --appendconfig /dev/shm/retroarch.cfg [INFO] RetroArch 1.8.8 (Git 9552f87) [INFO] Redirecting save file to "/home/pi/RetroPie/roms/arcade/journey.srm". [INFO] Redirecting save state to "/home/pi/RetroPie/roms/arcade/journey.state". [INFO] === Build ======================================= [INFO] Capabilities: NEON VFPv3 VFPv4 [INFO] Built: Nov 2 2020 [INFO] Version: 1.8.8 [INFO] Git: 9552f87 [INFO] ================================================= [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so" [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/MAME 2003-Plus.cfg. [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/arcade.cfg. [INFO] [Overrides] game-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/journey.cfg. [INFO] Config: appending config "/home/pi/.config/retroarch/config/MAME 2003-Plus/journey.cfg" /opt/retropie/supplementary/runcommand/runcommand.sh: line 1283: 4483 Segmentation fault /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/journey.zip" --verbose --appendconfig /dev/shm/retroarch.cfg -
@phoenixflood I'll need the full log with debug info. When you launch the rom a quick menu will appear just before it launches where you can press "a" to enter setup. Launch the rom with "verbose logging". Then after the in-game crash, navigate to "/dev/shm/runcommand.log"
@mahoneyt944 yup. That’s the log I get.
@mahoneyt944 that last line simply says segmentation fault. That’s all the info the log file has.
@phoenixflood then something is wrong because you are missing a lot of information, even the basic rom loading info.
I would start by deleting your journey.cfg and journey.nv found in your save directory. This will be in the mame2003-plus directory where you launched the rom from. Navigate to the cfg and nv directories to delete the corresponding files.
Then I would verify that your sample is located in
bios/mame2003-plus/samples/journey.zip
inside the zip folder there should be a single file, "sepways.wav".Then if you are using any overclock settings on your rpi4 you should disable them for now.
Once disabled, I would install mame2003-plus "from source". This will take about 25 minutes or so.
Then you can enable your overclock again and retest the rom, verifying mame2003-plus is the selected emulator for journey.
@mahoneyt944 Ok, its working now. I think the issue was when I'd go to the service menu and test the cassette to get the sample to play, which it did, it would bug it during the gameplay and crash.
Because now, if I play the game without touching the service menu, the sample plays during gameplay just fine.
Yes, the sample file is fine, it has sepways.wav, its identical to all the other versions of mame I have across mutliple PCs, bit by bit. I just got stuck on this mame2003plus glitch.
But now more concerning is my verbose logging. Maybe I didn't format it correctly when I copied it into the code box. I just recreated another crash to experiment. This is the log I have. I'm going to paste it here as straight text. It does have all the rom info on the log.
Parameters:
[INFO] Git: 9552f87
/opt/retropie/supplementary/runcommand/runcommand.sh: line 1283: 24139 Segmentation fault /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/journey.zip" --verbose --appendconfig /dev/shm/retroarch.cfg -
@mahoneyt944 I see what you mean now.
Here's a verbose log from Hard Drivin, and it didn't even crash. It's just a load with verbose and exit.
Thank you for all your help tonight.
Parameters: Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/harddrvc.zip" --verbose --appendconfig /dev/shm/retroarch.cfg [INFO] RetroArch 1.8.8 (Git 9552f87) [INFO] Redirecting save file to "/home/pi/RetroPie/roms/arcade/harddrvc.srm". [INFO] Redirecting save state to "/home/pi/RetroPie/roms/arcade/harddrvc.state". [INFO] === Build ======================================= [INFO] Capabilities: NEON VFPv3 VFPv4 [INFO] Built: Nov 2 2020 [INFO] Version: 1.8.8 [INFO] Git: 9552f87 [INFO] ================================================= [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so" [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/MAME 2003-Plus.cfg. [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/arcade.cfg. [INFO] [Overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/harddrvc.cfg. [INFO] [Remaps]: remap directory: /opt/retropie/configs/arcade/ [INFO] Redirecting save file to "/home/pi/RetroPie/roms/arcade/harddrvc.srm". [INFO] Redirecting save state to "/home/pi/RetroPie/roms/arcade/harddrvc.state". [INFO] [Environ]: GET_LOG_INTERFACE. [INFO] [Environ]: PERFORMANCE_LEVEL: 10. [INFO] Content loading skipped. Implementation will load it on its own. [libretro INFO] [MAME 2003+] Full content path /home/pi/RetroPie/roms/arcade/harddrvc.zip [libretro INFO] [MAME 2003+] Git Version c1741ed [libretro INFO] [MAME 2003+] Content lookup name: harddrvc [libretro INFO] [MAME 2003+] Driver index counter: 3421. Matched game driver: harddrvc [libretro INFO] [MAME 2003+] Content identified as using paddle controls. [libretro INFO] [MAME 2003+] Content identified as using 8-way joystick controls. [libretro INFO] [MAME 2003+] Content identified by controls.c as having joysticks on axis with respect to the cabinet. [libretro INFO] [MAME 2003+] Content identified as supporting 3 players with 3 distinct controls. [libretro INFO] [MAME 2003+] Content identified as supporting 5 button controls. [libretro INFO] [MAME 2003+] Content identified by controls.c as having mirrored multiplayer control labels. [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS". [libretro INFO] [MAME 2003+] Check for trailing slash in path: /home/pi/RetroPie/roms/arcade/ [libretro INFO] [MAME 2003+] Removed a trailing slash in path: /home/pi/RetroPie/roms/arcade [libretro INFO] [MAME 2003+] Check for trailing slash in path: /home/pi/RetroPie/BIOS [libretro INFO] [MAME 2003+] Trailing slash removal was not necessary for path given. [libretro INFO] [MAME 2003+] Check for trailing slash in path: /home/pi/RetroPie/roms/arcade/ [libretro INFO] [MAME 2003+] Removed a trailing slash in path: /home/pi/RetroPie/roms/arcade [libretro INFO] [MAME 2003+] content path: /home/pi/RetroPie/roms/arcade [libretro INFO] [MAME 2003+] system path: /home/pi/RetroPie/BIOS [libretro INFO] [MAME 2003+] save path: /home/pi/RetroPie/roms/arcade [INFO] [Environ]: SET_VARIABLES. [INFO] [Environ]: SET_CONTROLLER_INFO. [libretro INFO] [MAME 2003+] Opening ROM file: 2102200r.068 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 2101210r.068 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 2104200s.068 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 2103210s.068 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 1112200w.068 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 1111210w.068 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 1114200x.068 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 1113210x.068 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 3122-70n.052 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 3121-45n.052 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 1101-10h.052 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 1103-10k.052 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 1102-10j.052 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 1104-10l.052 [libretro INFO] [MAME 2003+] read_rom_data: All done [libretro INFO] [MAME 2003+] Opening ROM file: 1123-65a.052 [libretro INFO] [MAME 2003+] Opening ROM file: 1124-55a.052 [libretro INFO] [MAME 2003+] Opening ROM file: 3125-45a.052 [libretro INFO] [MAME 2003+] Opening ROM file: 1126-30a.052 [libretro INFO] [MAME 2003+] Succesfully loaded ROMs. [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [INFO] [Environ]: SET_ROTATION: 0 [INFO] [Environ]: SET_PIXEL_FORMAT: XRGB8888. [libretro INFO] [MAME 2003+] CONTROLS: GAMEINFO: Hard Drivin' (compact, rev 2) 1990 Atari Games CPU: 68010 8.000000 MHz TMS34010 6.000000 MHz TMS34010 6.250000 MHz ADSP2100 8.000000 MHz 68000 8.000000 MHz (sound) TMS32010 20.000000 MHz (sound) Sound: 1xDAC Screen Resolution: 512 x 288 (H) 60.000000 Hz [INFO] Skipping SRAM load.. [INFO] Version of libretro API: 1 [INFO] Compiled against API: 1 [libretro INFO] [MAME 2003+] Sample rate set to 48000 [INFO] [Cheats]: Load game-specific cheatfile: /home/pi/.config/retroarch/cheats/MAME 2003-Plus/harddrvc.cht [INFO] [Audio]: Set audio input rate to: 48000.00 Hz. [INFO] [Video]: Video @ 1680x1050 [INFO] [Video]: Starting threaded video driver ... [WARN] [DRM]: Couldn't get device resources. [WARN] [DRM]: Couldn't get device resources. [INFO] [DRM]: Found 1 connectors. [INFO] [DRM]: Connector 0 connected: yes [INFO] [DRM]: Connector 0 has 20 modes. [INFO] [DRM]: Connector 0 assigned to monitor index: #1. [INFO] [DRM]: Mode 0: (1680x1050) 1680 x 1050, 60 Hz [INFO] [DRM]: Mode 1: (1280x1024) 1280 x 1024, 75 Hz [INFO] [DRM]: Mode 2: (1280x1024) 1280 x 1024, 60 Hz [INFO] [DRM]: Mode 3: (1440x900) 1440 x 900, 60 Hz [INFO] [DRM]: Mode 4: (1280x960) 1280 x 960, 60 Hz [INFO] [DRM]: Mode 5: (1280x800) 1280 x 800, 60 Hz [INFO] [DRM]: Mode 6: (1152x864) 1152 x 864, 75 Hz [INFO] [DRM]: Mode 7: (1024x768) 1024 x 768, 75 Hz [INFO] [DRM]: Mode 8: (1024x768) 1024 x 768, 70 Hz [INFO] [DRM]: Mode 9: (1024x768) 1024 x 768, 60 Hz [INFO] [DRM]: Mode 10: (832x624) 832 x 624, 75 Hz [INFO] [DRM]: Mode 11: (800x600) 800 x 600, 75 Hz [INFO] [DRM]: Mode 12: (800x600) 800 x 600, 72 Hz [INFO] [DRM]: Mode 13: (800x600) 800 x 600, 60 Hz [INFO] [DRM]: Mode 14: (800x600) 800 x 600, 56 Hz [INFO] [DRM]: Mode 15: (640x480) 640 x 480, 75 Hz [INFO] [DRM]: Mode 16: (640x480) 640 x 480, 73 Hz [INFO] [DRM]: Mode 17: (640x480) 640 x 480, 67 Hz [INFO] [DRM]: Mode 18: (640x480) 640 x 480, 60 Hz [INFO] [DRM]: Mode 19: (720x400) 720 x 400, 70 Hz [INFO] [GL]: Found GL context: kms [INFO] [GL]: Detecting screen resolution 1680x1050. [INFO] [EGL] Found EGL client version >= 1.5, trying eglGetPlatformDisplay [INFO] [EGL]: EGL version: 1.4 [INFO] [EGL]: Current context: 0xaae01680. [INFO] [KMS]: New FB: 1680x1050 (stride: 6720). [INFO] [GL]: Vendor: Broadcom, Renderer: V3D 4.2. [INFO] [GL]: Version: OpenGL ES 3.1 Mesa 19.3.2. [INFO] [GL]: Using resolution 1680x1050 [INFO] [GL]: Default shader backend found: glsl. [INFO] [Shaders]: preset directory: /home/pi/.config/retroarch/config [INFO] [Shaders]: preset directory: /opt/retropie/configs/arcade/ [INFO] [Shaders]: preset directory: /home/pi/.config/retroarch/shaders/presets [INFO] [Shader driver]: Using GLSL shader backend. [WARN] [GL]: Stock GLSL shaders will be used. [INFO] [GLSL]: Found GLSL vertex shader. [INFO] [GLSL]: Found GLSL fragment shader. [INFO] [GLSL]: Linking GLSL program. [INFO] [GLSL]: Found GLSL vertex shader. [INFO] [GLSL]: Found GLSL fragment shader. [INFO] [GLSL]: Linking GLSL program. [INFO] [GLSL]: Found GLSL vertex shader. [INFO] [GLSL]: Found GLSL fragment shader. [INFO] [GLSL]: Linking GLSL program. [INFO] [GL]: Using 4 textures. [INFO] [GL]: Loaded 1 program(s). [WARN] [udev]: Couldn't open any keyboard, mouse or touchpad. Are permissions set correctly for /dev/input/event*? [INFO] [udev]: Plugged pad: 8Bitdo SN30 Pro (11720:24833) on port #0. [INFO] [udev]: Pad #0 (/dev/input/event0) supports 0 force feedback effects. [INFO] [Joypad]: Found joypad driver: "udev". [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Video]: Found display server: null [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xsal-level2-crt.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xsal.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xScaleHQ.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_lanczos4.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_phosphor.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_snes.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/Brighter-with_Contrast.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/bsnes_gamma_ramp.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-curvature-vertical.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-curvature.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-vertical.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy-screen-grid.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy2.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/gba-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x&lcd3x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x2.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x_lcd3x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x_phosphor.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2xwaterpaint.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2xwaterpaintscanline.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq4x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq4x_lcd3x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/nds-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/nds.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/nedi.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/palm-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/phosphor.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/psp-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-2x-prescale.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-scanlines.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-simple.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes2.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpaint.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpainthicontrast.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpaintscanline.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_lcd3x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_phosphor.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_scanline.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_waterpaint.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/stock.glsl" [INFO] Found shader "/home/pi/.config/retroarch/shaders/super-2xsai.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/super-eagle.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/vba-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/xbr-lv1-noblend.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_curve.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_curve_vertical.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_standard.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_standard_vertical.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_lcd_standard.glslp" [INFO] [ALSA]: Using signed 16-bit format. [INFO] [ALSA]: Period size: 768 frames [INFO] [ALSA]: Buffer size: 3072 frames [INFO] [ALSA]: Can pause: no. [INFO] [Menu]: Found menu display driver: "gl". [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Menu]: Found menu display driver: "gl". [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [LED]: LED driver = 'null' 0x4b477c [INFO] [MIDI]: Initializing ... [INFO] [MIDI]: Input disabled. [INFO] [MIDI]: Output disabled. [INFO] [MIDI]: Initialized "alsa" driver. [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] Loading history file: [/opt/retropie/configs/all/content_history.lpl]. [INFO] Loading history file: [/opt/retropie/configs/all/content_music_history.lpl]. [INFO] Loading history file: [/opt/retropie/configs/all/content_video_history.lpl]. [INFO] Loading history file: [/opt/retropie/configs/all/content_image_history.lpl]. [INFO] Loading favorites file: [/opt/retropie/configs/all/content_favorites.lpl]. [INFO] Written to playlist file: /opt/retropie/configs/all/content_history.lpl [libretro INFO] [MAME 2003+] options.nvram_bootstrap: 0 [libretro INFO] [MAME 2003+] Delegating population of initial NVRAM to emulated system. [libretro INFO] [MAME 2003+] Preparing emulated CPUs for execution. [libretro INFO] watchdog armed [INFO] [Environ]: SET_GEOMETRY. [INFO] [KMS]: New FB: 1680x1050 (stride: 6720). [INFO] [KMS]: New FB: 1680x1050 (stride: 6720). [INFO] [Cheats]: Save game-specific cheatfile: /home/pi/.config/retroarch/cheats/MAME 2003-Plus/harddrvc.cht [INFO] Content ran for a total of: 00 hours, 00 minutes, 07 seconds. [INFO] Unloading game.. [INFO] Unloading core.. [INFO] Unloading core symbols.. [INFO] [Core Options]: Saved core options file to "/opt/retropie/configs/all/retroarch-core-options.cfg" [INFO] Threaded video stats: Frames pushed: 468, Frames dropped: 1.
@phoenixflood I'm glad it's working for you. Since I last posted I've actually fixed some inputs /dip switches for journey in mame2003-plus. Minor changes, but there was some odd inputs issues I found. Updating from source again will give you those updates if you care to.
As far as logging goes, if you don't enter the service menu in journey does your log look more normal (similar to your hard driving log)?
There seems to be an issue in journey with playing music during attract mode, that part of the emulation is probably not present in this core...so it's best to leave that service menu option set to "no" if you do enter machine setup. You can also just delete the journey.nv file to return your service menu options to default again.
It's also recommended to completely exit the game back to emulationstation once entering exiting the service menu, a soft reset in the retroarch menu is not good enough.
@mahoneyt944 Hey Check Out My New Log File!!
It was the config files for my bezels that was blocking the verbose log. I realized the other games, like Hard Drivin wasn't using a bezel, so no config file, so it got a full log.
So I removed the Journey config file, and presto, I have a full verbose log for Journey!
Parameters: Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/journey.zip" --verbose --appendconfig /dev/shm/retroarch.cfg [INFO] RetroArch 1.8.8 (Git 9552f87) [INFO] Redirecting save file to "/home/pi/RetroPie/roms/arcade/journey.srm". [INFO] Redirecting save state to "/home/pi/RetroPie/roms/arcade/journey.state". [INFO] === Build ======================================= [INFO] Capabilities: NEON VFPv3 VFPv4 [INFO] Built: Nov 2 2020 [INFO] Version: 1.8.8 [INFO] Git: 9552f87 [INFO] ================================================= [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so" [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/MAME 2003-Plus.cfg. [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/arcade.cfg. [INFO] [Overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/journey.cfg. [INFO] [Remaps]: remap directory: /opt/retropie/configs/arcade/ [INFO] Redirecting save file to "/home/pi/RetroPie/roms/arcade/journey.srm". [INFO] Redirecting save state to "/home/pi/RetroPie/roms/arcade/journey.state". [INFO] [Environ]: GET_LOG_INTERFACE. [INFO] [Environ]: PERFORMANCE_LEVEL: 10. [INFO] Content loading skipped. Implementation will load it on its own. [libretro INFO] [MAME 2003+] Full content path /home/pi/RetroPie/roms/arcade/journey.zip [libretro INFO] [MAME 2003+] Git Version 67f92ad [libretro INFO] [MAME 2003+] Content lookup name: journey [libretro INFO] [MAME 2003+] Driver index counter: 940. Matched game driver: journey [libretro INFO] [MAME 2003+] Content identified as having a tilt feature. [libretro INFO] [MAME 2003+] Content identified as using 8-way joystick controls. [libretro INFO] [MAME 2003+] Content identified by controls.c as having joysticks on axis with respect to the cabinet. [libretro INFO] [MAME 2003+] Content identified as supporting 2 players with 2 distinct controls. [libretro INFO] [MAME 2003+] Content identified as supporting 1 button controls. [libretro INFO] [MAME 2003+] Content identified by controls.c as having mirrored multiplayer control labels. [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS". [libretro INFO] [MAME 2003+] Check for trailing slash in path: /home/pi/RetroPie/roms/arcade/ [libretro INFO] [MAME 2003+] Removed a trailing slash in path: /home/pi/RetroPie/roms/arcade [libretro INFO] [MAME 2003+] Check for trailing slash in path: /home/pi/RetroPie/BIOS [libretro INFO] [MAME 2003+] Trailing slash removal was not necessary for path given. [libretro INFO] [MAME 2003+] Check for trailing slash in path: /home/pi/RetroPie/roms/arcade/ [libretro INFO] [MAME 2003+] Removed a trailing slash in path: /home/pi/RetroPie/roms/arcade [libretro INFO] [MAME 2003+] content path: /home/pi/RetroPie/roms/arcade [libretro INFO] [MAME 2003+] system path: /home/pi/RetroPie/BIOS [libretro INFO] [MAME 2003+] save path: /home/pi/RetroPie/roms/arcade [INFO] [Environ]: SET_VARIABLES. [INFO] [Environ]: SET_CONTROLLER_INFO. [libretro INFO] [MAME 2003+] Opening ROM file: d2 [libretro INFO] [MAME 2003+] Opening ROM file: d3 [libretro INFO] [MAME 2003+] Opening ROM file: d4 [libretro INFO] [MAME 2003+] Opening ROM file: d5 [libretro INFO] [MAME 2003+] Opening ROM file: d6 [libretro INFO] [MAME 2003+] Opening ROM file: a [libretro INFO] [MAME 2003+] Opening ROM file: b [libretro INFO] [MAME 2003+] Opening ROM file: c [libretro INFO] [MAME 2003+] Opening ROM file: d [libretro INFO] [MAME 2003+] Opening ROM file: g3 [libretro INFO] [MAME 2003+] Opening ROM file: g4 [libretro INFO] [MAME 2003+] Opening ROM file: a7 [libretro INFO] [MAME 2003+] Opening ROM file: a8 [libretro INFO] [MAME 2003+] Opening ROM file: a5 [libretro INFO] [MAME 2003+] Opening ROM file: a6 [libretro INFO] [MAME 2003+] Opening ROM file: a3 [libretro INFO] [MAME 2003+] Opening ROM file: a4 [libretro INFO] [MAME 2003+] Opening ROM file: a1 [libretro INFO] [MAME 2003+] Opening ROM file: a2 [libretro INFO] [MAME 2003+] Opening ROM file: 82s123.12d [libretro INFO] [MAME 2003+] Succesfully loaded ROMs. [libretro ERROR] cpunum_get_localtime() called for invalid cpu num! [INFO] [Environ]: SET_ROTATION: 0 [INFO] [Environ]: SET_ROTATION: 3 [INFO] [Environ]: SET_PIXEL_FORMAT: RGB565. [libretro INFO] [MAME 2003+] CONTROLS: GAMEINFO: Journey 1983 Bally Midway CPU: Z80 7.500000 MHz Z80 2.000000 MHz (sound) Sound (stereo): 2xAY-3-8910 2.000000 MHz Samples Screen Resolution: 512 x 480 (V) 30.000000 Hz [INFO] Skipping SRAM load.. [INFO] Version of libretro API: 1 [INFO] Compiled against API: 1 [libretro INFO] [MAME 2003+] Sample timing rate too high for framerate required dropping to 30000.000000 [INFO] [Cheats]: Load game-specific cheatfile: /home/pi/.config/retroarch/cheats/MAME 2003-Plus/journey.cht [INFO] [Audio]: Set audio input rate to: 30000.00 Hz. [INFO] [Video]: Video @ 1680x1050 [INFO] [Video]: Starting threaded video driver ... [INFO] [DRM]: Found 1 connectors. [INFO] [DRM]: Connector 0 connected: yes [INFO] [DRM]: Connector 0 has 20 modes. [INFO] [DRM]: Connector 0 assigned to monitor index: #1. [INFO] [DRM]: Mode 0: (1680x1050) 1680 x 1050, 60 Hz [INFO] [DRM]: Mode 1: (1280x1024) 1280 x 1024, 75 Hz [INFO] [DRM]: Mode 2: (1280x1024) 1280 x 1024, 60 Hz [INFO] [DRM]: Mode 3: (1440x900) 1440 x 900, 60 Hz [INFO] [DRM]: Mode 4: (1280x960) 1280 x 960, 60 Hz [INFO] [DRM]: Mode 5: (1280x800) 1280 x 800, 60 Hz [INFO] [DRM]: Mode 6: (1152x864) 1152 x 864, 75 Hz [INFO] [DRM]: Mode 7: (1024x768) 1024 x 768, 75 Hz [INFO] [DRM]: Mode 8: (1024x768) 1024 x 768, 70 Hz [INFO] [DRM]: Mode 9: (1024x768) 1024 x 768, 60 Hz [INFO] [DRM]: Mode 10: (832x624) 832 x 624, 75 Hz [INFO] [DRM]: Mode 11: (800x600) 800 x 600, 75 Hz [INFO] [DRM]: Mode 12: (800x600) 800 x 600, 72 Hz [INFO] [DRM]: Mode 13: (800x600) 800 x 600, 60 Hz [INFO] [DRM]: Mode 14: (800x600) 800 x 600, 56 Hz [INFO] [DRM]: Mode 15: (640x480) 640 x 480, 75 Hz [INFO] [DRM]: Mode 16: (640x480) 640 x 480, 73 Hz [INFO] [DRM]: Mode 17: (640x480) 640 x 480, 67 Hz [INFO] [DRM]: Mode 18: (640x480) 640 x 480, 60 Hz [INFO] [DRM]: Mode 19: (720x400) 720 x 400, 70 Hz [INFO] [GL]: Found GL context: kms [INFO] [GL]: Detecting screen resolution 1680x1050. [INFO] [EGL] Found EGL client version >= 1.5, trying eglGetPlatformDisplay [INFO] [EGL]: EGL version: 1.4 [INFO] [EGL]: Current context: 0xac401680. [INFO] [KMS]: New FB: 1680x1050 (stride: 6720). [INFO] [GL]: Vendor: Broadcom, Renderer: V3D 4.2. [INFO] [GL]: Version: OpenGL ES 3.1 Mesa 19.3.2. [INFO] [GL]: Using resolution 1680x1050 [INFO] [GL]: Default shader backend found: glsl. [INFO] [Shaders]: preset directory: /home/pi/.config/retroarch/config [INFO] [Shaders]: preset directory: /opt/retropie/configs/arcade/ [INFO] [Shaders]: preset directory: /home/pi/.config/retroarch/shaders/presets [INFO] [Shader driver]: Using GLSL shader backend. [WARN] [GL]: Stock GLSL shaders will be used. [INFO] [GLSL]: Found GLSL vertex shader. [INFO] [GLSL]: Found GLSL fragment shader. [INFO] [GLSL]: Linking GLSL program. [INFO] [GLSL]: Found GLSL vertex shader. [INFO] [GLSL]: Found GLSL fragment shader. [INFO] [GLSL]: Linking GLSL program. [INFO] [GLSL]: Found GLSL vertex shader. [INFO] [GLSL]: Found GLSL fragment shader. [INFO] [GLSL]: Linking GLSL program. [INFO] [GL]: Using 4 textures. [INFO] [GL]: Loaded 1 program(s). [WARN] [udev]: Couldn't open any keyboard, mouse or touchpad. Are permissions set correctly for /dev/input/event*? [INFO] [udev]: Plugged pad: 8Bitdo SN30 Pro (11720:24833) on port #0. [INFO] [udev]: Pad #0 (/dev/input/event0) supports 0 force feedback effects. [INFO] [Joypad]: Found joypad driver: "udev". [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Video]: Found display server: null [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xsal-level2-crt.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xsal.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xScaleHQ.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_lanczos4.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_phosphor.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_snes.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/Brighter-with_Contrast.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/bsnes_gamma_ramp.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-curvature-vertical.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-curvature.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-vertical.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy-screen-grid.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy2.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/gba-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x&lcd3x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x2.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x_lcd3x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x_phosphor.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2xwaterpaint.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2xwaterpaintscanline.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq4x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq4x_lcd3x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/nds-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/nds.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/nedi.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/palm-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/phosphor.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/psp-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-2x-prescale.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-scanlines.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-simple.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes2.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpaint.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpainthicontrast.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpaintscanline.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_lcd3x.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_phosphor.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_scanline.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_waterpaint.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/stock.glsl" [INFO] Found shader "/home/pi/.config/retroarch/shaders/super-2xsai.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/super-eagle.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/vba-color.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/xbr-lv1-noblend.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_curve.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_curve_vertical.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_standard.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_standard_vertical.glslp" [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_lcd_standard.glslp" [INFO] [ALSA]: Using signed 16-bit format. [INFO] [ALSA]: Period size: 768 frames [INFO] [ALSA]: Buffer size: 3072 frames [INFO] [ALSA]: Can pause: no. [INFO] [Menu]: Found menu display driver: "gl". [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Menu]: Found menu display driver: "gl". [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [Font]: Using font rendering backend: stb-unicode. [INFO] [LED]: LED driver = 'null' 0x4b477c [INFO] [MIDI]: Initializing ... [INFO] [MIDI]: Input disabled. [INFO] [MIDI]: Output disabled. [INFO] [MIDI]: Initialized "alsa" driver. [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] [Environ]: SET_INPUT_DESCRIPTORS: [INFO] Loading history file: [/opt/retropie/configs/all/content_history.lpl]. [INFO] Loading history file: [/opt/retropie/configs/all/content_music_history.lpl]. [INFO] Loading history file: [/opt/retropie/configs/all/content_video_history.lpl]. [INFO] Loading history file: [/opt/retropie/configs/all/content_image_history.lpl]. [INFO] Loading favorites file: [/opt/retropie/configs/all/content_favorites.lpl]. [INFO] Written to playlist file: /opt/retropie/configs/all/content_history.lpl [libretro INFO] [MAME 2003+] options.nvram_bootstrap: 0 [libretro INFO] [MAME 2003+] Delegating population of initial NVRAM to emulated system. [libretro INFO] [MAME 2003+] Preparing emulated CPUs for execution. [libretro INFO] watchdog armed [INFO] [Environ]: SET_GEOMETRY. [INFO] [KMS]: New FB: 1680x1050 (stride: 6720). [INFO] [KMS]: New FB: 1680x1050 (stride: 6720). [INFO] [Cheats]: Save game-specific cheatfile: /home/pi/.config/retroarch/cheats/MAME 2003-Plus/journey.cht [INFO] Content ran for a total of: 00 hours, 00 minutes, 05 seconds. [INFO] Unloading game.. [INFO] Unloading core.. [INFO] Unloading core symbols.. [INFO] [Core Options]: Saved core options file to "/opt/retropie/configs/all/retroarch-core-options.cfg" [INFO] Threaded video stats: Frames pushed: 311, Frames dropped: 0.
@phoenixflood that looks much better.
