    2.3k Posts 37 Posters 8.8m Views
    • DTEAMD
      DTEAM @Folly
      @folly
      No, that's perfect. You added that in your post above for Buzz.
      • FollyF
        Folly
        @BuZz
        Have you been able to look into it ?
        We would like to know if we can take it to a next step and make a pull request.
        If you are not comfortable with adding the script, please let us know why.
        Thank you for your reply.
          BuZz administrators @Folly
          @folly Not in detail as I'm super busy at the moment. I had a brief look at the github repository but as it currently I can't see it being incorporated sorry due to the module generating nature of it.
          It may be possible to do in a single module if that module had a gui that allowed handling of each system etc. You can always include this as an 3rd party repo in ext if you want though to make it easier for users to include.
          DTEAMD FollyF 2 Replies Last reply Reply Quote 0
          • DTEAMD
            DTEAM @BuZz
            @buzz said in Development of module-script generator for lr-mess and mame standalone:
            It already contains a GUI interface . Are you looking for that type of GUI? Everything can be found in the first post above (procedure and explanation)
            BuZzB 1 Reply Last reply Reply Quote 1
            • FollyF
              Folly @BuZz
              @buzz
              Thanks for your reply.
              I understand that your very busy at the moment.
              Hopefully we can discuss the solutions later when you have more time.
                BuZz administrators @DTEAM
                @dteam (also for @Folly) Thanks - I appreciate that. However, I see the creation of automatic scriptmodules based on this to not be the ideal solution, and will be problematic (lots of dynamically created modules handled outside of git, which could break if a change was made to RetroPie-Setup, and it just doesn't feel like the right solution to me).
                I would prefer it to be included in a way that a single module handles the configuration for all the mess systems, without creation of scriptmodules etc. I will look at this though when I have a chance and see if I can replicate some of the basic functionality in a different way.
                BTW - the contributions are appreciated and this can be handled an external repo if needed (additional retropie module repositories can be checked out into the ext folder).
                We have a lot of code in RetroPie, and a lot of contributions end up being unmaintained, so I have to be careful what is accepted and what isn't based on whether it's the correct implementation, maintainability, and so on. As often it comes down to me and a few other devs to keep everything working.
                FollyF 1 Reply Last reply Reply Quote 2
                • FollyF
                  Folly @BuZz
                  @buzz
                  Ok, I understand.
                  I have no problem using the ext.
                  Only problem is that 3rd party repository's cannot be installed from within the RetroPie-Setup as there is no module-script for it that can download these 3rd party repositories.
                  I would like to see something like the esthemes.sh that would contain the links to these 3rd party repositories.
                  So it can download them to the ext directory.
                  That way it's much easier for people to install without using commands or ssh.
                  I have already build such a module-script that will download only the .sh files from a 3rd party repos to theextdirectory.
                  And, it will not download a specific .sh filename if there is already the same filename in the RetroPie-Setup.
                  This is added to prevent the duplicate error.
                  You can check the module-script over here :
                  https://github.com/FollyMaddy/RetroPie-Share/blob/main/00-scriptmodules-00/supplementary/add-ext-repos.sh
                  It would we nice if this,or something like this, could be implemented.
                  That way we increase our main purpose of preserving the knowledge of old computers.
                  It basically means that we can create a win-win situation here.
                  Can you let me know how you feel about that direction.
                  Ps.
                  Using the ext part would be an concession on our part.
                  Which concession are you be willing to make here ?
                  • DTEAMD
                    DTEAM @Folly
                    @dteam
                    Are you able to make artwork for the Atari Portfolio ?
                    For example only the screen.
                    Done ! Here it is !
                    You have three views (with computer, zoom on screen and without artwork)
                    FollyF 2 Replies Last reply Reply Quote 1
                    • FollyF
                      Folly @DTEAM
                      @dteam
                      Superb !
                      Will test asap ;-)
                      Just updated the artwork from within the script.
                      The update worked and was lightning fast, perfect !!!
                      Running the game, looks really cool now :-)
                      • DTEAMD
                        DTEAM @Folly
                        @folly
                        I am glad to hear that. Found a picture was not a walk in the park. I prefer an image with a higher definition, but not so bad for an image from the web.
                        • FollyF
                          Folly @DTEAM
                          @dteam
                          In time I will dig up my original porfolio's.
                          Maybe I can make some nice high resolution photo's of them.
                          • DTEAMD
                            DTEAM @Folly
                            @folly
                            It takes a lot of time to do a "MAME artwork" . If you like this one , I suggest to keep that one.
                            • FollyF
                              Folly @DTEAM
                              @dteam
                              In that case,
                              I am quite happy with it.
                              Thank you for making it happen !
                              • DTEAMD
                                DTEAM @Folly
                                @folly
                                If you have time, send me a photo with a uniform background and I'll see what I can do. But I'm not sure I'll do it quickly.
                                FollyF 3 Replies Last reply Reply Quote 1
                                • FollyF
                                  Folly @DTEAM
                                  @dteam
                                  I have to dig them up first that will take some time too.
                                  No rush, in time, I will see if I can send some photo's.
                                  That would be great if we could improve this way ;-)
                                  ps, have to go now, later !!!
                                  • FollyF
                                    Folly @DTEAM
                                    @dteam
                                    I have made some pictures, but it's quite difficult to get a good result.
                                    The biggest problem is that the screen reflects images as a mirror and I have to have good light with good white background.
                                    I am hoping to get some better results !
                                    This is my best image up till now (reduced quality and size for upload) :
                                    • FollyF
                                      Folly @DTEAM
                                      @dteam
                                      Today I made a great picture and used gimp to get it even better.
                                      Still have to do the zoom version.
                                      This is how it looks like ?
                                      I already edited the artwork layout for this one :
                                      (Do you like it too ?)
                                      • DTEAMD
                                        DTEAM @Folly
                                        @folly
                                        Very nice!
                                        You should add a small drop Shadow effect (#5). You will have a deepness effect for the screen (more realistic). Where can I get it!!!
                                        • FollyF
                                          Folly @DTEAM
                                          @dteam
                                          Here is the file :
                                          https://www66.zippyshare.com/v/w9W7OLDW/file.html
                                          Don't know how to add the small drop shadow effect.
                                          Can you add it ?
                                          • DTEAMD
                                            DTEAM @Folly
                                            Here : https://www12.lunapic.com/editor/
                                            Border section ---> dropShadow
                                            Scrollbar = 5
