    • ByteThisB
      ByteThis @JimmyFromTheBay
      @JimmyFromTheBay said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
      @ByteThis Making 256GB diskimages is an extremely non-trivial task. It bedblocks my computer for days at a time. I think I'm actually going to buy an RPi 5 and make a fresh start on that, seems like a good time
      I suppose that is the disadvantage of having a larger card, I use a 128GB card and to make a backup takes around 3hrs.
        bbilford83 @ByteThis
        @Folly sorry I have been gone for so long! I went back to my pi for the first time in forever today and was going to test out what you asked me to, but first I went to add in a new translation I found for FM Towns Marty, and I discovered that for some reason none of my cd-rom based games are working there anymore. After it didn't work I updated your script to the newest version and it installed a bunch of dependencies, but it didn't fix the issue. I'm getting the following in the runcommand whenever I load a CD-based game, at least in fmtmarty:
        /opt/retropie/supplementary/runcommand/runcommand.sh: line 1331: 1495 Bus error
        I know it was working fine just a couple of months or so ago, so I'm not sure what would've changed
        I tried Cameltry (maybe you remember you helped with that weird error on that one) because it is disk-only, and it is still working. So it isn't the FMT Marty system. And all the rom-based systems are still working fine. So it must be something with the CD drive games. Any ideas?
        Edit: I see now the same is true for my CD-i and VIS games. So it seems it is all CD games with the script? If I missed some update/problem while disconnected all this time, my apologies!
        • FollyF
          Folly @bbilford83
          @bbilford83
          Welcome back!
          Looks like you are using a binary that can't cope with CHD files.
          It's most likely not due to my script.
          There was an issue a couple of months ago if you can remember, see here :
          https://retropie.org.uk/forum/topic/35240/solved-mame-and-lr-mess-issues-with-chd-files-1590-bus-error
          What versions/binary are you using ?
          Could be the one I patched for fmtmarty not showing the annoying message.
          If so that could be one that also has that CHD issue.
          If you have installed from source did you have the latest RetroPie-Setup scripts installed ?
            bbilford83 @Folly
            @Folly Thank you! I didn't update anything except your script, but that's interesting about the retropie_setup script. I missed whatever happened a couple months ago, probably I was still in Japan.
            That didn't seem to fix anything, you think I should now update lr-mame/mame too? It is a shame to lose your cameltry fix and I think you had made something else work too! But c'est la vie.
            Edit: Yes I am definitely still using your patched version, I see now more clearly you are saying that had a chd issue. Updating now!
            Edit2: That fixed it!! Thank you. How strange it broke without doing any updating. I will add my towns game and then get to your request this weekend, I promise.
            • FollyF
              Folly @bbilford83
              You could copy that binary to a different location and use that one only for fmtmarty for the time being.
              Basically I should add an issue to https://github.com/mamedev/mame.
              Haven't done that because I have so much other stuff to do.
              Though I might see if I will.
              I am also seeing if I can make some good sub-target filters for for creating lr-mame/lr-mess with a proper set of drivers.
              That is something that basically has to be reported to https://github.com/libretro/mame .
              • FollyF
                Folly @bbilford83
                I also added clone detection when downloading from the restricted.
                There are a lot of clones in the lists/database of the handhelds and also in the ones used for realistic overlays.
                Clones are not separate roms but are within the main roms.
                For example gnw_egg is a clone of gnw_mmouse and ngnw_dkcirc is a clone of gnw_mmousep.
                Getting the original main file and renaming it to the clone name will give the proper rom or at least it will load properly while the name is linked to the hash tables when loading with basename runcommands.
                So downloading the main and renaming to the clone is what I have automated in the script.
                  bbilford83 @Folly
                  @DTEAM @bbilford83 ,
                  I changed and added quite some stuff in 264.05.
                  Would like to ask you both to test the stuff.
                  Particularly the part switching between database versions and the coleco sgm module part.
                  For the database part there seemed to be an issue that I never saw before, like many wrong numbers in the dialog box.
                  Tested all the code and added the unset IFS command.
                  It looks like it's ok again.
                  For coleco the sgm module will be added by default now when the database is higher than 0264.
                  I tested some roms that work with and without sgm module and both seemed to work when the sgm module was inserted.
                  Still the new 0265 database isn't there yet so if you want to test then you have to change line 1908 into :
                  [[ ${systems[-1]} == coleco ]] && [[ $(expr $rp_module_version_mame + 0) -gt 263 ]] && ExtraPredefinedOptions+=( "-exp sgm" )
                  ( so you will be able to use it with database 0264 )
                  I also like to know what you both find about the idea that the standard coleco install has the sgm module as we separated this in the past to a coleco_sgm install.
                  Seems to me that this is the easiest solution.
                  However, we might need to change the theme for coleco but lets discuss that later.
                  For the other restricted parts we can't talk about that much, but I would like to hear if you could figure it out how it works and if it works for you both.
                  Remember there are rompacks that are too big for using the added options.
                  I still need to add that advise/info in the variable of the form for get_all.
                  A good start is MSX and MSX2.
                  P.S .
                  I see that I might need to add sgm for colecop too.
                  Hi @Folly. I have read this through and honestly I had never heard of the "Super Game Module" for Colecovision, only read about it when I searched to see what SGM is. If I understand right, it would have improved the graphics on a bunch of arcade ports to make them closer to arcade quality, right? If it were me, I do think I would probably try to keep them as separate installs. I no doubt would want to play all the games that could be enhanced with SGM with those enhancements, but I bet at least some people would want to have the option if only to see what the difference would look like. Just my two cents though.
                  I don't understand what you mean about the other restricted parts that we can't talk about though, sorry!
                  • FollyF
                    Folly @bbilford83
                    Earlier I was thinking that it was too difficult but I managed it :
                    https://github.com/FollyMaddy/RetroPie-Share/commit/baa8f8ad89c5ff9d8b4910cbeb2c8ee379ac1e16
                    The description in the commit should explain it all.
                    I think it's indeed better to split it that way you can put the non-sgm games in the folder coleco and the sgm ones in coleco_sgm just like we did earlier on.
                    Now the themes also don't have to be changed if the have both coleco and coleco_sgm in them.
                    I think @DTEAM will also agree that this is a better solution.
                    Right @DTEAM ?
                    Remember that the mame versions from 0265 and above only work if you have Bookworm OS running.
                    B DTEAMD 2 Replies Last reply Reply Quote 1
                    • FollyF
                      Folly @bbilford83
                      Would like to ask you to test the stuff.
                      You don't have to test this part.
                      I still experience the issue.
                      Sometimes good versions are shown and sometimes not.
                      I am trying to come up with a better solution but will take a while.
                        bbilford83 @Folly
                        @Folly everything you said makes sense, though I agree that's odd about the databases.
                        I somehow entirely missed this. I see that .265 was released in late april but when I updated to mame/lr-mame/lr-mess yesterday I see now it only updated me to .264. I guess that is because it RetroPie-Setup somehow knows I'm not on an OS that can handle .265? What a bummer. I see the exchanges you had with @JimmyFromTheBay about how we'd have to set up a new SD card to get it running off Bookworm. I guess I will treat this as a "stopping point" for my pi4 image and start anew for my pi5 one once retropie/emulationstation is working smoothly on it.
                        • FollyF
                          Folly @bbilford83
                          Have fixed the issue with the database list, read here.
                          • DTEAMD
                            DTEAM @Folly
                            Right @DTEAM ?
                            Yes, it's a good solutions.
                            If you want me to change the theme name, I can do that too. In MAME they are named coleco_sgm = coleco_homebrew. Initially, the theme was created for fbneo
                            • FollyF
                              Folly @DTEAM
                              @DTEAM
                              Thanks !
                              I saw indeed the name coleco_homebrew.
                              Personally I find coleco_sgm a better name.
                              Not entirely sure but I think not all homebrews make use of sgm.
                              Would have to look into the hash table for that.
                              Edit :
                              If needed you could make a duplicate.
                              DTEAMD FollyF 3 Replies Last reply Reply Quote 0
                              • DTEAMD
                                DTEAM @Folly
                                Edit :
                                sure
                                • FollyF
                                  Folly @DTEAM
                                  Just updated the script so psions can be installed properly.
                                  For more info see here.
                                  Drivers still need to be tested though.
                                  • FollyF
                                    Folly @Folly
                                    @DTEAM
                                    Just had a look at coleco_homebrew.xml.
                                    There are also many non-sgm games in them, so not for sgm only.
                                    • DTEAMD
                                      DTEAM @Folly
                                      Edit :
                                      done!
                                      • FollyF
                                        Folly @DTEAM
                                        @DTEAM
                                        What is your opinion about the names ?
                                        coleco_sgm vs coleco_homebrew
                                        Do you think I should change it in the script ?
                                        Btw :
                                        Are you up to date so you can run mame 265 ?
                                        Edit :
                                        No reply from you but I decided to change coleco_sgm into coleco_homebrew.
                                        I think it's better overall.
                                        See commit.
                                        • DTEAMD
                                          DTEAM @Folly
                                          Btw :
                                          No, I didn't download it from the source. I'm waiting for the precompiled one.
                                          • FollyF Folly referenced this topic on
                                          • FollyF
                                            Folly @DTEAM
                                            @DTEAM @bbilford83
                                            I have added standalone mame version detection 265.17.
                                            So the database will be more in sync with mame.
                                            Can you both test it and let me know if you find this an improvement.
