I reinstalled MAME with your new mamedev.sh, but what's the next step? Do I need to install a new system or reinstalled one?
I added the tags samples to the database.
These categories can also be installed now.
You have to use :
►Choose and install HANDHELD/PLUG&PLAY/CATEGORIES
►Show all arcade categories from database and install one
Category => samples
For linking the roms then use :
►Link roms from folder ~/RetroPie/BIOS/mame
►Show all arcade categories from database and link roms
Category => samplesNow you will be able to run the roms from that category but they still don't have the audio samples installed.
If you want to install the audio samples then go to :
►ARTWORK/CHEATS/GAMELISTS/JOYSTICKS/OVERLAYS/PATCHES/SAMPLES
Download/update mame audio samplesNow you you should be able to notice the difference.
Run 005 and you will see.Speaking of drivers with audio samples, it seems that these non-arcade handheld use them too :
kst25 ktmnt2 ktopgun2
If you have installed the sample files then you should be able to notice the difference when loading them from your own konamih categorie.
(did not test is myself yet, will have a look later)I think you know how to install the arcade dynarec catergory now to test only the drivers that use dynarec.
So I do what you wrote above and Dynarec works automatically, right?
@Folly
It works !!! I tested ktmnt2 and now we can heard the Ninja Turtle voice. That's great! It's very good for game with voices. For 005 the sound is better and different when shooting.
Comment: maybe you should add .7z with the .zip in the Link roms from folder ~/RetroPie/BIOS/mame by default. Now it's only .zip . Thank you for your hard work! -
Yes
@Folly
Comment: maybe you should add .7z with the .zip in the Link roms from folder ~/RetroPie/BIOS/mame by default. Now it's only .zip . Thank you for your hard work!Good to hear that you have worked it out.
Will have a look at that 7z idea so you can choose between .zip or 7z. -
I had the idea to make a sophisticated change but it seemed too difficult so I added a quick possibility to link .7z files.
Let me know if this solution is good enough.
(update 274.01) -
@Folly
Hi FollyHave you work on runcommand.sh in your scritp? Since I did the installation, I have this message in my log when I try to load Xinit-wmc for any other emulator
/opt/retropie/supplementary/runcommand/runcommand.sh: line 1330: XINIT-WMC:: command not found
Maybe it's not linked. I'll reinstaled the original one.
New edit: fixed , I reinstalled runcommand. Maybe double check on your side
