    2.3k Posts 37 Posters 7.7m Views
    • FollyF
      Folly @DTEAM
      Great to hear that this also works on lr-mess !
      Did you try "-uimodekey TAB" too ?
      What do you think?
      It changes Scroll lock for TAB. Same problem if you don't have a keyboard.
      -ui_active is the best option for me. I don't see problems. Most of the time, It's already activated.
      Ok, good to know.
      I think it's in our best interest not to make separate lines for that.
      I would want to add -ui_active to the normal lines, I think that's the best option, for now.
      I also want to remove the separate line mame-system-xxxxxxx-autoframeskip= .
      Using 1 string we can add all options to both mame and lr-mess :
      mamedevcfgoptions="-v -c -autoframeskip -ui_active"
      This way, I only have to edit above line and we reduce some starter lines making it a bit simpler.
      Good idea ?
      If we run into problems we can always revert it.
      BTW.
      Don't know if we should add this to the CMD and BASENAME lines, we could get into trouble, agreed ?
      • FollyF
        Folly @RussellB
        @russellb said in Development of module-script generator for lr-mess and mame standalone:
        @folly I've tested this with mess running tic-80 games, Sega VMS, and CD-i and each game gets its own config file. I had config files already from the bezelproject for CD-i and they immediately came up as it was no longer reading tmpmess.cmd. Looks good from my testing.
        Super, very nice what you made 👍
        Thanks for testing.
        I will add this information to the first^post .
        You should upvote your own idea in post 1, then we improve our ranking.
        • DTEAMD
          DTEAM @Folly
          Ok, good to know.
          Good idea ?
          BTW.
          For -ui_active I agree, but for -autoframeskip, be aware that it slowed down some systems a bit with lr-mess and MAME, but most of the time it is beneficial.
          So, yes, I agree with your approach.
          It's simpler for the user and he can always set buttons to set frameskip option if needed.
          • FollyF
            Folly @DTEAM
            @dteam
            I have had a few hours re-thinking it.
            Now I think it's better to do small steps, so I didn't add that much.
            Editing the files, it struck me, that the "string" isn't that handy after all, so I have removed it.
            That way the options are right in the lines where they suppose to be and the scripts have less lines.
            I left the mame-xxxx-autoframeskip line in there, I think you have a point, when you say it doesn't always help that it is on. So I kept both lines.
            With lr-mess we already had -autoframeskip in the standard line, so I left it there.
            https://github.com/FollyMaddy/RetroPie-Share/commit/1843471347f30fe102b3690bb0652d1af77240e4
            • FollyF
              Folly @RussellB
              @russellb
              Would you like to help more, in improving the scripts ?
              • FollyF
                Folly @DTEAM
                @dteam
                I found the answers to improve the front-end script !
                As I told before I now use comma separate value's within the array's.
                This worked from the beginning, but there was a problem with speed.
                Al the things I used before were very slow for the 38000 entry's of mame.
                I couldn't use cut that's why it took so long to find a better solution.
                Now I use sed to convert the lines into csv and I use IFS to cut on delimiter and get the correct value's.
                I also implemented a way of re-using the data of mame within the different menu choices. So it will read all in one time for 20 sec. and re-use this data which takes 4 sec.
                It now works, only the generator_script part is still old.
                For that i also have to fix some things, but those are not that difficult I think.
                I worked from what I could accomplish, I hope it will match the direction of our ideas.
                Here are some pictures :
                2021-05-08-221723_1600x900_scrot-resized.png 2021-05-08-221731_1600x900_scrot-resized.png
                2021-05-08-221756_1600x900_scrot-resized.png 2021-05-08-221802_1600x900_scrot-resized.png
                • DTEAMD
                  DTEAM @Folly
                  @folly
                  This is very nice!!! good work !
                  • FollyF
                    Folly @DTEAM
                    @dteam
                    I didn't put it on github yet, there are a still a few little things to do and to check.
                    But I hope soon.
                    It's really quite amazing !
                    • FollyF
                      Folly @DTEAM
                      @DTEAM
                      @RussellB
                      @valerino
                      I moved to 2 versions of the generate-script, replacing 1v8 and 2v0:
                      • generate-systems-lr-mess_mame-2v1.sh generates in ~/RetroPie-Setup
                      • generate-systems-lr-mess_mame-2v1-ext.sh generates in ~/RetroPie-Setup/ext/RetroPie-Share
                      Example to generate in ~/RetroPie-Setup :
                      curl "https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/main/00-scripts-00/generate-systems-lr-mess_mame-2v1.sh" | bash -s coleco
                      Example to generate in ~/RetroPie-Setup/ext/RetroPie-Share :
                      curl "https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/main/00-scripts-00/generate-systems-lr-mess_mame-2v1-ext.sh" | bash -s coleco
                      Only the ext string is different, this defines if the files should be written in the normal directory or in the ext directory !
                      --> see_this_commit <--
                      Both files can now be pasted in as a function in add-mamedev-systems.sh front-end module-script
                      Edit :
                      With the add-mamedev-systems-test6.sh I did the same :
                      • add-mamedev-systems-test6.sh generates in ~/RetroPie-Setup/
                      • add-mamedev-systems-test6-ext.sh generates in ~/RetroPie-Setup/ext/RetroPie-Share
                      Get the script (in ~/RetroPie-Setup ) to generate in ~/RetroPie-Setup :
                      wget -q -nv -O /home/$(ls /home)/RetroPie-Setup/scriptmodules/supplementary/add-mamedev-systems.sh https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/main/00-workdir-00/add-mamedev-systems-test6.sh
                      Get the script (in ~/RetroPie-Setup ) to generate in ~/RetroPie-Setup/ext/RetroPie-Share :
                      wget -q -nv -O /home/$(ls /home)/RetroPie-Setup/scriptmodules/supplementary/add-mamedev-systems.sh https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/main/00-workdir-00/add-mamedev-systems-test6-ext.sh
                      or(only 1 version here)
                      You can also update the RetroPie-Share through the add-ext-repos.sh module-script.
                      (gets it in ~/RetroPie-Setup/ext/RetroPie-Share and generates in ~/RetroPie-Setup/ext/RetroPie-Share !)
                      Happy testing !
                      • FollyF
                        Folly
                        @DTEAM
                        I came across the first issue :
                        Sorting the descriptions is based on the system names because they are linked in one cel in the array.
                        That's why they are not perfectly on alphabetical order.
                        No solution right now, I have to think about it.
                        • DTEAMD
                          DTEAM @Folly
                          I understand what you mean. The numerical order go in front of alphabetical order. You are not far to the end of the project !! Have you think about a way to separate MESS systems from global MAME list? Bye the way, It's awsome!
                          • FollyF
                            Folly @DTEAM
                            Well, it's not exactly that.
                            But you are in the right direction.
                            Indeed it progressing nicely !
                            Yes I have been thinking about that.
                            I was looking at the mame source, arcade drivers are in a different place than the machine drivers.
                            But, for now, I have no idea on how to accomplish that.
                            Within minutes the structure can be quite difficult to understand.
                            And I have to take speed into account too.
                            That make this quite hard.
                            I was also thinking of making entry's by platform.
                            I think that can easier be done, just like the A,B,C story.
                            If I have some spirit I will look at those issues.
                            Thanks for the compliment !
                            It is ! Really unbelievable ;-)
                              RussellB @Folly
                              @folly I'd love to.
                              Here's a question, probably for a new thread. I installed a PixelCade LED marquee in my bartop arcade build which requires a customized EmulationStation that calls web services on the local machine which has a listener to interact with the marquee. I didn't like having to specifically modify ES for this purpose so I implemented three new events: game-select, system-select, screensaver-game-select, and moved the logic to bash scripts. I've seen other threads that discuss wanting this capability. Is that something users would like?
                              FollyF 2 Replies Last reply Reply Quote 2
                              • FollyF
                                Folly @RussellB
                                @folly I'd love to.
                                Great !
                                • FollyF
                                  Folly @RussellB
                                  Looking something like this ?
                                  I have never used a PixelCade LED marquee, but I would definitly want one, if I had a bartop arcade build.
                                  Perhaps something for the future.
                                  Just reading your story, I think you have something good.
                                  Just use the regular ES and add your bash script are really good arguments to make it simple.
                                  So this sounds good to me, you should make a thread for that !
                                  Perhaps we can even add it to our front-end, you never know.
                                    RussellB @Folly
                                    @folly I'll start a new thread. I really like the functionality that was in there so I just leveraged it. I like general solutions that can be reused.
                                    So:
                                    game-select receives system name, rom name, game name
                                    screensaver-game-select receives system name, rom name, game name
                                    system-select receives system name, type-of-change ("start","input")
                                    While I'm in there are there any other events that could be useful to intercept?
                                    RussellB
                                    • FollyF
                                      Folly @RussellB
                                      @russellb
                                      Well, at the moment I don't have any idea about that, because I know too little about this subject.
                                      You should explain the process in your thread thoroughly, perhaps then I can get a better idea on what should be in there and what should be added.
                                      Name me in your thread and I will follow it.
                                        RussellB @Folly
                                        @folly Will do!
                                        • FollyF
                                          Folly
                                          @DTEAM @RussellB
                                          I found multiple issues with the front-end module-script.
                                          I installed it all from scratch on a x86-64 computer.
                                          I made these commits :
                                          • https://github.com/FollyMaddy/RetroPie-Share/commit/3669f6ab2b9639cb0ef36bc4d62c8b1c25d175ba
                                          • https://github.com/FollyMaddy/RetroPie-Share/commit/c59f653b3e9b80e9f81ca0258866c6bc73bfff3f
                                          • FollyF
                                            Folly
                                            @DTEAM
                                            I added the choice to download the images and videos for the gamelists.
                                            So after the download the images and videos are displayed in Emulationstation.
                                            It worked quite good again.
                                            But sometimes, with the downloading, the download script said [Exists].
                                            It could be an issue with the gdrivedl.py script.
                                            Or perhaps there are double files on your google drive.
                                            Can you check that ?
                                            Also found something that could improve the gamelists.
                                            In the gamelists I found this directory :
                                            /home/pi/.emulationstation/downloaded_images/
                                            This is a link to :
                                            /opt/retropie/configs/all/emulationstation/downloaded_images
                                            So we can better use the opt directory, I think.
                                            That way other users of RetroPie, that aren't called "pi", can also use the gamelists.
                                            This is the commit :
                                            https://github.com/FollyMaddy/RetroPie-Share/commit/0671df1a855a67a3b42fcf969c8df8aabf92f5f5
