    Rasp Pi 4 8GB will not boot from Retropie SD card
    start4
    27 Posts 2 Posters 7.7k Views
    • Honda Z50MH
      Honda Z50M
      My Raspberry Pi 4 8GB will not boot from my Retropie SD card (SD card works in a Pi4 4GB)
      The Pi 4 8GB will bot ok from the SD card that came with it.
      Using the bootable card I did the usual apt update/full-upgrade because error mentioned board needs newer software as well as Strt4.elf not compatible but still the same issue an error message (see attached)![0_1612857662297_20210208_230726b.jpg](Uploading 100%)
      Would it work if I copied the start4.elf file from working card to card that won't boot?
        mitu Global Moderator @Honda Z50M
        @honda-z50m The recommended approach is to run a full upgrade from the system that works, so that both kernel and firmware are up-to-date, then use the card on the 8Gb system.
        Honda Z50MH 1 Reply Last reply Reply Quote 0
        • Honda Z50MH
          Honda Z50M @mitu
          @mitu I did that already assuming that sudo apt-get update followed by sudo apt-get full-upgrade is what I needed to do.
          Tom
            @honda-z50m Yes, that should update the firmware, including the start4.elf file. When did you run the update ?
            • Honda Z50MH
              Honda Z50M @mitu
              @mitu Just before taking the screen shot (rebooted after update)using the SD card that boots ok.
              Then inserted Retropie card and still got same error as per screenshot.
                @honda-z50m said in Rasp Pi 4 8GB will not boot from Retropie SD card:
                My fully updated system shows different values for the start4.elf file:
                • size 2227200
                • hash: b9a4da9e63f3e18fc0256e6fca6232f6
                What's the output of dpkg -l | grep raspberrypi-bootloader ?
                Is the RetroPie 4.7.1 image booting on the 8Gb system ?
                • Honda Z50MH
                  Honda Z50M @mitu
                  @mitu But surely the start4.elf file and other files stored on the sd card will only be updated on the card that's inserted at the time of update?
                  At the moment Retropie card will not boot as per screenshot so no.
                  So could I just copy required files from good card to Retropie card?
                  What's the output of dpkg -l | grep raspberrypi-bootloader ? Using good card I assume?
                    Maybe you misunderstood my reply - run the upgrade on the system that works (i.e. the non-8Gb Pi) to ensure you have the latest version of kernel/firmware on the sdcard, before using the sdcard on the new 8Gb system.
                    • Honda Z50MH
                      Honda Z50M @mitu
                      @mitu Ok but unfortunately can't do that as I no longer have that Pi (Pi 4 4GB)
                      I know someone who has one so inquiries made to them for their help.
                        In this case, you can try using copying the newer start4.elf and fixup4.dat from the working sdcard to your existing RetroPie install and boot from it. If it works, run again an update/upgrade to get the latest firmware and kernel.
                        Honda Z50MH 2 Replies Last reply Reply Quote 0
                        • Honda Z50MH
                          Honda Z50M @mitu
                          @mitu ok I'll try that this evening.
                          Thanks for your advice thus far
                          • Honda Z50MH
                            Honda Z50M @mitu
                            @mitu Copied those files over and now boots up BUT Emulation station does not detect anything not even a keyboard so I can' get past that to do the update
                              @honda-z50m Use SSH to connect and run the update.
                              • Honda Z50MH
                                Honda Z50M @mitu
                                @mitu Over ethernet?
                                How do I find Pi's IP address?
                                  If you don't have WiFi, yes.
                                  It's right in the RetroPie's menus, though you can just use the name (retropie or retropie.local) instead.
                                  • Honda Z50MH
                                    Honda Z50M @mitu
                                    @mitu ok won't be able to access wifi with PI as I can't type password in etc.
                                    • Honda Z50MH
                                      Honda Z50M @mitu
                                      @mitu ok I'm in
                                      How do I update?
                                        How do I update?
                                        With the same commands as before - using apt.
                                        • Honda Z50MH
                                          Honda Z50M @mitu
                                          @mitu ok I'm using winscp and all I have at the moment is the root directory how do I open the pi terminal?
                                            @honda-z50m Doesn't Commands > Open Terminal get your a command prompt ?
                                            Honda Z50MH 3 Replies Last reply Reply Quote 0
