    daphne help [solved!]
    blank screendaphne gamesdaphne-log.txt
    17 Posts 3 Posters 2.7k Views
    • tarT
      tar
      2 part question here
      1. has to deal with dragons lair2.
        i get could not find framefile : /home/pi/RetroPie/roms/daphne/lair2.daphne/lair2.txt
        read daphne_log.txt.
        now i can find the log txt on my comp using daphne but can not find reference to it on the pi.. btw runs beautifully on the comp.
        ![alt text](Screenshot (1).png the txt seems correct to me . but i must be missing something
      2. deals with space ace
        im getting a blank screen when i hit anykey.. again works well on comp but not on the pi 4 yet.. i hear a sound bite and then just black screen..
        ![alt text](Screenshot (2).png image url)
        ive tried getting rid of the space the period that just gets failed messages....
        ive been reading for days and feel as if im just chasing my tail..maybe i could be lead in the right direction
        thank you very much in advance********bolded text**********```
        bolded text
      tarT 3 Replies Last reply Reply Quote 0
      • tarT
        tar @tar
        @tar roubleshooting
        If you have issues with black screen, try deleting the .dat file as it is generated the first time you parse the video files. If you transferred the .dat file from another system it may not work, so just leave the .dat file out.
        It is also case sensitive so if it's not working try making the extensions in the .daphne file lowercase.
        done all this.. as well
        • tarT
          tar @tar
          @tar ok i answered a good portion of this for myself. seems i had files in two seperate paths i had started to use a usb stick but daphne didnt load on it maybe once i put space ace on the sd chip all was good..
          still could use some help with finding the log txt .. getting that error on dragons lair 2..
          im sorrey if im not posting this correcdtly i am real new to this...and trying to learn
          thank you
            mitu Global Moderator @tar
            The daphne_log.txt file is in the $HOME/.daphne folder, you'll need to connect via SSH with WinSCP to read it.
            tarT 2 Replies Last reply Reply Quote 0
            • tarT
              tar @mitu
              @mitu thank you very much..
              lol something new to frustrate me ..this is to much fun
              https://www.reddit.com/r/RetroPie/comments/62hcg5/retropie_enable_ssh_and_how_to_use_winscp_to/
              again google is a friend
                @tar said in daphne help:
                Or you could have just followed the link I posted to the Docs which explain how to enable and use SSH...
                tarT 1 Reply Last reply Reply Quote 1
                • tarT
                  tar @mitu
                  @mitu yep sorry my brain did not wrap around that explanation as well guess i needed pictures lol
                  • tarT
                    tar @mitu
                    @mitu so that would be the folder where i am putting the lair.daphne and i find the rom folder under? . sorry if i am being a pain here
                      @tar Have you looked at the Docs ? It explains what is the expected folder/file structure for a Daphne game.
                      tarT 1 Reply Last reply Reply Quote 0
                      • tarT
                        tar @mitu
                        @mitu i found it been reading but jumping around on 50 diffrent things sorry about that
                        • tarT
                          tar @tar
                          @tar--DAPHNE version 1.0.13
                          code_text
                          ```--Command line is: /opt/retropie/emulators/daphne/daphne.bin lair2 vldp -nohwaccel -framefile /home/pi/RetroPie/roms/daphne/lair2.daphne/lair2.txt -homedir /opt/retropie/emulators/daphne -fullscreen
                          --CPU : UnknownCPU 0 MHz || Mem : 0 megs
                          --OS : Linux 5.4 || Video : Unknown video
                          --OpenGL: Compiled In
                          --RGB2YUV Function: C
                          --Line Blending Function: C
                          --Audio Mixing Function: C
                          Setting alternate home dir:
                          Set 640x480 at 16 bpp with flags: 20000020
                          Initializing sound system ...
                          Joystick #0 was successfully opened
                          Remapping input ...
                          Loading compressed ROM image dl2_319.bin...65536 bytes read.
                          Could not open framefile : /home/pi/RetroPie/roms/daphne/lair2.daphne/lair2.txt
                          Could not initialize laserdisc player!```
                          code_text
                          this is my txt file..
                          code_text
                          00001  dl2-00001.m2v
                          00002  dl2-00002.m2v
                          00721  dl2-00721.m2v
                          02102  dl2-02102.m2v
                          04427  dl2-04427.m2v
                          04477  dl2-04477.m2v
                          04527  dl2-04527.m2v
                          04577  dl2-04577.m2v
                          04627  dl2-04627.m2v
                          04677  dl2-04677.m2v
                          04727  dl2-04727.m2v
                          04777  dl2-04777.m2v
                          04827  dl2-04827.m2v
                          04877  dl2-04877.m2v
                          04927  dl2-04927.m2v
                          04977  dl2-04977.m2v
                          05027  dl2-05027.m2v
                          05077  dl2-05077.m2v
                          05127  dl2-05127.m2v
                          05177  dl2-05177.m2v
                          05227  dl2-05227.m2v
                          05277  dl2-05277.m2v
                          05327  dl2-05327.m2v
                          05377  dl2-05377.m2v
                          05427  dl2-05427.m2v
                          05477  dl2-05477.m2v
                          07707  dl2-07707.m2v
                          07757  dl2-07757.m2v
                          07807  dl2-07807.m2v
                          07857  dl2-07857.m2v
                          07907  dl2-07907.m2v
                          07957  dl2-07957.m2v
                          08007  dl2-08007.m2v
                          08057  dl2-08057.m2v
                          08107  dl2-08107.m2v
                          08157  dl2-08157.m2v
                          08207  dl2-08207.m2v
                          08257  dl2-08257.m2v
                          10486  dl2-10486.m2v
                          10536  dl2-10536.m2v
                          10586  dl2-10586.m2v
                          10636  dl2-10636.m2v
                          10686  dl2-10686.m2v
                          10736  dl2-10736.m2v
                          10786  dl2-10786.m2v
                          10836  dl2-10836.m2v
                          10886  dl2-10886.m2v
                          10936  dl2-10936.m2v
                          10986  dl2-10986.m2v
                          11036  dl2-11036.m2v
                          13473  dl2-13473.m2v
                          13523  dl2-13523.m2v
                          13573  dl2-13573.m2v
                          13623  dl2-13623.m2v
                          13673  dl2-13673.m2v
                          13723  dl2-13723.m2v
                          13773  dl2-13773.m2v
                          13823  dl2-13823.m2v
                          13873  dl2-13873.m2v
                          13923  dl2-13923.m2v
                          13973  dl2-13973.m2v
                          14023  dl2-14023.m2v
                          14073  dl2-14073.m2v
                          14123  dl2-14123.m2v
                          14183  dl2-14183.m2v
                          14233  dl2-14233.m2v
                          16670  dl2-16670.m2v
                          16720  dl2-16720.m2v
                          16770  dl2-16770.m2v
                          16820  dl2-16820.m2v
                          16870  dl2-16870.m2v
                          16920  dl2-16920.m2v
                          16970  dl2-16970.m2v
                          17020  dl2-17020.m2v
                          17070  dl2-17070.m2v
                          17120  dl2-17120.m2v
                          17170  dl2-17170.m2v
                          17220  dl2-17220.m2v
                          17270  dl2-17270.m2v
                          17320  dl2-17320.m2v
                          17380  dl2-17380.m2v
                          17430  dl2-17430.m2v
                          19860  dl2-19860.m2v
                          19910  dl2-19910.m2v
                          19960  dl2-19960.m2v
                          20005  dl2-20005.m2v
                          20055  dl2-20055.m2v
                          20105  dl2-20105.m2v
                          20155  dl2-20155.m2v
                          20205  dl2-20205.m2v
                          20275  dl2-20275.m2v
                          20325  dl2-20325.m2v
                          20385  dl2-20385.m2v
                          20435  dl2-20435.m2v
                          20480  dl2-20480.m2v
                          20530  dl2-20530.m2v
                          20590  dl2-20590.m2v
                          20640  dl2-20640.m2v
                          20690  dl2-20690.m2v
                          20740  dl2-20740.m2v
                          23170  dl2-23170.m2v
                          23220  dl2-23220.m2v
                          23270  dl2-23270.m2v
                          23315  dl2-23315.m2v
                          23365  dl2-23365.m2v
                          23415  dl2-23415.m2v
                          23465  dl2-23465.m2v
                          23515  dl2-23515.m2v
                          23585  dl2-23585.m2v
                          23635  dl2-23635.m2v
                          23695  dl2-23695.m2v
                          23745  dl2-23745.m2v
                          23790  dl2-23790.m2v
                          23840  dl2-23840.m2v
                          23900  dl2-23900.m2v
                          23949  dl2-23949.m2v
                          24000  dl2-24000.m2v
                          24050  dl2-24050.m2v
                          26650  dl2-26650.m2v
                          26700  dl2-26700.m2v
                          26750  dl2-26750.m2v
                          26800  dl2-26800.m2v
                          26850  dl2-26850.m2v
                          26900  dl2-26900.m2v
                          26950  dl2-26950.m2v
                          27000  dl2-27000.m2v
                          27050  dl2-27050.m2v
                          27100  dl2-27100.m2v
                          27150  dl2-27150.m2v
                          27200  dl2-27200.m2v
                          27250  dl2-27250.m2v
                          27300  dl2-27300.m2v
                          27350  dl2-27350.m2v
                          27400  dl2-27400.m2v
                          27450  dl2-27450.m2v
                          30050  dl2-30050.m2v
                          30100  dl2-30100.m2v
                          30150  dl2-30150.m2v
                          30200  dl2-30200.m2v
                          30250  dl2-30250.m2v
                          30300  dl2-30300.m2v
                          30350  dl2-30350.m2v
                          30400  dl2-30400.m2v
                          30450  dl2-30450.m2v
                          30500  dl2-30500.m2v
                          30550  dl2-30550.m2v
                          30600  dl2-30600.m2v
                          30650  dl2-30650.m2v
                          30700  dl2-30700.m2v
                          30750  dl2-30750.m2v
                          30800  dl2-30800.m2v
                          30850  dl2-30850.m2v
                          33559  dl2-33559.m2v
                          33609  dl2-33609.m2v
                          33659  dl2-33659.m2v
                          33709  dl2-33709.m2v
                          33759  dl2-33759.m2v
                          33809  dl2-33809.m2v
                          33859  dl2-33859.m2v
                          33909  dl2-33909.m2v
                          33959  dl2-33959.m2v
                          34009  dl2-34009.m2v
                          34059  dl2-34059.m2v
                          34109  dl2-34109.m2v
                          34159  dl2-34159.m2v
                          34209  dl2-34209.m2v
                          34259  dl2-34259.m2v
                          34309  dl2-34309.m2v
                          37019  dl2-37019.m2v
                          37069  dl2-37069.m2v
                          37119  dl2-37119.m2v
                          37169  dl2-37169.m2v
                          37219  dl2-37219.m2v
                          37269  dl2-37269.m2v
                          37319  dl2-37319.m2v
                          37369  dl2-37369.m2v
                          37419  dl2-37419.m2v
                          37469  dl2-37469.m2v
                          37519  dl2-37519.m2v
                          37569  dl2-37569.m2v
                          37619  dl2-37619.m2v
                          37669  dl2-37669.m2v
                          37719  dl2-37719.m2v
                          37769  dl2-37769.m2v
                          37770  dl2-37770.m2v
                          37773  dl2-37773.m2v
                          37776  dl2-37776.m2v
                          37779  dl2-37779.m2v
                          37782  dl2-37782.m2v
                          37784  dl2-37784.m2v
                          39433  dl2-39433.m2v
                          39493  dl2-39493.m2v
                          39543  dl2-39543.m2v
                          39593  dl2-39593.m2v
                          39643  dl2-39643.m2v
                          39693  dl2-39693.m2v
                          39743  dl2-39743.m2v
                          39793  dl2-39793.m2v
                          41443  dl2-41443.m2v
                          41503  dl2-41503.m2v
                          41553  dl2-41553.m2v
                          41603  dl2-41603.m2v
                          41653  dl2-41653.m2v
                          41703  dl2-41703.m2v
                          41753  dl2-41753.m2v
                          41803  dl2-41803.m2v
                          44157  dl2-44157.m2v
                          44207  dl2-44207.m2v
                          44257  dl2-44257.m2v
                          44307  dl2-44307.m2v
                          44357  dl2-44357.m2v
                          44427  dl2-44427.m2v ```
                          code_text
                          having a hard time seeing anything wrong?```
                          ClydeC 1 Reply Last reply Reply Quote 1
                            Your previous screenshots shows the framefile .txt file as dl2-framefile.txt, while the game looks for lair2.txt - are you sure you have the right filename and location ?
                              Clyde @tar
                              Just a little word of friendly advice. Please use code blocks for long listings, it makes them much more readible in the forums. Examples:
                              Remapping input ...
                              00001 dl2-00001.m2v
                              00002 dl2-00002.m2v
                              00721 dl2-00721.m2v
                              02102 dl2-02102.m2v
                              04427 dl2-04427.m2v
                              04477 dl2-04477.m2v
                              04527 dl2-04527.m2v
                              04577 dl2-04577.m2v
                              04627 dl2-04627.m2v
                              04677 dl2-04677.m2v
                              04727 dl2-04727.m2v
                              04777 dl2-04777.m2v
                              04827 dl2-04827.m2v
                              04877 dl2-04877.m2v
                              04927 dl2-04927.m2v
                              04977 dl2-04977.m2v
                              05027 dl2-05027.m2v
                              05077 dl2-05077.m2v
                              05127 dl2-05127.m2v
                              05177 dl2-05177.m2v
                              05227 dl2-05227.m2v
                              05277 dl2-05277.m2v
                              05327 dl2-05327.m2v
                              05377 dl2-05377.m2v
                              05427 dl2-05427.m2v
                              05477 dl2-05477.m2v
                              07707 dl2-07707.m2v
                              07757 dl2-07757.m2v
                              07807 dl2-07807.m2v
                              07857 dl2-07857.m2v
                              07907 dl2-07907.m2v
                              07957 dl2-07957.m2v
                              08007 dl2-08007.m2v
                              08057 dl2-08057.m2v
                              08107 dl2-08107.m2v
                              08157 dl2-08157.m2v
                              08207 dl2-08207.m2v
                              08257 dl2-08257.m2v
                              10486 dl2-10486.m2v
                              10536 dl2-10536.m2v
                              10586 dl2-10586.m2v
                              10636 dl2-10636.m2v
                              10686 dl2-10686.m2v
                              10736 dl2-10736.m2v
                              10786 dl2-10786.m2v
                              10836 dl2-10836.m2v
                              10886 dl2-10886.m2v
                              10936 dl2-10936.m2v
                              10986 dl2-10986.m2v
                              11036 dl2-11036.m2v
                              13473 dl2-13473.m2v
                              13523 dl2-13523.m2v
                              13573 dl2-13573.m2v
                              13623 dl2-13623.m2v
                              13673 dl2-13673.m2v
                              13723 dl2-13723.m2v
                              13773 dl2-13773.m2v
                              13823 dl2-13823.m2v
                              13873 dl2-13873.m2v
                              13923 dl2-13923.m2v
                              13973 dl2-13973.m2v
                              14023 dl2-14023.m2v
                              14073 dl2-14073.m2v
                              14123 dl2-14123.m2v
                              14183 dl2-14183.m2v
                              14233 dl2-14233.m2v
                              16670 dl2-16670.m2v
                              16720 dl2-16720.m2v
                              16770 dl2-16770.m2v
                              16820 dl2-16820.m2v
                              16870 dl2-16870.m2v
                              16920 dl2-16920.m2v
                              16970 dl2-16970.m2v
                              17020 dl2-17020.m2v
                              17070 dl2-17070.m2v
                              17120 dl2-17120.m2v
                              17170 dl2-17170.m2v
                              17220 dl2-17220.m2v
                              17270 dl2-17270.m2v
                              17320 dl2-17320.m2v
                              17380 dl2-17380.m2v
                              17430 dl2-17430.m2v
                              19860 dl2-19860.m2v
                              19910 dl2-19910.m2v
                              19960 dl2-19960.m2v
                              20005 dl2-20005.m2v
                              20055 dl2-20055.m2v
                              20105 dl2-20105.m2v
                              20155 dl2-20155.m2v
                              20205 dl2-20205.m2v
                              20275 dl2-20275.m2v
                              20325 dl2-20325.m2v
                              20385 dl2-20385.m2v
                              20435 dl2-20435.m2v
                              20480 dl2-20480.m2v
                              20530 dl2-20530.m2v
                              20590 dl2-20590.m2v
                              20640 dl2-20640.m2v
                              20690 dl2-20690.m2v
                              20740 dl2-20740.m2v
                              23170 dl2-23170.m2v
                              23220 dl2-23220.m2v
                              23270 dl2-23270.m2v
                              23315 dl2-23315.m2v
                              23365 dl2-23365.m2v
                              23415 dl2-23415.m2v
                              23465 dl2-23465.m2v
                              23515 dl2-23515.m2v
                              23585 dl2-23585.m2v
                              23635 dl2-23635.m2v
                              23695 dl2-23695.m2v
                              23745 dl2-23745.m2v
                              23790 dl2-23790.m2v
                              23840 dl2-23840.m2v
                              23900 dl2-23900.m2v
                              23949 dl2-23949.m2v
                              24000 dl2-24000.m2v
                              24050 dl2-24050.m2v
                              26650 dl2-26650.m2v
                              26700 dl2-26700.m2v
                              26750 dl2-26750.m2v
                              26800 dl2-26800.m2v
                              26850 dl2-26850.m2v
                              26900 dl2-26900.m2v
                              26950 dl2-26950.m2v
                              27000 dl2-27000.m2v
                              27050 dl2-27050.m2v
                              27100 dl2-27100.m2v
                              27150 dl2-27150.m2v
                              27200 dl2-27200.m2v
                              27250 dl2-27250.m2v
                              27300 dl2-27300.m2v
                              27350 dl2-27350.m2v
                              27400 dl2-27400.m2v
                              27450 dl2-27450.m2v
                              30050 dl2-30050.m2v
                              30100 dl2-30100.m2v
                              30150 dl2-30150.m2v
                              30200 dl2-30200.m2v
                              30250 dl2-30250.m2v
                              30300 dl2-30300.m2v
                              30350 dl2-30350.m2v
                              30400 dl2-30400.m2v
                              30450 dl2-30450.m2v
                              30500 dl2-30500.m2v
                              30550 dl2-30550.m2v
                              30600 dl2-30600.m2v
                              30650 dl2-30650.m2v
                              30700 dl2-30700.m2v
                              30750 dl2-30750.m2v
                              30800 dl2-30800.m2v
                              30850 dl2-30850.m2v
                              33559 dl2-33559.m2v
                              33609 dl2-33609.m2v
                              33659 dl2-33659.m2v
                              33709 dl2-33709.m2v
                              33759 dl2-33759.m2v
                              33809 dl2-33809.m2v
                              33859 dl2-33859.m2v
                              33909 dl2-33909.m2v
                              33959 dl2-33959.m2v
                              34009 dl2-34009.m2v
                              34059 dl2-34059.m2v
                              34109 dl2-34109.m2v
                              34159 dl2-34159.m2v
                              34209 dl2-34209.m2v
                              34259 dl2-34259.m2v
                              34309 dl2-34309.m2v
                              37019 dl2-37019.m2v
                              37069 dl2-37069.m2v
                              37119 dl2-37119.m2v
                              37169 dl2-37169.m2v
                              37219 dl2-37219.m2v
                              37269 dl2-37269.m2v
                              37319 dl2-37319.m2v
                              37369 dl2-37369.m2v
                              37419 dl2-37419.m2v
                              37469 dl2-37469.m2v
                              37519 dl2-37519.m2v
                              37569 dl2-37569.m2v
                              37619 dl2-37619.m2v
                              37669 dl2-37669.m2v
                              37719 dl2-37719.m2v
                              37769 dl2-37769.m2v
                              37770 dl2-37770.m2v
                              37773 dl2-37773.m2v
                              37776 dl2-37776.m2v
                              37779 dl2-37779.m2v
                              37782 dl2-37782.m2v
                              37784 dl2-37784.m2v
                              39433 dl2-39433.m2v
                              39493 dl2-39493.m2v
                              39543 dl2-39543.m2v
                              39593 dl2-39593.m2v
                              39643 dl2-39643.m2v
                              39693 dl2-39693.m2v
                              39743 dl2-39743.m2v
                              39793 dl2-39793.m2v
                              41443 dl2-41443.m2v
                              41503 dl2-41503.m2v
                              41553 dl2-41553.m2v
                              41603 dl2-41603.m2v
                              41653 dl2-41653.m2v
                              41703 dl2-41703.m2v
                              41753 dl2-41753.m2v
                              41803 dl2-41803.m2v
                              44157 dl2-44157.m2v
                              44207 dl2-44207.m2v
                              44257 dl2-44257.m2v
                              44307 dl2-44307.m2v
                              44357 dl2-44357.m2v
                              44427 dl2-44427.m2v
                              • tarT
                                tar @mitu
                                @mitu god i hope thats it ive been reading things all over and tail chasing.. ill give it a try..im trying to make a trilogy cab wouldnt be much of 1 with just the 2.
                                so to make sure im understanfing you suggest the txt file needs renamed.. then would i have to rename all the files as will the m2v and ogg?
                                • tarT
                                  tar
                                  thank you clysde will do my best to learn that next..
                                  just a carpenter trying to take up a diffrent hobby
                                    No, they shouldn't - just the .txt file.
                                    • tarT
                                      tar @mitu
                                      @mitu ok so here is what i found to be my problem..
                                      i thought i could just rename the file right click rename.
                                      to fix i opened file in notepad and save as.. lair2.txt...
                                      just so if there are others that dont get it like me
                                      lol
                                      thank you ever so much..
                                      now i can move on to the rest of the fun
