    (SOLVED) MAME "standalone" Cheats for systems like Coleco, Arcade and more
    cheatslr-messmamemame rommame.ini
    29 Posts 3 Posters 11.2k Views
    • DTEAMD
      DTEAM
      Hi,
      I am starting to use MAME "standalone" as a replacement for lr-Mess for some systems like ColecoVision or Super Vision. I'm trying to run cheat codes with the package of Pugsy's Cheats
      I'm not able to activate those Cheats in MAME. All tutorials I found are for Windows, MAC or Linux on PC.
      Does anyone know how to do this?
      Regards
        dankcushions Global Moderator @DTEAM
        @dteam i believe it should work much the same way on retropie as anywhere.
        mame.ini and mame folder structure is in /opt/retropie/configs/mame/
        i believe you need to enable cheats in the .ini, and then unzip the cheat archive to the above directory.
        • DTEAMD
          DTEAM @dankcushions
          @dankcushions
          What I did for now is adding cheat 1 and cheatpath /home/pi/RetroPie/roms/mame/cheat in mame.ini and paste cheat.7z and unzipped jagar cheat folder in /home/pi/RetroPie/roms/mame/cheat and It doesn't work. I'll try what you are suggesting.
          Note: MAME naming match for this test.
          rompath /home/pi/RetroPie/roms/mame;/home/pi/RetroPie/roms/arcade;/home/pi/RetroPie/BIOS/mame;/home/pi/RetroPie/BIOS;/home/pi/RetroPie/roms/tigerh;/home/pi/RetroPie/roms/gameandwatch;/home/pi/RetroPie/roms/tigerrz;/home/pi/RetroPie/roms/pong;/home/pi/RetroPie/roms/konamih;/home/pi/RetroPie/roms/classich;/home/pi/RetroPie/roms/atomiswave;/home/pi/RetroPie/roms/naomi;/home/pi/RetroPie/roms/all_in1;/home/pi/RetroPie/roms/jakks;/home/pi/RetroPie/roms/all_in1;/home/pi/RetroPie/roms/gp32;/home/pi/RetroPie/roms/nes
          hashpath /opt/retropie/emulators/mame/hash
          samplepath /home/pi/RetroPie/roms/mame/samples;/home/pi/RetroPie/roms/arcade/samples
          artpath /home/pi/RetroPie/roms/mame/artwork;/home/pi/RetroPie/roms/arcade/artwork;/home/pi/RetroPie/BIOS/mame/artwork
          ctrlrpath /opt/retropie/emulators/mame/ctrlr
          pluginspath /opt/retropie/emulators/mame/plugins
          languagepath /opt/retropie/emulators/mame/language
          cfg_directory /home/pi/RetroPie/roms/mame/cfg
          nvram_directory /home/pi/RetroPie/roms/mame/nvram
          input_directory /home/pi/RetroPie/roms/mame/inp
          state_directory /home/pi/RetroPie/roms/mame/sta
          snapshot_directory /home/pi/RetroPie/roms/mame/snap
          diff_directory /home/pi/RetroPie/roms/mame/diff
          comment_directory /home/pi/RetroPie/roms/mame/comments
          skip_gameinfo 1
          plugin hiscore
          samplerate 44100
          video accel
          cheat 1
          New edit
          Now, I think It sees the cheat codes, but this message appear:
          see also: Mess cheats
          New edit 2
          however, this setup works with Arcade system (MAME standalone). I kept cheat.7z zipped
          I'm reading posts on this forum to found a solution... will see : http://www.mamecheat.co.uk/forums/viewforum.php?f=2
          • DTEAMD
            DTEAM @DTEAM
            @Folly
            See above, any idea? It works with MAME (Arcade) but not MAME (MESS). On http://www.mamecheat.co.uk/forums/viewforum.php?f=2, they are able to run those systems.
            New edit:
            I also found this: https://docs.mamedev.org/advanced/paths.html
            • FollyF
              Folly @DTEAM
              @dteam said in MAME "standalone" Cheats for systems like Coleco and more:
              @Folly
              Nice work, getting cheats to work.
              I have never used cheats.
              Reading the posts I got a bit confused about what you mean by:
              Now I think I know what you mean.
              You mean :
              • systems that were in MESS and which are now merged/added into MAME, don't work.
              • systems that were already in MAME (Arcade) before the merge with MESS, do work.
              But with both systems (your edit1 and edit2) your cheats are in the same way added, right ?
              So I think I understand it correctly now.
              Looks like the picture from edit1 asks for a softwarelist with games.
              Seems like you run the system and game with a command-line just like we did earlier.
              Did you add the (-c) or (-cheat) option in the commandline ?
              Looks like the picture from edit2 uses a softwarelist with games.
              So it looks like it get's information from the softwarelist in order to run the cheat.
              Then I think the (-c) option doesn't have to be used.
              I don't know If I am correct in this thinking though ;-) .
              Did you check your runcommand.logs and generated commandlines both times ?
              • DTEAMD
                DTEAM
                @folly said in MAME "standalone" Cheats for systems like Coleco and more:
                You mean :
                systems that were in MESS and which are now merged/added into MAME, don't work. - YES
                systems that were already in MAME (Arcade) before the merge with MESS, do work. - YES
                But with both systems (your edit1 and edit2) your cheats are in the same way added, right ? YES
                Yes , I tried It with Jaguar and nothing happened
                emulators.cfg
                mame-jaguar= "/opt/retropie/emulators/mame/mame -c -autoframeskip -cheat jaguar -cart %ROM%"
                Note: roms with MAME naming for the test
                • FollyF
                  Folly @DTEAM
                  @dteam
                  What is the other emulators.cfg ?
                  • DTEAMD
                    DTEAM @Folly
                    @folly
                    mame-jaguar= "/opt/retropie/emulators/mame/mame -c -autoframeskip jaguar -cart %ROM%"
                    With or without -cheat, It runs the same way with the mame.ini above.
                    • FollyF
                      Folly @DTEAM
                      @folly
                      Now I am confused.
                      Do you use jaguar both times, one that works and one that doesn't work ?
                      Or which Arcade system did you used then ?
                      • DTEAMD
                        DTEAM @Folly
                        @folly
                        No sorry, for Arcade and jaguar, I did nothing excepted what you see above with mame.ini and cheat.7z file location.
                        for -cheat in emulators.cfg , I did a test with jaguar and nothing happens. mame.ini seems to do the same thing.
                        For some reason, we can load cheats for arcade games (MAME) and not for systems from the old MESS
                        • FollyF
                          Folly @DTEAM
                          @folly
                          Ok I understand it correctly.
                          What is your emulators.cfg of Arcade then ?
                          • DTEAMD
                            DTEAM @Folly
                            @folly
                            those 2
                            mame_autoframeskip = "/opt/retropie/emulators/mame/mame -c -autoframeskip %BASENAME%"
                            mame = "/opt/retropie/emulators/mame/mame %BASENAME%"
                            • FollyF
                              Folly @DTEAM
                              @folly
                              those 2
                              Yes, just what I was thinking/explaining in my earlier post.
                              Your edit1 doesn't run through the softwarelist and your edit2 does.
                              In both (Arcade and jaguar) you use MAME naming, as you said,
                              but with jaguar you added the system in the commandline so the MAME naming for the softwarelist is not used/rejected.
                              So the question is, do cheats only work when a game is loaded the softwarelist way.
                              Pfff... do you follow it ?
                              Can you try your jaguar game (with MAME naming) from the Arcade rom directory, to see what will happen ?
                              Perhaps you also have to add a hash table for jaguar too in you mame directory.
                              Here are hash tables :
                              https://github.com/mamedev/mame/tree/master/hash
                              • DTEAMD
                                DTEAM @Folly
                                @folly
                                Not working. In mame.ini , It already pointed in the hash folder with xml. The xml. are already there.
                                • FollyF
                                  Folly @DTEAM
                                  @folly
                                  Not working.
                                  Do you have hash tables ?
                                  I think the have to be in :
                                  /home/pi/RetroPie/BIOS/mame/hash
                                  • DTEAMD
                                    DTEAM @Folly
                                    @folly
                                    Yes, and in 2 places (lr-Mess and MAME) . For mame, It's in the mame.ini and Its full by default, unlike Lr-Mess
                                    My hashpath
                                    /opt/retropie/emulators/mame/hash;
                                    /home/pi/RetroPie/BIOS/mame/hash;
                                    FollyF DTEAMD 2 Replies Last reply Reply Quote 0
                                    • FollyF
                                      Folly @DTEAM
                                      @dteam
                                      And you have the jaguar.xml in there ?
                                      • DTEAMD
                                        DTEAM @DTEAM
                                        @dteam
                                        What %BASENAME% doing
                                        Can we use it in
                                        with jaguar
                                        • FollyF
                                          Folly @DTEAM
                                          @dteam
                                          I am quite certain basename is the romname without the extension.
                                          So the basename is looked up in the hash tables then it knows the :
                                          • game
                                          • system
                                          • etc.
                                          • DTEAMD
                                            DTEAM @Folly
                                            @folly
                                            yes, jaguar.xml is there
                                            Before I use your script, I installed Lr-Mess systems manually with .xml files.
                                            I'm running both. I'm familiar with It.
