    2.3k Posts 37 Posters 8.8m Views
    • DTEAMD
      DTEAM @Folly
      @DTEAM
      I came up with a few drivers,
      I filtered the database on :
      • non-arcade (grep non-)
      • multigame (grep multigame)
      • not all_in1 (grep -v all_in1)
      Full command to test the drivers one by one :
      cat /opt/retropie/emulators/mame/mame0271_systems_sorted_info |grep non-|grep multigame|grep -v all_in1|cut -d " " -f2|while read driver;do /opt/retropie/emulators/mame/mame -ui_active $driver;done
      Found that next drivers seem to work ok and could potentially be added to the list all_in1 :
      cham24
      smssgame
      smssgamea
      vgtablet
      What do you think ?
      P.s.
      Added marc101 to all_in1.ini and 271/272 database.
      All systems are for arcade games excepted vgtablet
      New edit: vgtablet has been added to "All in one" gamelist.xml
      • FollyF
        Folly @DTEAM
        cham24
        smssgame
        smssgamea
        My database states that these system drivers are non-arcade and the don't use a coin to play.
        Besides "Sega Master Systems" on itself, isn't arcade either.
        If these are really arcade, as you stated, then my database isn't correct and has to be improved somehow.
        Where did you find the info of these being arcade ?
        Can you share your source ?
        I have added vgtablet to the database 271/272 and ini file.
        • DTEAMD
          DTEAM @Folly
          cham24
          smssgame
          smssgamea
          For cham24, here's where I got my info. [site 1] (https://bootleggames.fandom.com/wiki/Chameleon_24) , site 2 (at the bottom in the history section) .
          Maybe it's a token-free home arcade. If yes, it could be in the list, but it's not easy to know.
          It's a "pay for time" arcade like PlayChoice10. See here
          For smssgame and smssgamea, see site 1 (at the bottom in the history section and also the picture where we can see the game time credits)
          They put those games in "bootleg" but they are Arcade "multi games" bootlegs. Maybe they put those games in the wrong category. I don't think they are token-free home arcades.
          FollyF 2 Replies Last reply Reply Quote 1
          • FollyF
            Folly @DTEAM
            @DTEAM
            Thanks for the info.
            Indeed if they are arcade then we should not add them.
            Will have a second look at these drivers if I can find the proper info about coin/pay usage in the driver xml info.
            Then I can, possibly, split arcade and non-arcade better in the future.
            • FollyF
              Folly @DTEAM
              @DTEAM
              For cham24 and smssgame I tried to find coin/pay/time info but there is nothing to be found inside the xml driver info.
              There is also no coin input key inside the input settings.
              If these drivers are really arcade then the mame drivers and driver infos are incomplete for these drivers.
              Seems they just work without "paying" but that could mean that this is the incompleteness which is also a reason not to add them to all_in1.
              For now I will keep them in the non-arcade section as I can't properly detect whether they are arcade or not.
              • TPRT
                TPR @Folly
                @TPR
                Tried elite and elitea from bbcb_flop.
                Saw these graphic glitches also.
                Mame warns for "graphic issues".
                I think there is noting you can do about it.
                Gotcha. If I end up coming up with some sort of solution or work around I'll post it!
                • FollyF Folly referenced this topic on
                • DTEAMD
                  DTEAM @TPR
                  @Folly
                  MAME 0.274 is release
                  Many new games (JAKKS, and more)
                  • FollyF
                    Folly @DTEAM
                    @DTEAM
                    Great !, Indeed I saw some stuff on the bannister forum.
                    Will have a look if I can update this month if the time allows.
                    • FollyF
                      Folly @DTEAM
                      @DTEAM
                      The mame 274 binary has been added to the gdrive.
                      I added the new 274 ini files.
                      Can you check these here ?
                      DTEAMD 2 Replies Last reply Reply Quote 1
                      • DTEAMD
                        DTEAM @Folly
                        @Folly
                        Here's the list (0.274):
                        The others from your list are Arcades, Slot machines or other.
                        • FollyF
                          Folly @DTEAM
                          @DTEAM
                          Thanks for checking and adding some that are not automatically found by my script.
                          I have committed the ones for all_in1 here.
                          For classich I did the same here.
                          For classich I will try to add automatic detection for the new ones later.
                          I believe :
                          • your list misses tama and trclchick
                          • epo_tetris must be epo_tetr
                            Right ?
                          Can you check a second time ?
                          After that I think we are good to go and use the inis for updating the database.
                          • DTEAMD
                            DTEAM @Folly
                            It works well
                            • DTEAMD
                              DTEAM @Folly
                              @DTEAM
                              I believe :
                              tama is there (last one) and yes trclchick (classich) is missing , thanks
                              Right ?
                              Yes
                              • FollyF
                                Folly @DTEAM
                                @DTEAM
                                Thanks.
                                Seems we have all our new data for 274.
                                I will wait for the new data from progettosnaps and then create the new database.
                                • FollyF
                                  Folly
                                  Read this post.
                                  Looks like many systems will work much better now on arm with mame 274.
                                  duglorD 1 Reply Last reply Reply Quote 2
                                  • duglorD
                                    duglor @Folly
                                    @Folly EXCELLENT!
                                    • FollyF
                                      Folly
                                      Here is the commit for the drivers that, most likely, will benefit from the arm dynarec improvement :
                                      https://github.com/FollyMaddy/RetroPie-Share/commit/d3b18e080a9182e6aaf48cf06b53278c4d5a95b7
                                      Btw.
                                      Rumours, on the internet, are that arm64 will do a better job than intel64, we will see !
                                      • FollyF
                                        Folly
                                        Here is the commit for the drivers that will use separate audio samples :
                                        https://github.com/FollyMaddy/RetroPie-Share/commit/0250f4d4f0822f49c1b33506fc8e8054472b10d7
                                        When I update the mamedev.sh script to 274 it will be possible to download these files from within the script.
                                        And it should then also be possible to install the category "samples" and "dynarec" so all these drivers can be placed in 1 romfolder to test.
                                        • FollyF
                                          Folly
                                          The script and database have been updated to 274.
                                          • FollyF
                                            Folly @DTEAM
                                            @DTEAM
                                            I have not added any help yet,
                                            Can you let me know if you understand how the samples are downloaded and if you can detect the difference in running the games with or without?
