    2.3k Posts 37 Posters 9.1m Views
    • FollyF
      Folly @DTEAM
      @dteam
      Finished!
      With added zoomed display and back drop shadow !
      https://www91.zippyshare.com/v/YBEC4tim/file.html
      • DTEAMD
        DTEAM @Folly
        @folly
        Do you have pictures of your final result!
        • FollyF
          Folly @DTEAM
          @dteam
          2021-09-16-224833_800x600_scrot-resized.png 2021-09-16-224617_800x600_scrot-resized.png
          • DTEAMD
            DTEAM
            @folly
            Very nice!!! Do you like the drop shadow effect? I think it gives a realistic touch
            • FollyF
              Folly @DTEAM
              @dteam
              Yes I do ! , it gives just that touch ;-)
              Shall we replace it on google drive ?
              DTEAMD 2 Replies Last reply Reply Quote 0
              • DTEAMD
                DTEAM @Folly
                @folly
                Yes, I'll do it
                • DTEAMD
                  DTEAM @Folly
                  Done!
                  • FollyF
                    Folly @DTEAM
                    Done!
                    Perfect.
                    We should test if the old file is going to be updated.
                    I think it has to be removed first.
                    That could be an issue.
                    Edit :
                    I tested it and the file wasn't updated.
                    I added the issue on github :
                    https://github.com/matthuisman/gdrivedl/issues/19
                    • FollyF
                      Folly @DTEAM
                      @dteam
                      I would like you to add the artwork for videopin for mame .
                      It's described here :
                      https://retropie.org.uk/forum/topic/31255/atari-video-pinball-backdrop
                      Artwork :
                      https://www92.zippyshare.com/v/9Gp7lzW5/file.html
                      It comes from "mame202artworkall".
                      Perhaps there is more, in there, that can be added.
                      Though, for lr-mess there isn't a solution yet.
                      • DTEAMD
                        DTEAM @Folly
                        @folly
                        I found this for Backdrop
                        https://retropie.org.uk/forum/topic/22306/update-docs-for-lr-mame2003-plus-artwork-backdrops-bezels/8?_=1631895075858
                        See: two last post
                        • FollyF
                          Folly @DTEAM
                          @dteam
                          Thanks,
                          Looked at the links but could not find a videopin backdrop overlay.
                          • DTEAMD
                            DTEAM @Folly
                            @folly
                            For Google Drive issues, would it be easier if I put everything on GitHub?
                            • FollyF
                              Folly @DTEAM
                              @folly
                              Let's wait for Matt first, perhaps he can improve his script.
                              But indeed github could be a better way in the long run.
                              There are some advantages like :
                              • forking
                              • easy collaborating
                              • perhaps skipping files when cloning for an update
                              But there could also be some downsides :
                              • how much data will we have in the future and what is the data-limit of github ?
                              • I think cloning doesn't work when we add files manual locally because it wants to sync with the repository. So testing files on the harddrive becomes more difficult.
                              • Perhaps we also face some ownership issues
                              We can do some tests with a few files and see how it works.
                              • FollyF
                                Folly @DTEAM
                                @dteam
                                Matt changed his script and added the option -m or --mtimes.
                                link
                                I added this in my script (not on github yet).
                                It's downloading all again now, just as Matt explained.
                                When I am ready we have to change 1 file and revert it back to test if this solution works.
                                Edit:
                                It has downloaded now.
                                Tried to download everything again and now it said that the files exist.
                                Looking good, so far !
                                So now you can throw in an different file with the same name and I can test if it's working.
                                For example, you could place your old pofo.zip back for a while.
                                If you want to test it also, use this line (1058) with the added -m :
                                python3 - https://drive.google.com/drive/folders/$1 -m -P "$2"
                                • DTEAMD
                                  DTEAM @Folly
                                  It seems to work well!
                                  • FollyF
                                    Folly @DTEAM
                                    @dteam
                                    Can you put in a file for me so I can test it too ?
                                    Can you put first a dummy "videopin.zip" onto the google drive ?
                                    And after I acknowledge, the real one ?
                                    • DTEAMD
                                      DTEAM @Folly
                                      @folly
                                      I put an arcade "artwork"
                                      look for berzerk.zip
                                      • FollyF
                                        Folly @DTEAM
                                        @dteam
                                        Got it.
                                        You can now update berzerk
                                        • DTEAMD
                                          DTEAM @Folly
                                          @folly
                                          Done, I replaced them by a dummy
                                          • FollyF
                                            Folly @DTEAM
                                            @dteam
                                            Too bad, the file isn't updated.
                                            It could depend on the time difference.
                                            Perhaps it's a good idea to leave the file on google drive, so I can test tomorrow again.
                                            Good idea ?
