    2.2k Posts 36 Posters 7.0m Views
    • F
      Folly @DTEAM
      nes datach
      Perhaps I will try and implement this in the 2v2 version.
      I already have done some work on 2v2.
      There are many thing I want to change or add in this version.
      Also adding just lines for specific systems.
      Problem, for now, is that the if functions are at the moment coming inside the generated module-scripts.
      I want these if functions outside the generated module-scripts. Perhaps I can find a way.
      This can be done in a similar way for nes detach, I think.
      Perhaps nes detach will work on lr-mess with my discovered lr-mess direct line.
      Maybe I will have some time to test that.
      We will have to see how it goes.
      edit:
      The mame lines work for me too.
      Tested some experimental lr-mess direct lines, not working right now.
      • F
        Folly @DTEAM
        @dteam
        I got it working with lr-mess.
        The trick was, it has to find the hash tables !
        Otherwise it won't work.
        I had a look in the the original lr-mess module-script.
        Hash tables for lr-mess have to be in /home/pi/RetroPie/BIOS/mame/hash/*.xml.
        It seems lr-mess looks for them in that directory.
        I created a link from : /opt/retropie/emulators/mame/hash
        Copying will also work, I think.
        Then I used a direct lr-mess line, which I plan to add in 2v2.
        This is the modified one for nes_detach :
        lr-mess_nes_datach = "/opt/retropie/emulators/retroarch/bin/retroarch --config /opt/retropie/configs/nes/retroarch.cfg -v -L /opt/retropie/libretrocores/lr-mess/mess_libretro.so 'nes datach -cart2 %ROM%'"
        • DTEAMD
          DTEAM @Folly
          @folly
          To play those games (Datach) you must enter barcodes. If you go in UI Mame menu in Barcode Reader. Go in "new barcode" . Enter the code with your keyboard and after, go down to "Enter Code" and press enter or B button. Your barcode will be activated.
          F H 2 Replies Last reply Reply Quote 0
          • F
            Folly @DTEAM
            @dteam
            Ok, that worked in lr-mess.
            Seems we have to do a lot of translation with RetroArch if we want to play.
            I have already add that in 2v2.
            The generated module-script will add it if it's not there.
            Still, I have to work on the naming of the runcommandlines, though.
            I had improved it a bit, but I am not satisfied and I have an issue because if the name in emulators.cfg doesn't begin with lr- the required dev/shm/retroarch.cfg for the libretro-core is not loaded.
            So I have to take a second look at that.
            • F
              Folly
              Like datach there seems to be also a :
              • ade
              • kstudio
              • ntbrom
              Tried a few things, but can't get it running.
              • DTEAMD
                DTEAM @Folly
                @folly
                i'm working on a gamelist.xml for Datach
                • DTEAMD
                  DTEAM @DTEAM
                  @folly
                  @hhtien1408 @Folly
                  here's the new gamelist.xml with media for Datach
                  It's better than I thought. Don't be fooled by the quality of my photos. It's better than they appear
                  • F
                    Folly
                    @DTEAM
                    Really nice gamelist !
                    Using the name "nes_datach" is really appropriate, but I am not so sure how to implement this into the script.
                    I have been trying to extract some info about "nes_datach".
                    Not sure if I can use this in the script, but with this command I can extract these :
                    /opt/retropie/emulators/mame/mame -listfull | grep slot | grep nes
                    nes_cart_slot     "NES Cartridge Slot"
                    nes_ntb_slot      "NES NTB Cartridge Slot"
                    nes_ade_slot      "NES Aladdin Deck Enhancer Cartridge Slot"
                    nes_datach_slot   "NES Datach Cartridge Slot"
                    nes_ks_slot       "NES Karaoke Studio Expansion Slot"
                    nes_cart_slot -> normal cartridge slot
                    nes_ks_slot -> not a cartridge but an expansion slot
                    ( not really sure how to add some slots, because we have different types and names ! )
                    With this command we can list all slots of all systems, perhaps we can find something interesting with this :
                    We can also use this plain command or using it with adding a system :
                    /opt/retropie/emulators/mame/mame -listslots
                    This link shows some examples with Amstrad cpc6128 :
                    https://wiki.mamedev.org/index.php/Driver:Amstrad
                    Here they show how to add an extension, but with nes -exp wasn't recognised.
                    Just like the -listmedia option, using this :
                    /opt/retropie/emulators/mame/mame -listslots nes
                    Will reveal that you can use the -nes_slot option. ( I don't know what parameter to add, though )
                    Well I stop for now with the information.
                    It's nice knowing, a bit, how this structure works.
                    • H
                      hhtien1408 @DTEAM
                      @dteam Fucking awesome. Thanks for your sharing images and video scraped for gamelist!
                      Which theme can I apply for? Carbon?
                      Could you send me system theme and loading screen for Datach? If possible, the whole theme you are using? I am very impressed by your theme!
                      F DTEAMD 2 Replies Last reply Reply Quote 0
                      • H
                        hhtien1408 @DTEAM
                        @folly
                        For your reference about Datach Barcodes for Dragon Ball and other games in this system
                        https://retrostuff.org/2014/02/14/bandai-datach-barcodes-for-mess/
                        For other Datach games, scroll down to the end (Related posts)
                        https://mamedev.emulab.it/etabeta/2014/02/12/barcode-scanning/
                        • H
                          hhtien1408 @Folly
                          @dteam
                          English translation rom? Where to download? Or you use IPS patch?
                          • F
                            Folly @hhtien1408
                            @hhtien1408 said in Development of module-script generator for lr-mess and mame standalone:
                            @dteam
                            All info is in this thread, you should use this post :
                            https://retropie.org.uk/forum/topic/28461/translate-games-on-the-fly/10
                            Add the lines to your /opt/retropie/configs/all/retroarch.cfg
                            If a libretro-core is used you can press the hotkey "t" and things will be translated on the fly.
                            Press again and, if all goes well, you can play further.
                            For security, you could make a saving before translating if that's possible.
                            Edit :
                            Read from here to use the joystick to translate the picture :
                            https://retropie.org.uk/forum/topic/28461/translate-games-on-the-fly/25
                            • F
                              Folly @hhtien1408
                              You can manually download those here :
                              https://drive.google.com/drive/folders/1f_jXMG0XMBdyOOBpz8CHM6AFj9vC1R6m
                              You can place them in :
                              ~/RetroPie/roms/nes_datach/gamelist.xml
                              ~/RetroPie/roms/nes_datach/media.................etc
                              • DTEAMD
                                DTEAM @hhtien1408
                                You can use my cygnus_modified theme and copy & paste my es_systems.cfg in your /opt/retropie/configs/all/emulationstation folder
                                see:
                                https://drive.google.com/drive/folders/1bfuYF7Ij_dhNc9b8bVCS6I22XiEmP7rv
                                For Carbon, you must add a logo by your own
                                • H
                                  hhtien1408 @DTEAM
                                  Thanks a lot!
                                  • DTEAMD
                                    DTEAM @Folly
                                    Is It the same thing for MSX?
                                    • F
                                      Folly @DTEAM
                                      It seems to work.
                                      For moonsound I added the yrw801.rom from openmsx to msx_moonsound.zip so it loaded the second time.
                                      Option -centronics seems to work also.
                                      I hope you see the picture here. ;-)
                                      pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listslots hbf700p
                                      SYSTEM           SLOT NAME        SLOT OPTIONS     SLOT DEVICE NAME
                                      hbf700p          centronics       ap2000           Epson ActionPrinter 2000
        chessmec         The ChessMachine EC
        covox            Covox Speech Thing
        covox_stereo     Covox (Stereo-in-1)
        ex800            Epson EX-800
        lx800            Epson LX-800
        lx810l           Espon LX-810L
        p72              NEC PinWriter P72
        pl80             COMX PL-80
        printer          Centronics Printer
        samdac           SAMDAC
                                                       cartslot1        bm_012           MSX Cartridge - BM-012
        moonsound        MSX Cartridge - MoonSound
                                                       cartslot2        bm_012           MSX Cartridge - BM-012
                                                       fdc:0            35dd             3.5" double density floppy drive
        35ssdd           3.5" single-sided double density floppy drive
                                      pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame hbf700p -cartslot1 moonsound
                                      yrw801.rom NOT FOUND (tried in msx_moonsound hbf700p)
                                      Fatal error: Required files are missing, the machine cannot be run.
                                      pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame hbf700p -cartslot1 moonsound #ok after adding the rom !
                                      Average speed: 94.10% (59 seconds)
                                      pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame hbf700p -cartslot1 bm_012
                                      midi_v1.00.u4 NOT FOUND (tried in msx_cart_bm_012 hbf700p)
                                      pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame hbf700p -centronics chessmec
                                      74s288.1 NOT FOUND (tried in chessmachine hbf700p)
                                      74s288.2 NOT FOUND (tried in chessmachine hbf700p)
                                      74s288.3 NOT FOUND (tried in chessmachine hbf700p)
                                      74s288.4 NOT FOUND (tried in chessmachine hbf700p)
                                      I tried to load moonsound also with the option -cartridge1because I wanted to know if the options are the same thing :
                                      pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame hbf700p -cart1 moonsound
                                      Fatal error: Device MSX Cartridge slot load (-cartridge1 moonsound) failed: File not found
                                      So option -cartridge1/-cart1 isn't the same as -cartslot1 !
                                      • F
                                        Folly
                                        @DTEAM
                                        Picture from the File Manager section :
                                        Picture from the Slot Devices section :
                                        • H
                                          hhtien1408 @Folly
                                          Super Acan Magazine
                                          https://archive.org/details/acan-special-issue/page/84/mode/2up
                                          NeoGeo CD Magazine
                                          https://archive.org/details/013-neo-geo-cd
                                            JimmyFromTheBay
                                            Chaps, absolutely massive kudos on all this. I'm beyond thrilled to be able to play stuff like CD-i (Hotel Mario at last!) and Super Cassette Vision on my Pi, not to mention all the systems I was running in AdvMESS on my Pi3 which now don't work on the Pi4 but have been rescued by all these wonderful lr-mess forks.
                                            (I'm currently working myself up to the daunting-looking task of setting up konamih and tigerh handhelds. The tutorial is tangling my brain.)
                                            A quick couple of pleas for stuff that's currently got me stumped:
                                            (1) Any chance of adding a coco3 fork? As far as I can tell nothing emulates it on the 4, and it's got a few cool games - it was the original home of Donkey Kong Remix.
                                            (2) I can't for the life of me figure out what BIOS files lr-mess-archimedes wants. The current MAME ROMset has nothing called "archimedes.zip" in it and I've got various things with "risc" in their names in my BIOS folder but I still get the dreaded Box With Blurry Word In The Middle Crash. Any clues?
                                            (3) Quite a few systems (most notably coco and dragon32, for me) are currently sort-of functional, which is to say that everything appears to work and games load, but then don't run properly. (eg The King/Donkey King, which keeps looping back to the menus when you try to choose the difficulty.)
                                            I imagine this is a problem with lr-mess itself rather than the system-specific forks, but if lr-mess gets updated to fix it will we have to install all the individual systems again?
                                            DTEAMD F 2 Replies Last reply Reply Quote 0
