    • FollyF
      Folly @hhtien1408
      @hhtien1408 said in Development of module-script generator for lr-mess and mame standalone:
      @folly
      You mean your method for lr-mame or MAME standalone? Or work for both?
      For MAME standalone.
      In this thread we only use mame standalone and lr-mess.
      lr-mame is not implemented !
      I would like to ask about this (I changed the path for myself to suitable for Retropie on Ubuntu)
      mame-basename = "/opt/retropie/emulators/mame/mame -rompath /home/RetroPie/roms/supracan -v -c supracan %BASENAME%"
      Indeed, you should do that because you are an other user !
      It means I will put this line in my /opt/retropie/configs/supracan/emulators.cfg
      exactly as the same code above and make it default emulator? Right?
      Yes, indeed.
      For making it the default you can also press a key when the RetroPie boot-screen comes, press a key, and select your default runcommand line.
      Should I need change a little bit in script before executing for my suitable locations (remove "/pi/)? My current default location is "/home/RetroPie" on Ubuntu.
      No, not needed.
      The module-script will find your user name and use that.
      Check those other lines in emulators.cfg, it should already have user RetroPie not pi.
      For normal neogeo roms, Running with lr-mame (mamearcade-libretro.so show the “initializing” and freeze. Wrong bios or romset? Do you face this error yet?
      You have to press a key when the RetroPie boot-screen comes, then select launch with verbose.
      For the mame standalone and lr-mess lines created by my module-scripts you don't need to do this, our lines have always verbose on.
      Then run your rom.
      After the failed boot, initializing, check your runcommand log in :
      /dev/shm/runcommand.log
      This will tell you where things go wrong, if you understand it.
      With a Bios rom failure you will find something like :
      tried in this and that
      • H
        hhtien1408 @Folly
        @folly I manage to run neogeo under lr-mame by putting bios in neogeo rom folder also (not in /BIOS/mame.).
        But how to make command line to run supracan run? (enable softlist, boot from CLI, cart, automatic type )
        When I check with lr-mame for supracan, it shows error:
        '/opt/retropie/libretrocores/lr-mame/mamearcade_libretro.so' -listroms supracan
        Segmentation fault (core dumped)
        If I try to run supracan from terminal with command verbose to check error
        /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame/mamearcade_libretro.so --config /opt/retropie/configs/supracan/retroarch.cfg '/home/h2t/Downloads/supracan.zip' --verbose
        [INFO] [MIDI]: Initializing ...
        [INFO] [MIDI]: Input disabled.
        [INFO] [MIDI]: Output disabled.
        [INFO] [MIDI]: Initialized "alsa" driver.
        [INFO] Loading history file: [/opt/retropie/configs/supracan/content_history.lpl].
        [INFO] Loading history file: [/opt/retropie/configs/supracan/content_music_history.lpl].
        [INFO] Loading history file: [/opt/retropie/configs/supracan/content_video_history.lpl].
        [INFO] Loading history file: [/opt/retropie/configs/supracan/content_image_history.lpl].
        [INFO] Loading favorites file: [/opt/retropie/configs/supracan/content_favorites.lpl].
        [INFO] [GL]: VSync => on
        [INFO] [GLX]: glXSwapInterval(1)
        [libretro INFO] Starting game from command line:/home/h2t/Downloads/supracan.zip
        [libretro INFO] ARGUV[0]=/home/h2t/Downloads/supracan.zip
        [libretro WARN] Driver supracan not found -1
        [libretro WARN] Game not found: supracan
        [libretro WARN] Driver Downloads not found -1
        [libretro ERROR] Driver not found: Downloads
        [libretro INFO] RES:-2
        It seemed lr-mame does not recognize supracan softlist even softlist is enabled. Weird.
        P.S. P.S. Why I sticked with lr-mame because I cannot builr lr-mess and MAME standalone (qt5 error) successfully on my Ubuntu.
        I run lr-mame with software list perfectly on Retrobat on Windows 10, but no luck with Retropie.
        • H
          hhtien1408 @hhtien1408
          [deleted]
          • FollyF
            Folly @hhtien1408
            @hhtien1408
            We don't want to mix up many things here.
            This thread is only for discussions about improving our script and about discussing the issues related to that.
            Successfully running supracan with mame standalone or lr-mess is part of this discussion and can be discussed over here.
            You should stick with that first !
            If you want to discuss lr-mame it's better to make your own thread or look for an lr-mame thread and post your problem over there.
            I am happy to help you over there, if I can.
            You should look also at the retropie-docs first.
            • H
              hhtien1408 @Folly
              [deleted]
              • FollyF
                Folly @hhtien1408
                @folly could you give me binary files for lr-mess and MAME standalone ubuntu? I cannot build from source from rpi-script? Thanks again!
                I can't help you with that because I don't have a computer with ubuntu 21.04 running.
                If I could, chances are, it won't even work if I shared them.
                You have to ask for advice somewhere else in the forum.
                If you have found a solution, you can come back here to discuss supracan.
                BTW.
                Depending on your computer, it can take 24 hours to build both packages !
                • H
                  hhtien1408 @Folly
                  @folly I manually got it working with mame-libretro downloaded from buildbot (nightly lastest). Runcommand in emulator.cfg. Thanks for all your support.
                  My command line in emulators.cfg
                  supracan= "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame/mame_libretro.so --config /opt/retropie/configs/supracan/retroarch.cfg %ROM%"
                  default = "supracan"
                  • FollyF
                    Folly @hhtien1408
                    @hhtien1408
                    Great to hear you have found the solution !
                    I will test your line.
                    (edit : no luck on trying this oob, using mamearcade_libretro.so on pi4)
                    Perhaps something to implement for the future if it can be "cracked".
                    H 2 Replies Last reply Reply Quote 0
                    • H
                      hhtien1408 @Folly
                      @folly Nightly buildbot version is here, the complied one works well with neogeo but softlist cannot be used.
                      https://buildbot.libretro.com/nightly/
                      Be careful!
                      I am using Linux Debian, I will download this build:
                      https://buildbot.libretro.com/nightly/linux/x86_64/latest/mame_libretro.so.zip
                      In your case, you should choose the suitable build for arm here
                      Noted that mame_libretro.so: arcade + non-arcade (softlist)
                      mamearcade_libretro.so: arcade only)
                      You should down the first one (mame_libretro.so.zip and extract)
                      • Create new system supracan directing to rom path home/Retropie/roms/supracan in es-systems.cfg with .zip and .ZIP extension and copy supracan to this rom path.
                      • Super Acan Funtech
                       <system>
                          <name>supracan</name>
                          <fullname>Super A'can</fullname>
                          <path>/home/h2t/RetroPie/roms/supracan</path>
                          <extension>.zip .ZIP</extension>
                          <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ supracan %ROM%</command>
                          <platform>supracan</platform>
                          <theme>supracan</theme>
                      • NES Datach
                         <system>
                          <name>nes_datach</name>
                          <path>/home/h2t/RetroPie/roms/nes_datach</path>
                          <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ nes_datach %ROM%</command>
                          <platform>nes_datach</platform>
                          <theme>nes_datach</theme>
                        </system>
                      • Make sure softlist is enabled, automatic type is off, cart is chosen, boot from CLI is enabled in retroarch-core-option.cfg or setup via Retroarch GUI.
                      mame_softlists_enable = "enabled"
                      mame_softlists_auto_media = "disabled"
                      mame_media_type = "cart"
                      • Supracan and NES-Datach system has no bios. Any systems requiring bios, please copy to rompath of that system (not BIOS/mame anymore)
                      • Copy hash folders into BIOS/mame and opt/retropie/libretrocores/lr-mame
                      • Copy runcommand line to emulators.cfg
                      • Supracan
                      supracan = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame/mame_libretro.so --config /opt/retropie/configs/supracan/retroarch.cfg %ROM%"
                      default = "supracan”
                      • NES-Datach
                      nes_datach = "/opt/retropie/libretrocores/mame/mame nes datach -cart2 %ROM%"
                      default = "nes_datach"
                      Noted that for NES Datach does not work with the same method of Supracan, using lr-mame just brings it to the NES system (not the Datach - subsystem of NES), at that point you should choose Datach rom and insert cart 2 (for example: dtc_dbz - Datach Dragon Ball game manually).
                      So I found out another way is using the mame binary with no-nag screen. On the other way, you also can use your MAME stadalone just adjust your file location. The disadvantage is that you cannot utilize Retroarch features but you can set combo keys for reset, load/save state, exit… via MAME tab —> controls easily)
                      Download link:
                      https://drive.google.com/drive/folders/0B_hdh1Ds66TvflV4alVlSzNIbDh3a0R6aFczYlJBc2t2STJ4U0tJS2FOTEZPdTdOWVIwYk0
                      • Download file mame225_x86_64-nonag_crvision.tag.gz from this link above
                      • Extract and rename from mame225_x86_64-nonag_crvision to mame
                      • Copy renamed file to /opt/retropie/libretrocores/mame, copy for Linux 64bit, I have tested carefully)
                      *** Artworks, fallback artworks, shaders and other features of official MAME work perfectly aa they are in official MAME.
                      This method can be applied to any systems (except system which uses many layer including cart1, cart2 like NES Datach).
                      If you update your script, it could be such a great news.
                      Enjoy!
                      • FollyF
                        Folly @hhtien1408
                        @hhtien1408
                        Thanks !
                        Seems you made a good description.
                        If I have some energy left, I will look into it some more.
                        I will add the idea of implementing into post 1.
                        You have to keep in mind that if I could implement it, the config structure has to be somewhat the same as we are using now with using lr-mess and mame.
                        So I have to look at that too then.
                        Right now there are other things that have more priority.
                        So can't really tell when I am going to try this.
                        DTEAMD H 2 Replies Last reply Reply Quote 0
                        • DTEAMD
                          DTEAM @Folly
                          @folly
                          Hi Folly,
                          Thank you for the gamelists. I'm happy to read you have done It fast. I'm pretty busy with real life stuff, that's why I'm in and out from the forum. I've put back all videos and pictures in the good directories on the Google Drive. I did'nt add channelf and pv1000 because they are now proprely supported by Screenscrapper.
                          If this is not working properly, just let me know
                          • FollyF
                            Folly @DTEAM
                            @dteam
                            Super, thanks for letting me know !
                            I will test it.
                            At the moment busy with version 2.2 .
                            I just added a part that will be integrated in the generated module-scripts
                            it will sort the emulators.cfg when a module-script is installed.
                            Just tested it and it works really nice.
                            I also added the BASENAME lines that I discovered trying supracan with mame.
                            These lines should work on more systems, no doubt about that.
                            I will test some other systems how they react.
                            Perhaps I will also convert the line names so we can understand the lines better on what they do.
                            • DTEAMD
                              DTEAM @Folly
                              @folly
                              For supracan, I remember that only the first game worked. Has it changed? I never had issues to load that emulator.
                              FollyF H 3 Replies Last reply Reply Quote 0
                              • FollyF
                                Folly @DTEAM
                                @folly
                                Indeed, seems that not all games will work properly.
                                But that's not the interesting part to it.
                                What's interesting, though, is that I now discovered runcommand lines that should be added to the script.
                                I just found a way to do the same with lr-mess without even using valerino's script.
                                I have to look into this deeper but it seems quite a discovery because everywhere they say that this can't be done.
                                So I think I might found the secret to it.
                                Did the same with lr-mame, but I have no luck up till now.
                                Perhaps I should do a source install for that.
                                So @hhtien1408 I have found a way to run supracan with lr-mess too.
                                So here is a picture of boomzoo :
                                • FollyF
                                  Folly @DTEAM
                                  @dteam
                                  As far as I can see, the discovered lines can't be used for our own created plaforms like :
                                  all_in1
                                  classich
                                  konamih
                                  tigerh
                                  and perhaps more
                                  So I want to use an if function for that.
                                  When doing so I found an issue with the tigerh.
                                  This seems to be a mame system Tiger-Heli.
                                  Now using the if function can lead to a problem.
                                  Can we consider to rename tigerh to tigerhh or tiger-hh ?
                                  Perhaps we can do the same with classic-hh and konami-hh.
                                  hh = handheld
                                  Let me know what you think about that.
                                  • DTEAMD
                                    DTEAM @Folly
                                    @folly
                                    I have no problem with that. You can rename them.
                                    • DTEAMD
                                      DTEAM
                                      This is great if it works
                                      Another question. Do you think It's doable to create a default mame.ini per system? Like they do with Retroarch
                                      see: https://docs.mamedev.org/commandline/commandline-all.html#mame-commandline-createconfig
                                      • FollyF
                                        Folly @DTEAM
                                        @folly
                                        Ok if I have to I will let you know.
                                        • FollyF
                                          Folly @DTEAM
                                          I hope so. I already have problems again with the lr-mess lines as supracan needs no bios.
                                          But coleco does, seems difficult to understand every time.
                                          Well, not sure how to do this !
                                          I have to dig in that.
                                          Can't promise anything, I have a real life too you know, haha :-)
                                          • FollyF
                                            Folly @DTEAM
                                            @dteam
                                            The downloads work ok they should work for all systems now.
                                            Tested a few systems and those were fine.
                                            Although this works fine I don't think updating will work.
                                            I think the gdrivedl.py script looks for existing filenames, but doesn't check if it's different or not.
                                            So if you want to update files you would have to manually remove those files and do the download again.
                                            If I can I will try to find a fix for this.
                                            I found a duplicate in the wrong directory, you can remove it if you want to :
                                            ./gamate/media/emulationstation/gamelist.xml
