    2.3k Posts 37 Posters 8.5m Views
    • TPRT
      TPR @Folly
      @Folly Awesome! Thank you! I can totally work with that! I’ll let you know if I run into any issues.
      • FollyF
        Folly @TPR
        @TPR
        Remember that the list is not filtered on the tag @good so the list contains also bad drivers.
        Then the code would have been :
        ",Home systems upon descriptions,,create_systems_list_mamedev descriptions @home_system @good,"
        ",Home systems upon system names,,create_systems_list_mamedev systems @home_system @good,"
        If you want you can experiment with that.
        Here you can see how many filter options you can add when running the function :
        https://github.com/FollyMaddy/RetroPie-Share/blob/da0b6070816126d340e5690c66ff374eaa589eae/00-scriptmodules-00/supplementary/mamedev.sh#L1937-L1951
        TPRT 1 Reply Last reply Reply Quote 0
        • TPRT
          TPR @Folly
          @Folly Yay! Thank you!
          • FollyF
            Folly @TPR
            @TPR
            Perfect !
            Seems you are getting the hang of it.
            Let me know if you want to know more about the code.
            I can teach you some stuff.
            I could use some volunteers in the future, you know ;-)
            • TPRT
              TPR @Folly
              @TPR
              Perfect !
              I can understand it and I can tinker with it, but I'm not a "programmer" however I still try to contribute what I can! :D
              • FollyF
                Folly @TPR
                @TPR said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
                That's fine too, thanks !
                • FollyF
                  Folly
                  @TPR said in How to emulate Bally Astrocade, VTech Creativision, and Emerson Arcadia-2001 in lr-mess:
                  I finally figured it out, and in case anyone needs to know for future reference:
                  Option 1: Go into "Slot Devices" by pressing TAB to get into the MAME config menu and choose "Joy" under "ctrl2" - This is not set by default.
                  Option 2: Add -ctrl2 joy to your command line in emulators.cfg - This will force a controller to put put into controller port 2. So for example, my command line for Astrocade looks like this:
                  @TPR @LilaQ
                  I read both your posts and added this in my script for :
                  -astrocde
                  -astrocdl
                  -astrocdw
                  With a default install for these drivers "-ctrl2 joy" will be added automatically.
                  https://github.com/FollyMaddy/RetroPie-Share/commit/28939863494d9a124d02cf16fddb4b49cf5f1e32
                  Remember my script doesn't use "astrocade" (with an A) just :
                  -astrocde
                  -astrocdl
                  -astrocdw
                  • DTEAMD
                    DTEAM @Folly
                    @Folly
                    MAME 0.272 is release
                    For All in one:
                    Jungle Soft Classic Max Pocket Mx-10 - 12 in 1 (vertical) [TeamEurope, David Haywood, AJR] --> cmpmx10
                    YSN GameU Joint TV Bank 108-in-1 (model AH9069) [TeamEurope, David Haywood] --> gujtv108
                    Classic Max Pocket PCMX11 - 12 in 1 Colour Games Console (horizontal, France) -->cmpmx11
                    NJ Pocket 60-in-1 handheld 'X zero' (NTSC) [David Haywood, AJR] --> njp60in1 (already in the list , but now promoted as a working system)
                    Portable Game Station 268-in-1 [David Haywood, AJR] --> pgs268
                    unknown VT1682-based 101-in-1 handheld (PAL) [David Haywood, AJR] --> unk1682 (already in the list , but now promoted as a working system)
                    for MAME 0.271
                    265-in-1 Handheld Game (SPG2xx based) [David Haywood, TeamEurope] --> 265games
                    Digital Pocket Hand Held System 230-in-1 - Model 8630 / Model 8633 [David Haywood] --> dphh8630
                    dreamGEAR My Arcade Gamer Mini 160-in-1 (DGUN-2953) [David Haywood]
                    --> dgun2953
                    Fizz Creations Arcade Classics Mini Handheld Arcade --> supreme
                    Fizz Creations Mini Arcade Console (Arcade 10-in-1) [David Haywood] --> arcade10
                    Millennium 2000 GmbH Millennium Arcade 250 --> marc250
                    Orb Retro Arcade Game Controller 153-in-1 [David Haywood] --> ragc153
                    Orb Retro Handheld Console 152-in-1 [David Haywood] --> rhhc152
                    Recently, many "all in one" systems have been promoted as "working systems". I didn't saw that. I'll do a quick search in the previous MAME releases. A lot of work to update the gamelist.xml.
                    New edit: That list above is ok. I revisited the old MAME journals.
                    • DTEAMD
                      DTEAM @DTEAM
                      MAME 0.265 is released, see here
                      Coleco_homebrew now supported by MAME
                      New games for:
                      gameking3:
                      Diamond, Hemic Battle [sCZther, SSJ, Gaming Alexandria, TeamEurope]
                      After 7 months , my gamelist.xml is now updated for Gameking3
                      • FollyF
                        Folly @DTEAM
                        @DTEAM
                        Nice to hear that you did some updates.
                        • FollyF
                          Folly @DTEAM
                          @Folly
                          For All in one:
                          for MAME 0.271
                          --> dgun2953
                          I have manually added the all_in1 drivers in the 271 database.
                          To get it just update the script and the database will be overwritten with a new one.
                          https://github.com/FollyMaddy/RetroPie-Share/commit/5f45c53d414154087f56cfb3cb6a408824b249f0
                          https://github.com/FollyMaddy/RetroPie-Share/commit/568454915cc701f0ac2ca66ea7bcaca1d84acd06
                          Also updated for next update:
                          https://github.com/FollyMaddy/RetroPie-Share/commit/0edbb4b9e81dd8464ba3f8dc5c3413f9c6aa2417
                          P.s.
                          Did you leave out marc101 because booting is a bit slow in the beginning ?
                          • FollyF
                            Folly
                            @DTEAM
                            Found something that is interesting.
                            Viewing on the progettosnaps website I found that he has a github page with the ini files over here :
                            https://github.com/AntoPISA/MAME_SupportFiles/tree/main
                            If needed we can still find the old ini files over there..
                            • FollyF
                              Folly
                              The script and database have been updated to 272.
                              • DTEAMD
                                DTEAM @Folly
                                P.s.
                                This is a mistake. I'll add it. It works fine. No reason why it shouldn't be in the list. I'll add it to my gamelists.xml file.
                                Thanks for the 0.272 update, I'll finish the gamelist update today
                                New edit: All_in_1 gamelist.xml is now updated for MAME 0.271 and 0.272.
                                • FollyF
                                  Folly @DTEAM
                                  @DTEAM
                                  Super, thanks for the reply.
                                  I will add that driver manually later.
                                  Might be intersting for you.
                                  There is also a tag multi-game in the database.
                                  Might be that you can find more for all_in1 when looking at these drivers with the multi-game tag.
                                  • DTEAMD
                                    DTEAM @Folly
                                    @DTEAM
                                    It's a mix of Casino machines, arcade machines and cartridges with many games. If we exclude Arcade and Casino Machine, only those games seems to be (maybe) ok for "All in one" as cartridges :
                                    multi96
                                    multigam
                                    multigm2
                                    multigm3
                                    multigmb
                                    multigmt
                                    sgmt1
                                    supergm3 1992 pirated arcade machine don't fit in "all in 1"
                                    All am_mg, geimulti, games seems to be Casino Slot Machine games. geimulti and twinadvk seems to be arcade boards.
                                    I'll do a double check later.strikethrough text
                                    • FollyF
                                      Folly @DTEAM
                                      @DTEAM
                                      I came up with a few drivers,
                                      I filtered the database on :
                                      • non-arcade (grep non-)
                                      • multigame (grep multigame)
                                      • not all_in1 (grep -v all_in1)
                                      Full command to test the drivers one by one :
                                      cat /opt/retropie/emulators/mame/mame0271_systems_sorted_info |grep non-|grep multigame|grep -v all_in1|cut -d " " -f2|while read driver;do /opt/retropie/emulators/mame/mame -ui_active $driver;done
                                      Found that next drivers seem to work ok and could potentially be added to the list all_in1 :
                                      cham24
                                      smssgame
                                      smssgamea
                                      vgtablet
                                      What do you think ?
                                      P.s.
                                      Added marc101 to all_in1.ini and 271/272 database.
                                      • TPRT
                                        TPR
                                        @Folly @DTEAM Working on getting BBC Micro Installed and so far a lot of games work perfectly fine, for example:
                                        But trying some more graphics intensive games the screen gets scrambled and starts to flicker:
                                        (Top game is Ransom or King's Ransom, bottom game is Elite)
                                        I've installed both the BBC Micro B and BBC Micro B +128 and get the same results for both.
                                        Any idea what graphics card or expansion I might need to put into one of the internal slots in MAME or if there is another settings I should be using?
                                        Note that I've tried just about every dip switch combo I could try.
                                        • FollyF
                                          Folly @TPR
                                          @TPR
                                          Not sure either what should be done to get it working.
                                          I will have a look at "elite" when I can.
                                          Although I must say this discussion has been on the forum before.
                                          As far as I know mame isn't the best bbc micro emulator but for RetroPie it's the best available.
                                          I have made some module-scripts with alternative emulators but sadly newer gcc will not compile these older packages anymore, if you run a newer OS.
                                          Alternative forums, to find answers, are :
                                          https://stardot.org.uk/
                                          or
                                          https://forums.bannister.org/ubbthreads.php?ubb=postlist&Board=1
                                          • FollyF
                                            Folly @TPR
                                            @TPR
                                            Tried elite and elitea from bbcb_flop.
                                            Saw these graphic glitches also.
                                            Mame warns for "graphic issues".
                                            I think there is noting you can do about it.
                                            TPRT 1 Reply Last reply Reply Quote 1
