    2.3k Posts 37 Posters 9.0m Views
    • FollyF
      Folly @JimmyFromTheBay
      @JimmyFromTheBay
      I will try to describe the manual installation over here.
      You can use "Raspberry Pi Imager" from here :
      https://www.raspberrypi.com/software/
      Then I would suggest that you pick "Raspberry Pi OS with desktop (64-bit)"
      With that you will be able to use the PI as regular Desktop computer which makes life more easier.
      You can simply copy and paste from your browser or in your file manager.
      Once your SD card is written you can boot your Pi with it and set your own recommended settings.
      With your browser you then you go to (scroll down to the readme) :
      https://github.com/retropie/RetroPie-Setup
      You can simply copy the code pressing this icon.
      Then you open the "Terminal" and paste the code into the terminal ultimately revealing the RetroPie-Setup.
      Before you run the RetroPie-Setup you can add my script by doing :
      wget --backups=1 https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/main/00-scriptmodules-00/supplementary/mamedev.sh -x -nd -np -P ~/RetroPie-Setup/ext/RetroPie-Share/scriptmodules/supplementary
      Remember, there are no binaries from RetroPie so everything is installed from source.
      Although the PI5 is quite quick it's still recommended to install the things you only need.
      Go to :
      • Manage packages -> Manage core packages -> Install all core packages
      You start "Retropie" with running emulationstation from the terminal.
      After that you will be able to go and set your joystick settings and ultimately go to my script and install the binaries from within my script.
      Eventually you can go to the raspi-config and set your pi to boot into the terminal by default if you want.
      From there you can boot into the desktop by doing startx or run Retropie with emulationstation.
      I think you can set booting to emulationstation in the retropie_setup if you would want that.
      Personally I would not do that as it will make it more difficult to boot into the Desktop.
      Then if you want you can copy things from you old SD to you new SD with use of an sd->usb converter and copy the files to your new SD.
      Get it ?
      • DTEAMD
        DTEAM @Folly
        Is it a 64bits OS or 32bits OS.
        Did you create your own binary or did you use mine ?
        64bits OS binary (aarch64) from your script. I did that for MAME 0.266, Lr-Mess 0.266 and Lr-MAME 0.266. Work well with Pi5
        • FollyF
          Folly @DTEAM
          @DTEAM
          Ok thanks for letting me know.
          You had mentioned 32-bit earlier, that is why I asked.
          • DTEAMD
            DTEAM @Folly
            @Folly
            yes, it was for my Pi4 , but I switched for my Pi5 last week. 32 bits is important for Pi 4 and lower with the official Retropie image.
            • FollyF
              Folly @DTEAM
              @DTEAM
              Ok, got it.
              • duglorD
                duglor @DTEAM
                I'd like to play Bubsy in Atari Jaguar emulator Lr-Mess-Jaguar- Help. 2024
                Hello. I'd like to play Bubsy in Atari Jaguar Emulator. I have the game .j64 and the game zipped as bubsy.zip with that .j64 in it and a folder named bubsy as well with that .j64 in it. I'm trying to cover all bases here.
                Installed lr-Mess-Jaguar and have regular lr-Mess set for that directory along with the virtual jaguar emulator.
                I have a bios called jagboot.zip and jagboot.rom is my bios folder.
                Now....so far i have not been able to run the .j64, the .j64 in the bubsy folder, or the bubsy.zip with lr-mess-jaguar chosen as my emulator. It just kicks me out.
                Any help would be appreciated. Thank you very much.
                p.s. btw, all my bubsy names in the folder are lower case.
                • FollyF
                  Folly @duglor
                  @duglor
                  I am not going to talk about lr-virtualjaguar as that is an other topic
                  For running bubsy in mame or lr-mess with my script you need to install jaguar from my script.
                  Mame needs a bios called jaguar.zip (see in mame-merged) which needs to be in :
                  ~/RetroPie/BIOS/mame
                  Try to get the "original" bubsy.zip file from jaguar.zip (see in mame-sl).
                  Always try with mame-standalone first to see if it works then you know the files are good.
                  (If it doesn't the /dev/shm/runcommad.log is better to reed if mame standalone is used.)
                  Then try lr-mess if it works.
                  If it doesn't then you know it's probably an lr-mess issue.
                  Good luck
                  duglorD 1 Reply Last reply Reply Quote 0
                  • duglorD
                    duglor @Folly
                    @Folly Thanks!
                    • DTEAMD
                      DTEAM @duglor
                      Hi @folly, do you think it's possible to use Vulkan on pi5 for MAME standalone?
                        shift
                        Hi @Folly, I was testing the Jupiter Ace system (jupace) and I saw that to work correctly the "-ram 32k" parameter must be added, otherwise most of the roms don't work, I'm now using this command line:
                        lr-mess-jupace-basename-32k = "/opt/retropie/emulators/retroarch/bin/retroarch --config /opt/retropie/configs/jupace/retroarch.cfg --appendconfig /opt/retropie/configs/jupace/retroarch.cfg.basename -S /home/pi/RetroPie/roms/jupace -s /home/pi/RetroPie/roms/jupace -v -L /opt/retropie/libretrocores/lr-mess/mamemess_libretro.so 'mame jupace -cfg_directory /opt/retropie/configs/jupace/lr-mess -c -ui_active -ram 32k -rompath /home/pi/RetroPie/BIOS/mame;/home/pi/RetroPie/roms/jupace/  '%BASENAME%''"
                        when you get to the prompt, a precise line must be typed for each game (up to the "." if there is one, the rest are the game controls), for convenience here are those of all the games reported as working:
                        3dmaze		load 3dmaze 3dmaze
                        avoider		load avoider run
                        invader1	load GR load GR load GR load GM load GM load GM z p
                        aceinvad	load graphics gr load run run
                        amce11
                        acemines	load mines mines
                        acestar		0 0 bload astar 16384 call
                        acevader	load gr load acevaders gr r. Z = left, X = right, M = fire
                        adventa		0 0 bload adva 16384 call
                        aliendef	load defender g
                        amazmaze	load maze g
                        astrian		load Lander run
                        aticraid	load atic go
                        blackisl	load black island
                        bomber		load bomber play
                        breakout	load breakout b. Left = A, Right = L
                        callisto	8930 0 bload callisto
                        cavern		load graphics load run gr run. A = up, Z = down
                        cenipede	load centipede go
                        chase		load chase chase. Cursor keys to move
                        chess		load chess run
                        dodge		load Dodger game
                        ducksht		11272 0 bload dchars load duckshoot d. Fire = Enter
                        firebird	load FIREBIRD run
                        surround	load surround go
                        frogger		load frogger go
                        fungle		load FU run
                        gobbgook	load gobblegook gobblegook
                        grexfrog	load graphics load run grf run
                        guessing	load game game
                        kkong		load CHARACTERS CHARACTERS load KONG run
                        lightrac	load LightRacer run
                        memstars	load run run
                        meteor		load gr meteor load meteor game
                        metracer	load GR load GR load GR load GM load GM z p
                        meteors		load asteroids g
                        micromaz	load graphics load run s run
                        minefld		11272 0 bload mchars load minefield m
                        othello		load othello 11272 0 bload pieces go
                        owler		load owler loading
                        quickdrw	load quick-draw go
                        quickdrp	load Qdraw run
                        robohnch	load robohench g
                        robohunt	load robohunt g
                        sailhorn	load hornpipe hornpipe
                        sambombs	load sam g
                        sokoace		load sokoace play
                        sacemap		load sokoed ed
                        sbattle		load graphics load run gr run. Fire = F
                        startrek	load startrek g
                        sudoku		load sudoku sudoku
                        schess2		load chess run
                        tankbatl	load tankbattle g
                        tetris		load tetris tetris
                        hanoi		load hanoi hanoi
                        turbo		load turbo 0 0 bload track turbo. Left = 5, Right = 6
                        zapem		11272 0 bload zchars load zapem z. Left = 6, Right = 7, 9 = Thrust, 0 = Fire
                        zombies		load zombpot zombpot
                        • FollyF
                          Folly @DTEAM
                          I don't have much knowledge of that.
                          Looked for some info and it seems it can use vulkan with BGFX stuff.
                          That would mean background and shader stuff.
                          On the stickfreaks website I found some info that it will not work correctly on Bullseye on the pi4.
                          (https://stickfreaks.com/misc/raspberry-pi-4-mame-performance-guide)
                          However for the pi5 this could be totally different.
                          Seems that if the computer has it it will automatically be enabled.
                          However not sure how one can see what is enable.
                          • FollyF
                            Folly @shift
                            @shift said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
                            Ok, will do some tests.
                            If -ram 32k is a good add-on I will add it to the script so it will be installed automatically when installing jupace.
                            Thanks for the loader commands will have a look at them too.
                            Edit 1 :
                            Added the maximum of 48k to jupace when installing by default :
                            https://github.com/FollyMaddy/RetroPie-Share/commit/c1d164d7e2b71a11c6a35d969f690fb60482dfac
                            I tested it with 3dmaze and indeed adding ram works.
                            Edit 2 :
                            Loader commands can also be found in the hash table jupace_cass.xml
                            • DTEAMD
                              DTEAM @Folly
                              I found this (from 2020)
                              https://retropie.org.uk/forum/topic/28362/enhanced-performance-of-mamedev-mame-in-x11/2
                              • FollyF Folly referenced this topic on
                              • FollyF
                                Folly @DTEAM
                                @DTEAM
                                Have read the topic link you proposed.
                                Was indeed informing but hard to understand how things are really connected to each other.
                                Seems resolution changes were working better with some drivers in x11 which improved the speed sometimes, right ?
                                From my own perspective I have also seen these differences sometimes.
                                Indeed Vulkan was mentioned having a possible impact when enabling BGFX and using the HLSL shaders.
                                I think the questions would be :
                                • When are resolution changes active underneath to perform speed improvements in drivers ?
                                  (using x11 or wayland in a desktop environment or not or in both situations and or using older or newer RaspberryPi's)
                                • When is Vulkan installed and how can we check ?
                                • Is Vulkan part of the mesa package ?
                                • What does the mesa package do ?
                                • When is Vulkan active ?
                                • Do we use HLSL shaders in our drivers, for example with the handheld ?
                                What do you think are these questions correct ?
                                Edit :
                                We might find more info over here about mesa.
                                • DTEAMD
                                  DTEAM @Folly
                                  Vulkan could be useful for 3D consoles (like Dreamcast) or newer 3D arcade games (like Naomi 2) under MAME standalone. Maybe the results will be disappointing, but it would be good to do the test.
                                  • FollyF
                                    Folly @DTEAM
                                    I think there are indeed some drivers that could work faster.
                                    However I don't expect 50 % speed increases.
                                    • FollyF
                                      Folly
                                      Script and database are updated to 267.
                                        shift @Folly
                                        @Folly Thank You!
                                        Meanwhile, I continue to point out those systems that require some adjustments to the scripts in order to work.
                                        Orion-128
                                        It has a really complicated operation
                                        • cassette
                                          The script I used is this:
                                        lr-mess-orion128-cart-cass = "/opt/retropie/emulators/retroarch/bin/retroarch --config /opt/retropie/configs/orion128/retroarch.cfg --appendconfig /opt/retropie/configs/orion128/ retroarch.cfg.add -S /home/pi/RetroPie/roms/orion128 -s /home/pi/RetroPie/roms/orion128 -v -L /opt/retropie/libretrocores/lr-mess/mamemess_libretro.so 'orion128 - rompath /home/pi/RetroPie/BIOS/mame;/home/pi/RetroPie/roms/orion128/ -cfg_directory /opt/retropie/configs/orion128/lr-mess -c -ui_active -cart /home/pi/RetroPie/ roms/orion128/romdisk.zip -cass %ROM%'"
                                        the romdisk.zip (a cartridge) must necessarily be loaded and then the cassette, this is the procedure for loading the cassette:
                                        Once the game is launched you will arrive at the Orion-128 prompt, immediately press the "Scroll Lock" button to change the focus
                                        You will enter the ROMDISK GUI
                                        Select CH4# and press ENTER (the LOADER will load)
                                        At the BBOA prompt? press A (the cursor should stop flashing)
                                        Refocus by pressing "Scroll Lock" (GAME OFF)
                                        Press F2 to play the tape
                                        Refocus by pressing "Scroll Lock" (GAME ON)
                                        Alongside BBOA? you will see the name of the game you chose at the beginning appear
                                        Once loading is complete, press F4 (the LOADER will close)
                                        In the next column you will see the name of the game you loaded
                                        Go right with the cursor arrows, select it and press ENTER
                                        Type RUN and ENTER
                                        • floppy
                                        lr-mess-orion128-cart-flop1-flop2 = "/opt/retropie/emulators/retroarch/bin/retroarch --config /opt/retropie/configs/orion128/retroarch.cfg --appendconfig /opt/retropie/configs/ orion128/retroarch.cfg.add -S /home/pi/RetroPie/roms/orion128 -s /home/pi/RetroPie/roms/orion128 -v -L /opt/retropie/libretrocores/lr-mess/mamemess_libretro.so ' orion128 -rompath /home/pi/RetroPie/BIOS/mame;/home/pi/RetroPie/roms/orion128/ -cfg_directory /opt/retropie/configs/orion128/lr-mess -c -ui_active -cart /home/pi/RetroPie/roms/orion128/romdisk.zip -flop1 /home/pi/RetroPie/roms/orion128/floppy/game1715.zip -flop2 %ROM%'"
                                        Select Boot# and press ENTER (the first floppy that loads the Norton Commander will boot)
                                        You will enter directly into the Norton Commander GUI
                                        Press D to change drive press B (you should have the floppy you chose at the beginning)
                                        The launchable games are the .com ones, select the one you want and press ENTER
                                        EDIT: I moved the romdisk.zip cartridge to the correct folder, which is .../orion128/cart
                                        • FollyF
                                          Folly @shift
                                          Good to hear you got Orion-128 working.
                                          I saw you saying : "The script I used is this: ".
                                          We call that a runcommand which is normally installed by the script, so there will be no misunderstanding in what we mean.
                                          I see you have edited the runcommands to get them working for the Orion-128.
                                          Will have a look at the Orion-128 when I can, and perhaps I can change the way things are installed.
                                          With some drivers this is not always possible.
                                          Initially these installs were added in systems with EXRAS.
                                          However I try to add more stuff to the DEFAULT installs like adding more ram.
                                          Will have a look at what is possible.
                                          Thanks for explaining how this system driver works.
                                          • FollyF
                                            Folly @DTEAM
                                            I see you experimenting with other things on the forum like aethersx2 and using xinit with it, if I am correct.
                                            If you run a headless distro (OS without desktop) then you could try to load mame with xinit in the runcommand and see if it gives some improvements.
                                            Would like to hear if it works and if it gives some higher speeds.
