    2.2k Posts 36 Posters 6.6m Views
    • F
      Folly @JimmyFromTheBay
      @jimmyfromthebay
      Have you sent the originals, not resized or something like that ?
      I tried to push the nice one into perspective but I can't get it to work.
      I have to use some other tool.
      Here is what it looks like when I place the nice one over the old one.
      There is so much difference as you can see in the next picture.
      jamrom2J J 2 Replies Last reply Reply Quote 0
      • jamrom2J
        jamrom2 @Folly
        @folly Hi. Not sure you're the one to ask, but I'm trying to get lr-mess-dragon32-cass (and any other version) to work. I have the d32.rom and ddos10.rom (zipped and unzipped) placed in /home/pi/RetroPie/BIOS per the docs (https://retropie.org.uk/docs/Dragon/). But I keep getting errors in my runcommand.log file that says they are missing.
        07NOT FOUND (tried in dragon32)
        ddos10.rom NOT FOUND (tried in dragon_fdc dragon32)
        [libretro ERROR] d32.rom NOT FOUND (tried in dragon32)
        [INFO] [Environ]: SET_MESSAGE: `¦b07ror: Required files are missing, the machine cannot be run.
        [libretro ERROR] Fatal error: Required files are missing, the machine cannot be run.
        Do I have them in the right location for the lr-version? Where is dragon_fdc? The docs are really for Xroar which works fine with what I have.
        Thank you!
        • F
          Folly @jamrom2
          @jamrom2
          Did you use the valerino module-script ?
          Edit :
          Looked at the name of the valerino's script again it lacks cass.
          So you are using an older generated module-script of my script generator.
          Then I think you have to put your BIOS file in :
          /home/pi/RetroPie/BIOS/mame
          I changed it long ago into this so that both mame and lr-mess can use the same bios files.
          Second advantage is that the are now seperated from the root BIOS directory.
          So you should try that directory.
          I checked my emulators.cfg lines and I have dragon32 running with external ram because otherwise some games did't work.
          You can install this from the front-end from the special systems with slotdevices.
          • jamrom2J
            jamrom2 @Folly
            @folly yes, but I've since switched back over to the correct RetroPie repository. I had issues with updating because his script left me on 4.7.11.
            I have a bunch of other emus from the Mess build running without issue. If that matters.
            • F
              Folly @jamrom2
              @jamrom2
              Strange, I have updated my post, have a look at that first.
              Can you try the other BIOS directory first ?
              Check your runcommand.log and look at line 19 containing -rp, after the -rp you will have the path where the bios has to be in.
              • jamrom2J
                jamrom2 @Folly
                @folly \t_biosdir: /home/pi/RetroPie/BIOS
                In line 19 after the -rp the directory is the same as above. Maybe it's my BIOS files? I've pulled a few different one. The ones I have seem to work without issue on Xroar.
                here's my runcommand.log I tried two more d32.rom files. still the same.
                https://pastebin.com/hvtTZJ0k
                • F
                  Folly @jamrom2
                  @jamrom2
                  I will have a look at your log later.
                  My working bios sha1sums are :
                  pi@raspberrypi:~/Desktop/dragon32 $ sha1sum *
                  f2dab125673e653995a83bf6b793e3390ec7f65a  d32.rom
                  a8918c71d319237c1e3155bb38620acb114a80bc  ddos10.rom
                  27a2a6bf5c98fb69e174b927f240973033881826  dragon32.zip
                  77bb4c81d1078d7bd0b2378bbf831c007e2252ff  dragon_fdc.zip
                  • I
                    isidoro80
                    hi i have installed your script but i have problems. i want to install apfm1000 games. Your script created the folder opt / config / apfm1000 then I put the bios in home / pi / RetroPie / BIOS / mame; I put the zip files of the roms in / home / pi / RetroPie / roms / apfm1000. I tried all the various runcommand launch systems: lr-mess cmd; lr-mess; mame-cmd; etc ... if I try to start a retroarch rom it crashes and I have to force it to close. in the runcommand log file it says WARN ... driver not found .... what is the problem?
                    i have already installed lr-mess manually before trying your script to play arcadia games. arcadia games work very well. i dont understand why apfm1000 games don't work. the roms are correct.
                    F 2 Replies Last reply Reply Quote 0
                    • F
                      Folly @isidoro80
                      @isidoro80
                      Nice to hear that arcadia works oob for you.
                      I am not able to test your desired system at the moment.
                      When I am in the right place I will test it for you.
                      (over 11 hours, or so)
                      • jamrom2J
                        jamrom2 @Folly
                        @folly got it working... your BIOS file list there helped. From there I did a little more searching to find what I needed which was the answer. I needed to create two more .zip files with the names dragon32.zip and dragon_fdc.zip with the files in it listed like this...
                        dragon32.zip -- contains d32.rom, and ddos10.rom
                        dragon64.zip -- contains d64_1.rom , d64_2.rom , and ddos10.rom
                        dragon_fdc.zip -- contains ddos10.rom
                        This little list might need to be added to docs at some point. I know a lot of these Emus are very finicky as to what they need for BIOS files and how they need to be named.
                        I created the dragon32.zip file with what is listed above and it boots to a DragonDOS prompt. But no games run.
                        so... how do the games play? I have a ton of CAS based files. All that happens it the emulator goes to DOS.
                        Thanks for the help!
                        JamR
                        J F 3 Replies Last reply Reply Quote 0
                          JimmyFromTheBay @jamrom2
                          @jamrom2
                          With a .CAS file you need to load it. Most games will be in machine code so you need to type CLOADM. If you get an "FM ERROR" it was in BASIC, so you'd type CLOAD instead.
                          Most will autorun on loading, but if they don't you need to type EXEC for machine-code games or RUN for BASIC ones.
                          HOWEVER, if you're working from a Dragon DOS prompt you may find that games appear to have loaded but then don't run properly. That's because lots and lots of them really don't like the DDOS BIOS. The solution is to edit your EMULATORS.CFG to include this line:
                          lr-mess-system-dragon32-cass = "/home/pi/RetroPie-Setup/scriptmodules/run_mess.sh /opt/retropie/emulators/retroarch/bin/retroarch /opt/retropie/libretrocores/lr-mess/mess_libretro.so /opt/retropie/configs/dragon32/retroarch.cfg \dragon32 /home/pi/RetroPie/BIOS/mame -autoframeskip -ui_active -ext ram -cass %ROM%"
                          and run it from that. That should boot from the standard Dragon OS, not the disk one, and your games should work.
                          jamrom2J 1 Reply Last reply Reply Quote 1
                          • F
                            Folly @jamrom2
                            @jamrom2 said in Development of module-script generator for lr-mess and mame standalone:
                            Nice !
                            With mame and lr-mess you have to know how the computer works.
                            There isn't an autoboot by default. (although there are options that can be added into the commandline)
                            Read post one from this thread and look at @dmmarti 's google sheet, there you should find how to load the cas files.
                            And there are other posts on the forum on how to do it.
                            If you can't work it out then let me know, then I will look for it.
                            EDIT: Jimmy has already made a post for you.
                            Remember that the emulators.cfg line he proposes uses the BIOS/mame directory.
                            And... , as said earlier, you can just install that line from the front-end.
                            That way you have all emulators.cfg line including the mame and the lr-mess game-specific ones ;-)
                            I think mine is booting into basic and from there I insert the commands.
                            Sometimes you have to use the scroll-lock button to go into game-focus-mode.
                            Otherwise the keys will act as hotkeys.
                            JamR
                            Your welcome.
                            Please upvote post 1, if you think this is a good project ;-)
                              JimmyFromTheBay @Folly
                              @jimmyfromthebay
                              I got both of them from the artwork files on Mr Do's page.
                              • F
                                Folly @isidoro80
                                @isidoro80
                                I just tested apfm1000 for you.
                                For me it was the first time and it worked out the box with both lr-mess and mame.
                                I didn't even need a game.
                                I just created a dummy file rocketp.zip as a game file and it booted a rocket game by default.
                                So it should work.
                                Maybe you have wrong bios files.
                                I use this one :
                                pi@raspberrypi:~/RetroPie/BIOS/mame $ sha1sum apfm*
                                87fd4de8f8b3d2dbb65eb0d89f43e02a0543d743 apfm1000.zip
                                But looking at the mame log it seems I have a wrong bios file.
                                I wants this one within the zip :
                                apf_4000.rom SHA1(1110a234bcad99bd0894ad44c591389d16376ca4)
                                2021-09-29-190934_800x600_scrot-resized.png2021-09-29-190756_800x600_scrot-resized.png
                                I 3 Replies Last reply Reply Quote 0
                                • F
                                  @jimmyfromthebay said in Development of module-script generator for lr-mess and mame standalone:
                                  @jimmyfromthebay
                                  Thanks,
                                  I have tried with the warp transformation with better results.
                                  But I tried lr-mame2003 and after testing my leds are gone, no idea why.
                                  I will try something different, if I have the time.
                                  • F
                                    Folly @jamrom2
                                    Basically, when you download the correct mame bios files the are already named that way.
                                    And... the runcommand.log will give you the "names" of the zip files it's looking for.
                                    You can also use the command mame to list which bios files it needs with, for example :
                                    pi@raspberrypi:~/RetroPie/BIOS/mame $ /opt/retropie/emulators/mame/mame -listroms dragon32
                                    ROMs required for driver "dragon32".
                                    Name                                   Size Checksum
                                    d32.rom                               16384 CRC(e3879310) SHA1(f2dab125673e653995a83bf6b793e3390ec7f65a)
                                    ddos10.rom                             8192 CRC(b44536f6) SHA1(a8918c71d319237c1e3155bb38620acb114a80bc)
                                    • I
                                      isidoro80 @Folly
                                      @folly i have only apfm1000.zip. i use rom.zip it's wrong?
                                      • I
                                        isidoro80 @Folly
                                        This post is deleted!
                                        • I
                                          isidoro80 @Folly
                                          @folly now all right. The bios wrong. I have two questions. where do i find the mess gui commands? i can't navigate mess gui. apfm1000 only works with lr-mess cmd while with lr-mess basename it doesn't work. When should the different mess start options be used?
                                          DTEAMD F 2 Replies Last reply Reply Quote 0
                                          • DTEAMD
                                            DTEAM @isidoro80
                                            @isidoro80
                                            Try "select" and "Y" on your game pad (sometime it works for lr-mess).
