    Changing resolution for retropie + emulationstation - typical stuff not working
    emulatorstationresolution
    3 Posts 2 Posters 785 Views
      RobotGuyInPA
      Hello,
      I'm running RetroPie 4.7 on a R-PI 4b, connected to a Sony Bravia X900H 4K TV.
      Currently, everything boots into 4K, which makes emulation slow. If I reduce emulator-specific resolution (i.e, for N64), it ends up using only a small portion of the screen.
      Trying to change resolution using raspi-config doesn't work. When I try, it never shows resolution selections, and dumps me back into the menu.
      I can change boot resolution via boot/config.txt successfully using hdmi_group + hdmi_mode. BUT, that doesn't change the resolution that emulationstation boots into - it'll still boot into 4K menus even if my screen is now 1280x720.
      I know I can use --resolution 1280 720 with emulationstation invocation to change resolution, and that works - but for the life of me I can't figure out how to have that automatically happen. I've looked at scripts in /usr/bin/emulationstation and /opt/retropie/supplementary/emulationstation - and added the --resolution flags where I see invocations of emulationstation, with no luck.
      Is there a better way to do this? Most of my googling has turned up using raspi-config, but that's just not working.
      Thanks much for any help.
        You can try to filter out the 4k video modes by adding to the /boot/config.txt
        hdmi_max_pixel_freq:0=200000000
        hdmi_max_pixel_freq:1=200000000
        For the EmulationStation resolution approach, the start command is in /opt/retropie/configs/all/autostart.sh - you can modify it and add the --resolution parameter there.
          RobotGuyInPA @mitu
          @mitu Ahh thank you! I was trying to find where the autostart command was - but was looking in /home/pi in .bashrc, etc... I'll try one of those two solutions. Thanks again!
