    Fix for PC Engine CD CHD files not working
    chdpc enginebeetle-pce-fastturbografx
    8 Posts 2 Posters 3.7k Views
      RVA-818X-LAYstar
      There seems to be an error on the DOCS page for PC Engine https://retropie.org.uk/docs/PC-Engine/
      I had a long difficult time trying to get my CHD files to work.
      First:
      1. I tested that my CHDs files were good on Retroarch on my PC - A-OK - no problems, ran fine.
      The problem was that lr-beetle-pce-fast apparently wants a BIOS file inside the directory where the CHD file is.
      The DOCS page https://retropie.org.uk/docs/PC-Engine/ says you need to place the BIOS file in /home/pi/RetroPie/BIOS
      However, in my testing I've found this to be incorrect. Whilst it works for .cue .bin files, it won't work for CHD files.
      The solution is to place a BIOS file (e.g. syscard3.pce) inside the same directory as your CHD ROM file.
      Hope that helps some people.
        mitu Global Moderator @RVA-818X-LAYstar
        @rva-818x-laystar Post a verbose log please - if that's the case, then it may be an upstream bug.
          RVA-818X-LAYstar @mitu
          sorry just a quick question, should it be a verbose log before I added the bios to the ROM directory, or after?
            The log should contain the error, so before you added the BIOS to the pcenginecd folder.
              @mitu Here's the pastebin: https://pastebin.com/mcGAEueC
              Not sure why but it can't find the BIOS when loading a CHD and this seems to be the critical line from the log:
              [WARN] SYSTEM DIR is empty, assume CONTENT DIR /home/pi/RetroPie/roms/pcengine/test/Fantastic Night Dreams - Cotton (USA).chd
              So I add the BIOS to the directory where the CHD files are.
                @rva-818x-laystar said in Fix for PC Engine CD CHD files not working:
                This means you've reset your configuration from RetroPie's default - which sets SYSTEM_DIR to the RetroPie's BIOS folder.
                  RVA-818X-LAYstar
                  Well, hell. I have no idea how that happened. But you seem to be right.
                  I checked my /opt/retropie/configs/pcengine/retroarch.cfg
                  and it has this line:
                  system_directory = "default"
                  If this is wrong, how would I fix it?
                  change it to:
                  system_directory = "/home/pi/RetroPie/BIOS"
                    @rva-818x-laystar Don't use 'Reset' from RetroArch's menu, since it will disable any configuration done by RetroPie - including the BIOS folder used as 'System Dir'.
                    Rename the retroarch.cfg file from the pcengine folder or delete it, then re-install the emulator before starting any PCEngine games. Re-installation will re-generate the RetroPie's default configuration for pcengine.
