    2.3k Posts 37 Posters 8.8m Views
    • FollyF
      Folly @DTEAM
      @dteam
      Confusing, but yes indeed, with the normal -cart lines they do load properly.
      I have had that working too, earlier on.
      But some games don't work as they should and sound is missing too.
      Do you have that same problem ?
      I was thinking the lr-mame_libretro.so way booted them better.
      Btw. I also tried with the mame-basename without succes, and yes I added /home/pi/RetroPie/roms/supracan in mame.ini .
      It seems it is not loading the rompath from the mame.ini.
      Forcing it in the commandline is working now using this :
      /opt/retropie/emulators/mame/mame -hash /opt/retropie/emulators/mame/hash -rompath /home/pi/RetroPie/roms/supracan -v -c supracan sangofgt
      I will test this part again on where it is going wrong.
      I did have a go again with with the lr-mame_libretro.so.
      No luck with the lr-mame_libretro.so nightly on pi4, it seems a 64bit one, and I run 32bit OS.
      So tried on my x86_64 ubuntu 20.04.
      Well boomzoo loaded, but others, no.
      DTEAMD H 2 Replies Last reply Reply Quote 0
      • DTEAMD
        DTEAM @Folly
        No luck with the lmame_libretro.so nightly on pi4, it seems a 64bit one, and I run 32bit OS.
        Like you, It doesn't work on my side for all games. I played with UI parameters and everything stopped working ! The 5 options above are the best ones for me.
        For
        mame-basename = "/opt/retropie/emulators/mame/mame -v -c supracan %BASENAME%"
        It works well for me. It's strange if it doesn't work on your side
        Seems to be a picky emulator.
        I'll retry hhtien1408 solution
        • FollyF
          Folly @DTEAM
          @dteam
          Seems the mame basename line doesn't work on both x86_64 and the pi4.
          But it works if I force the rompath.
          Where is your mame.ini located ?
          Mine is in :
          /home/pi/RetroPie/roms/mame/mame.ini
          • DTEAMD
            DTEAM @Folly
            It works on my Pi4
            in
            opt/retropie/configs/mame
            new edit:
            I added the location in my comment above
            • FollyF
              Folly @DTEAM
              @dteam
              Perfect !
              That works !
              Just tried the lr-mame_libretro.so nightly on my x86_64 renaming it as /opt/retropie/libretrocores/lr-mess/mess_libretro.so
              It just runs trough the runmess.sh script just like mess_libretro.so does.
              The file-size is a bit different but other than that it's looks the same package but just the name is different.
              • DTEAMD
                DTEAM @Folly
                @folly
                Good to know
                • H
                  hhtien1408 @DTEAM
                  @dteam Ok. Because I use softlists and cart type so I do not need -cart. All roads lead to Roma in the end. Different methods, same result. All supracan games should work as they are.
                  • H
                    hhtien1408 @Folly
                    @folly Sound weird. Do you download the suggested lr-mame nightly I gave you download link? Do you use the same method with me via softlist and cart type chosen? I do not use automatic script just do manually. It should work under Ubuntu. Maybe you miss some points on the road.
                    • H
                      hhtien1408 @DTEAM
                      @folly
                      Good to know
                      Thanks for letting me know. I will try run_mess.sh when I have free time later.
                      • H
                        hhtien1408 @hhtien1408
                        @Folly @DTEAM @dmmarti
                        Here are some pictures for my Retropie.
                        ![Pictures](https://ibb.co/k3rgyzQ
                        https://ibb.co/xSLPgTG
                        https://ibb.co/9vjVTPn
                        https://ibb.co/ZGL714N
                        https://ibb.co/bgcVyK6
                        https://ibb.co/bWczbyM
                        https://ibb.co/2WW0yMf
                        https://ibb.co/XZjcjbk
                        https://ibb.co/tY7kSpJ
                        https://ibb.co/phXKtQH)
                        • FollyF
                          Folly @hhtien1408
                          @hhtien1408 said in Development of module-script generator for lr-mess and mame standalone:
                          I tried as you suggested, but it seems i am missing something here.
                          Not sure what though.
                          Don't have that much time to try every time, I will try again later.
                          Btw. how good are you games running ?
                          • H
                            hhtien1408 @Folly
                            @folly perfect as it used to be in official MAME. Tested! See some pictures above for fun!
                            • FollyF
                              Folly @hhtien1408
                              @hhtien1408
                              Pictures are looking good :-)
                              Can you check your sha1sums with mine ?
                              pi@raspberrypi:~/RetroPie/roms/supracan $ sha1sum *
                              d642db0ff9bb4986d62b4676da31e536e9595058  boomzoo.zip
                              7cc99d26a1a3062fe8869d6d99eb1bd914fb54b0  gamblord.zip
                              56e71e6f6f8a7ab0eb1af44dbe0eaf9aad8e75a2  jttlaugh.zip
                              3c3f5ba50a3e3062eb7536168341b8866de858ab  magipool.zip
                              5588e33b23d61781428a9bb953b1d07a3b274501  monopoly.zip
                              ca92963db119fe94455532c2fcb9c76f98ef0eb5  sangofgt.zip
                              113fc81d6f46a822d73c759dba3dda58397797d8  slghtsag.zip
                              42e48389323247d9e3806c2fdcbe2aaa1a34a946  sonevil.zip
                              d6712a946b80cb22c4c49b78bb2a29f4408f8ec6  speedyd.zip
                              0b5ca6c00d9040918afdb60a5af446718426f9d3  staiwbbl.zip
                              • H
                                hhtien1408 @Folly
                                @folly If you download from MAME Softlist 0.202 archive, they should be the same. I will check SHA later and tell you results soon.
                                • DTEAMD
                                  DTEAM @hhtien1408
                                  hhtien1408 about 4 hours ago
                                  @hhtien1408
                                  You don't need to download the softlist. It's already in / opt / retropie / emulators / mame / hash with the latest standalone version of MAME if you updated it.
                                  The problem is that MAME points there but not Lr-Mess and maybe also lr-MAME. You need to force them to go there or "cut and paste" the hash files into the appropriate folders for lr-Mess and / or lr-mame (only if you want to use softlists - not an obligation - advantage = cheat codes and MAME artworks).
                                  Do you have sound with your Supracan games.
                                  I have no sound on my side
                                  • H
                                    hhtien1408 @DTEAM
                                    @dteam Could you share me your compiled mame standalone you are using to test?
                                    I would like to use script run_mess.sh without using softlist just for my trial.
                                    No sound with all games of supracan system due to emulator even with the lastest official MAME 0.232.
                                    Thanks!
                                    • DTEAMD
                                      DTEAM @hhtien1408
                                      @dteam thanks a lot. Could you share me your compiled mame standalone you are using to test? Thanks!
                                      Now, I'm using MAME 0.229 on my Pi4 (usually, I update it from source). If I do the update, it will be 0.332 0.232 probably.
                                      • H
                                        hhtien1408 @DTEAM
                                        @dteam 232 not 332. Could you share me your current version?
                                        • DTEAMD
                                          DTEAM @hhtien1408
                                          @hhtien1408
                                          sorry my mistake. My current version is MAME 0.229
                                          • DTEAMD
                                            DTEAM @DTEAM
                                            @hhtien1408 @Folly
                                            For Datach, I'm able to run it with those lines:
                                            mame-system-nes_datach-cart = "/opt/retropie/emulators/mame/mame -v -c nes datach -cart2 %ROM%"
                                            mame-system-nes_datach-cart-autoframeskip = "/opt/retropie/emulators/mame/mame -v -c -autoframeskip nes datach -cart2 %ROM%"
                                            I'm not able to run it with Lr-Mess and softlist for now
                                            FollyF 2 Replies Last reply Reply Quote 1
