    2.3k Posts 37 Posters 9.1m Views
    • DTEAMD
      DTEAM @jamrom2
      @jamrom2
      Hard to see with my background. Is It easy for you to use different colors? brighter or white
      • I
        isidoro80 @Folly
        @folly which script you use? I try lr-mess-basename and lr-mess-cmd but not work. In the log read: error parsing game path and sustem name and driver not found.... I try lr-mess-system-apple2gsr1-flop1 but retroarch start and freeze. I download bios correct. Beyond pinball and dark logic are game apple2 not apple2gs. An example Apple2gs games are alienmd.zip airball.zip arknoid2.zip
        • jamrom2J
          jamrom2 @DTEAM
          @dteam how about this using colors from the INTV palette?
          DTEAMD 2 Replies Last reply Reply Quote 1
          • DTEAMD
            DTEAM @jamrom2
            @jamrom2
            Wow !!!
            • FollyF
              Folly @isidoro80
              @isidoro80 said in Development of module-script generator for lr-mess and mame standalone:
              (Btw. I have to make long hours this week, so perhaps I am not able to post.)
              I use lr-mess-system-apple2gsr1-flop1.
              Have you tried with mame ?
              You should post the runcommand.log on pastebin so we can have a look at it.
              • FollyF
                Folly @jamrom2
                @jamrom2 said in Development of module-script generator for lr-mess and mame standalone:
                @folly That pic you posted looks like what I was talking about. Those look like Apple II games being played on the Apple IIgs BIOS/system.
                The Apple IIgs was for lack of better comparison, similar in graphic level to an Amiga 500/1000. The Apple II(e) was similar to about an Atari 400/800.
                I'll help you more with this later, or tomorrow for sure. But that's a start. The previous script had them split right. I don't know if it's all that necessary to get every variant to the system up and running right away. But for sure, these two need to work separate of each other. I think the Apple II(e) games could be played on a GS model though. So you're not out of the realm of possibility.
                I'm no Apple expert.. but they are definitely different from each other.
                Indeed I used an "Apple II" games on the gsr1.
                Thanks for explaining, didn't know that they have better graphics like Amiga.
                Good that we have separated these systems from each other.
                Will try some real gs stuff later.
                Btw. nice theme stuff ;-)
                (I have to make long hours this week, so perhaps I am not able to post.)
                • I
                  isidoro80 @Folly
                  @folly ok later i post the log. i read https://docs.google.com/spreadsheets/d/1AQ28J9OUKg55R3d-TZkWO3GH50KjC2hHteCP1Bx59Ns/edit#gid=0
                  in third column rom extension... apple 2 does not work with zip files? for play dark logic e beyond pinball you use zip file or other?
                  FollyF jamrom2J 2 Replies Last reply Reply Quote 0
                  • DTEAMD
                    DTEAM @jamrom2
                    If you update your theme in Retropie Theme menu, you will get your logo. Thanks , Nice logo!!
                    For your Coleco logo, I would like to use it to replace the one for Super Game Module. Do you have time to add Super Game Module to your logo to replace the one below?
                    For logos and themes, we should move our discussion to Request for artists working on themes - needs for (lr-mess/MAME) additions
                    • jamrom2J
                      jamrom2 @DTEAM
                      @dteam
                      no prob. moved! Lol. I was kinda thinking the same
                      • DTEAMD
                        DTEAM @jamrom2
                        @jamrom2
                        Perfect!!
                        • FollyF
                          Folly @isidoro80
                          I tried bypinbll.zip on apple2ee and that booted just fine so .zip files should work too.
                          Just found some real apple2gs software and found Airball.zip .
                          I tried it on apple2gsr1 and used -flop3 because inside there is a .2mg and that is a 3.5'' double density image.
                          Both .2mg and .zip will work but my Airball.zip contained a subdirectory containing the .2mg file.
                          If you have that .zip file then that .zip file will not work.
                          So you have to repack it so it doesn't have the subdirectory.
                          Airball booted with both lr-mess and mame and the mouse worked.
                          How to play is another story, but once we run thing we will discover this.
                          Here is some more info about the media and the images.
                          Listing the slots will tell you what type of drives you have :
                          pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listslots apple2gsr1
                          etc......
                                           fdc:0            525              5.25" single density floppy drive
                                           fdc:1            525              5.25" single density floppy drive
                                           fdc:2            35dd             Apple/Sony 3.5 DD (400/800K GCR)
                                                            35hd             Apple/Sony 3.5 HD (Superdrive)
                                                            35sd             Apple/Sony 3.5 SD (400K GCR)
                                           fdc:3            35dd             Apple/Sony 3.5 DD (400/800K GCR)
                          And this will give you the media supported by the drives :
                          pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listmedia apple2gsr1
                          SYSTEM           MEDIA NAME       (brief)    IMAGE FILE EXTENSIONS SUPPORTED
                          apple2gsr1       floppydisk1      (flop1)    .mfi  .dfi  .dsk  .do   .po   .rti  .edd  .woz  .nib
                          apple2gsr1       floppydisk2      (flop2)    .mfi  .dfi  .dsk  .do   .po   .rti  .edd  .woz  .nib
                          apple2gsr1       floppydisk3      (flop3)    .mfi  .dfi  .hfe  .mfm  .td0  .imd  .d77  .d88  .1dd  .cqm  .cqi  .dsk  .ima  .img  .ufi  .360  .ipf  .dc42 .woz  .2mg
                          apple2gsr1       floppydisk4      (flop4)    .mfi  .dfi  .hfe  .mfm  .td0  .imd  .d77  .d88  .1dd  .cqm  .cqi  .dsk  .ima  .img  .ufi  .360  .ipf  .dc42 .woz  .2mg
                          Indeed, just like @jamrom2 said it's like the Amiga graphics :
                          2021-10-05-205339_800x600_scrot-resized.png 2021-10-05-205355_800x600_scrot-resized.png
                          2021-10-05-210204_800x600_scrot-resized.png 2021-10-05-211020_800x600_scrot-resized.png
                          I jamrom2J 2 Replies Last reply Reply Quote 0
                          • I
                            isidoro80 @Folly
                            @folly wow very good. i try but i can't play.
                            i post you runcommand.log of apple2ee and apple2gsr1. i test two game but retroarch freeze and i can't play the game
                            apple2ee lr-mess-floppy bypinball.zip
                            Parameters:
                            Executing: /home/pi/RetroPie-Setup/scriptmodules/run_mess.sh /opt/retropie/emulators/retroarch/bin/retroarch /opt/retropie/libretrocores/lr-mess/mess_libretro.so /opt/retropie/configs/apple2ee/retroarch.cfg pple2ee /home/pi/RetroPie/BIOS/mame -autoframeskip -ui_active  -flop1 "/home/pi/RetroPie/roms/apple2ee/bypinbll.zip" --verbose --appendconfig /dev/shm/retroarch.cfg
                            basename: unrecognized option '--verbose'
                            Try 'basename --help' for more information.
                            [.] parameters dump
                            \t_retroarchbin: /opt/retropie/emulators/retroarch/bin/retroarch
                            \t_messpath: /opt/retropie/libretrocores/lr-mess/mess_libretro.so
                            \t_config: /opt/retropie/configs/apple2ee/retroarch.cfg (+ /opt/retropie/configs/apple2ee/retroarch.cfg.add)
                            \t_cfg_directory: /opt/retropie/configs/apple2ee
                            \t_system: apple2ee
                            \t_biosdir: /home/pi/RetroPie/BIOS/mame
                            dirname: opzione non valida -- "a"
                            Try 'dirname --help' for more information.
                            dirname: opzione non valida -- "u"
                            dirname: opzione non valida -- "f"
                            \t_romdir: /home/pi/RetroPie/roms/apple2ee
                            \t/tmp/mess.cmd content: apple2ee -rp /home/pi/RetroPie/BIOS/mame -cfg_directory /opt/retropie/configs/apple2ee "-autoframeskip" "-ui_active" "-flop1" "/home/pi/RetroPie/roms/apple2ee/bypinbll.zip"
                            rm: impossibile rimuovere '/home/pi/RetroPie/roms/apple2ee/.cmd': File o directory non esistente
                            rm: impossibile rimuovere '/opt/retropie/configs/apple2ee/tmpconfig.add': File o directory non esistente
                            [.] launching: /opt/retropie/emulators/retroarch/bin/retroarch --verbose --config /opt/retropie/configs/apple2ee/retroarch.cfg --appendconfig /opt/retropie/configs/apple2ee/tmpconfig.add -L /opt/retropie/libretrocores/lr-mess/mess_libretro.so /home/pi/RetroPie/roms/apple2ee/.cmd
                            [INFO] RetroArch 1.9.7 (Git 8373ac6)
                            [INFO] Funzionalità:  NEON VFPv3 VFPv4
                            [INFO] Built: Sep 15 2021
                            [INFO] Version: 1.9.7
                            [INFO] Git: 8373ac6
                            [INFO] [Input]: Found input driver: "x".
                            [INFO] [Core]: Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-mess/mess_libretro.so"
                            [INFO] [Environ]: SET_VARIABLES.
                            [INFO] [Remaps]: Remap directory: "/opt/retropie/configs/apple2ee/".
                            [INFO] [Overrides]: Reindirizzare il file di salvataggio su "/home/pi/RetroPie/roms/apple2ee/.srm".
                            [INFO] [Overrides]: Reindirizzare il salva stato su "/home/pi/RetroPie/roms/apple2ee/.state".
                            [INFO] [Environ]: GET_LOG_INTERFACE.
                            [WARN] [Environ]: SYSTEM DIR is empty, assume CONTENT DIR /home/pi/RetroPie/roms/apple2ee/.cmd
                            [INFO] [Environ]: SYSTEM_DIRECTORY: "".
                            [libretro INFO] SYSTEM_DIRECTORY: /home/pi/RetroPie/roms/apple2ee/
                            [INFO] [Environ]: CORE_ASSETS_DIRECTORY: "/home/pi/.config/retroarch/downloads".
                            [libretro INFO] CONTENT_DIRECTORY: /home/pi/.config/retroarch/downloads
                            [INFO] [Environ]: GET_SAVE_DIRECTORY.
                            [libretro INFO] SAVE_DIRECTORY: /home/pi/RetroPie/roms/apple2ee/
                            [INFO] [Environ]: SET_PIXEL_FORMAT: XRGB8888.
                            [INFO] [CONTENT LOAD]: Il caricamento del contenuto è stato saltato. Le Implemenzioni verranno caricati in proprio.
                            [libretro INFO] Joystick map: disabled
                            [INFO] [Environ]: SET_INPUT_DESCRIPTORS:
                            [INFO] [SRAM]: Carico SRAM saltato..
                            [INFO] Versione delle API di libretro: 1
                            [INFO] Compilato contro API: 1
                            [libretro INFO] AV_INFO: width=640 height=480
                            [libretro INFO] AV_INFO: max_width=640 max_height=480
                            [libretro INFO] AV_INFO: aspect_ratio = 1.333333
                            [libretro INFO] AV_INFO: fps = 60.000000 sample_rate = 48000.000000
                            [INFO] [Audio]: Set audio input rate to: 48000.00 Hz.
                            [INFO] [Video]: Timings deviate too much. Will not adjust. (Display = 50.00 Hz, Game = 60.00 Hz)
                            [INFO] [Video]: Game FPS > Monitor FPS. Cannot rely on VSync.
                            [INFO] [Video]: Video @ 1920x1080
                            [INFO] [DRM]: Found 1 connectors.
                            [INFO] [DRM]: Connector 0 connected: yes
                            [INFO] [DRM]: Connector 0 has 33 modes.
                            [INFO] [DRM]: Connector 0 assigned to monitor index: #1.
                            [INFO] [DRM]: Mode 0: (1920x1080) 1920 x 1080, 60.000000 Hz
                            [INFO] [DRM]: Mode 1: (1920x1080) 1920 x 1080, 59.940201 Hz
                            [INFO] [DRM]: Mode 2: (1920x1080i) 1920 x 1080, 30.000000 Hz
                            [INFO] [DRM]: Mode 3: (1920x1080i) 1920 x 1080, 29.970100 Hz
                            [INFO] [DRM]: Mode 4: (1920x1080) 1920 x 1080, 50.000000 Hz
                            [INFO] [DRM]: Mode 5: (1920x1080i) 1920 x 1080, 25.000000 Hz
                            [INFO] [DRM]: Mode 6: (1920x1080) 1920 x 1080, 30.000000 Hz
                            [INFO] [DRM]: Mode 7: (1920x1080) 1920 x 1080, 29.970100 Hz
                            [INFO] [DRM]: Mode 8: (1920x1080) 1920 x 1080, 25.000000 Hz
                            [INFO] [DRM]: Mode 9: (1920x1080) 1920 x 1080, 24.000000 Hz
                            [INFO] [DRM]: Mode 10: (1920x1080) 1920 x 1080, 23.976080 Hz
                            [INFO] [DRM]: Mode 11: (1280x720) 1280 x 720, 60.000000 Hz
                            [INFO] [DRM]: Mode 12: (1280x720) 1280 x 720, 59.940201 Hz
                            [INFO] [DRM]: Mode 13: (1280x720) 1280 x 720, 50.000000 Hz
                            [INFO] [DRM]: Mode 14: (1024x768) 1024 x 768, 75.028580 Hz
                            [INFO] [DRM]: Mode 15: (1024x768) 1024 x 768, 70.069359 Hz
                            [INFO] [DRM]: Mode 16: (1024x768) 1024 x 768, 60.003841 Hz
                            [INFO] [DRM]: Mode 17: (832x624) 832 x 624, 74.551270 Hz
                            [INFO] [DRM]: Mode 18: (800x600) 800 x 600, 75.000000 Hz
                            [INFO] [DRM]: Mode 19: (800x600) 800 x 600, 72.187569 Hz
                            [INFO] [DRM]: Mode 20: (800x600) 800 x 600, 60.316540 Hz
                            [INFO] [DRM]: Mode 21: (720x576) 720 x 576, 50.000000 Hz
                            [INFO] [DRM]: Mode 22: (720x576i) 720 x 576, 25.000000 Hz
                            [INFO] [DRM]: Mode 23: (720x480) 720 x 480, 60.000000 Hz
                            [INFO] [DRM]: Mode 24: (720x480) 720 x 480, 59.940060 Hz
                            [INFO] [DRM]: Mode 25: (720x480i) 720 x 480, 30.001110 Hz
                            [INFO] [DRM]: Mode 26: (720x480i) 720 x 480, 29.970030 Hz
                            [INFO] [DRM]: Mode 27: (640x480) 640 x 480, 75.000000 Hz
                            [INFO] [DRM]: Mode 28: (640x480) 640 x 480, 72.808800 Hz
                            [INFO] [DRM]: Mode 29: (640x480) 640 x 480, 66.666664 Hz
                            [INFO] [DRM]: Mode 30: (640x480) 640 x 480, 60.000000 Hz
                            [INFO] [DRM]: Mode 31: (640x480) 640 x 480, 59.940475 Hz
                            [INFO] [DRM]: Mode 32: (720x400) 720 x 400, 70.081665 Hz
                            [INFO] [GL]: Found GL context: kms
                            [INFO] [GL]: Detecting screen resolution 1920x1080.
                            [INFO] [EGL] Found EGL client version >= 1.5, trying eglGetPlatformDisplay
                            [INFO] [EGL]: EGL version: 1.4
                            [INFO] [EGL]: Current context: 0x1c4ed98.
                            [INFO] [KMS]: New FB: 1920x1080 (stride: 7680).
                            [INFO] [GL]: Vendor: Broadcom, Renderer: V3D 4.2.
                            [INFO] [GL]: Version: OpenGL ES 3.1 Mesa 19.3.2.
                            [INFO] [GL]: Using resolution 1920x1080
                            [INFO] [GL]: Default shader backend found: glsl.
                            [INFO] [Shader driver]: Using GLSL shader backend.
                            [WARN] [GL]: Stock GLSL shaders will be used.
                            [INFO] [GLSL]: Found GLSL vertex shader.
                            [INFO] [GLSL]: Found GLSL fragment shader.
                            [INFO] [GLSL]: Linking GLSL program.
                            [INFO] [GL]: Using 4 textures.
                            [INFO] [GL]: Loaded 1 program(s).
                            [INFO] [udev]: Added Device Keyboard#0 CASUE CASUE USB Keyboard (/dev/input/event1) .
                            [INFO] [udev]: Added Device mouse#0 Logitech Lenovo USB Optical Mouse (/dev/input/event0) .
                            [INFO] [udev]: Added Device mouse#1 Sony Interactive Entertainment Wireless Controller Touchpad (/dev/input/event4) .
                            [INFO] [udev]: Pad #0 (/dev/input/event6) supports force feedback.
                            [INFO] [udev]: Pad #0 (/dev/input/event6) supports 16 force feedback effects.
                            [INFO] [Font]: Using font rendering backend: freetype.
                            [INFO] [Video]: Found display server: null
                            [INFO] [ALSA]: Using floating point format.
                            [INFO] [ALSA]: Period size: 768 frames
                            [INFO] [ALSA]: Buffer size: 3072 frames
                            [INFO] [ALSA]: Can pause: no.
                            [INFO] [Display]: Found display driver: "gl".
                            [INFO] [Playlist]: Caricamento dei file della cronologia: [/opt/retropie/configs/apple2ee/content_history.lpl].
                            [INFO] [Playlist]: Caricamento dei file della cronologia: [/opt/retropie/configs/apple2ee/content_music_history.lpl].
                            [INFO] [Playlist]: Caricamento dei file della cronologia: [/opt/retropie/configs/apple2ee/content_video_history.lpl].
                            [INFO] [Playlist]: Caricamento dei file della cronologia: [/opt/retropie/configs/apple2ee/content_image_history.lpl].
                            [INFO] [Playlist]: Caricamento file preferiti: [/opt/retropie/configs/apple2ee/content_favorites.lpl].
                            [INFO] [Playlist]: Written to playlist file: /opt/retropie/configs/apple2ee/content_history.lpl
                            [libretro INFO] Starting game from command line:apple2ee -rp /home/pi/RetroPie/BIOS/mame -cfg_directory /opt/retropie/configs/apple2ee "-autoframeskip" "-ui_active" "-flop1" "/home/pi/RetroPie/roms/apple2ee/bypinbll.zip"
                            [libretro INFO] ARGUV[0]=apple2ee
                            [libretro INFO] Game name: apple2ee, Game description: Apple //e (enhanced)
                            Error opening translation file English
                            Adding monitor screen0 (640 x 480) a:1.333333
                            [libretro INFO] SOURCE FILE: ../../../../../src/mame/drivers/apple2e.cpp
                            [libretro INFO] PARENT: apple2e
                            [libretro INFO] NAME: apple2ee
                            [libretro INFO] DESCRIPTION: Apple //e (enhanced)
                            [libretro INFO] YEAR: 1985
                            [libretro INFO] MANUFACTURER: Apple Computer
                            341-0027-a.p5 NOT FOUND (tried in a2diskiing apple2ee apple2e)
                            341-0028-a.rom NOT FOUND (tried in d2fdc apple2ee apple2e)
                            Fatal error: Required files are missing, the machine cannot be run.
                            [libretro INFO] RES:1
                            [libretro INFO] MAIN FIRST
                            [INFO] [Environ]: SET_GEOMETRY: 560x192, aspect: 1.333.
                            w:560 h:192 a:1.333333
                            /home/pi/RetroPie-Setup/scriptmodules/run_mess.sh: riga 89:  1458 Ucciso                  "$@"
                            apple2gsr1 lr-mess-flop3
                            Parameters:
                            Executing: /home/pi/RetroPie-Setup/scriptmodules/run_mess.sh /opt/retropie/emulators/retroarch/bin/retroarch /opt/retropie/libretrocores/lr-mess/mess_libretro.so /opt/retropie/configs/apple2gsr1/retroarch.cfg pple2gsr1 /home/pi/RetroPie/BIOS/mame -autoframeskip -ui_active  -flop3 "/home/pi/RetroPie/roms/apple2gsr1/1stltrwd.zip" --verbose --appendconfig /dev/shm/retroarch.cfg
                            [.] parameters dump
                            \t_config: /opt/retropie/configs/apple2gsr1/retroarch.cfg (+ /opt/retropie/configs/apple2gsr1/retroarch.cfg.add)
                            \t_cfg_directory: /opt/retropie/configs/apple2gsr1
                            \t_system: apple2gsr1
                            \t_romdir: /home/pi/RetroPie/roms/apple2gsr1
                            \t/tmp/mess.cmd content: apple2gsr1 -rp /home/pi/RetroPie/BIOS/mame -cfg_directory /opt/retropie/configs/apple2gsr1 "-autoframeskip" "-ui_active" "-flop3" "/home/pi/RetroPie/roms/apple2gsr1/1stltrwd.zip"
                            rm: impossibile rimuovere '/home/pi/RetroPie/roms/apple2gsr1/.cmd': File o directory non esistente
                            rm: impossibile rimuovere '/opt/retropie/configs/apple2gsr1/tmpconfig.add': File o directory non esistente
                            [.] launching: /opt/retropie/emulators/retroarch/bin/retroarch --verbose --config /opt/retropie/configs/apple2gsr1/retroarch.cfg --appendconfig /opt/retropie/configs/apple2gsr1/tmpconfig.add -L /opt/retropie/libretrocores/lr-mess/mess_libretro.so /home/pi/RetroPie/roms/apple2gsr1/.cmd
                            [INFO] Git: 8373ac6
                            [INFO] [Remaps]: Remap directory: "/opt/retropie/configs/apple2gsr1/".
                            [INFO] [Overrides]: Reindirizzare il file di salvataggio su "/home/pi/RetroPie/roms/apple2gsr1/.srm".
                            [INFO] [Overrides]: Reindirizzare il salva stato su "/home/pi/RetroPie/roms/apple2gsr1/.state".
                            [WARN] [Environ]: SYSTEM DIR is empty, assume CONTENT DIR /home/pi/RetroPie/roms/apple2gsr1/.cmd
                            [libretro INFO] SYSTEM_DIRECTORY: /home/pi/RetroPie/roms/apple2gsr1/
                            [libretro INFO] SAVE_DIRECTORY: /home/pi/RetroPie/roms/apple2gsr1/
                            [WARN] [DRM]: Couldn't get device resources.
                            [INFO] [EGL]: Current context: 0x2058d98.
                            [INFO] [Playlist]: Caricamento dei file della cronologia: [/opt/retropie/configs/apple2gsr1/content_history.lpl].
                            [INFO] [Playlist]: Caricamento dei file della cronologia: [/opt/retropie/configs/apple2gsr1/content_music_history.lpl].
                            [INFO] [Playlist]: Caricamento dei file della cronologia: [/opt/retropie/configs/apple2gsr1/content_video_history.lpl].
                            [INFO] [Playlist]: Caricamento dei file della cronologia: [/opt/retropie/configs/apple2gsr1/content_image_history.lpl].
                            [INFO] [Playlist]: Caricamento file preferiti: [/opt/retropie/configs/apple2gsr1/content_favorites.lpl].
                            [libretro INFO] Starting game from command line:apple2gsr1 -rp /home/pi/RetroPie/BIOS/mame -cfg_directory /opt/retropie/configs/apple2gsr1 "-autoframeskip" "-ui_active" "-flop3" "/home/pi/RetroPie/roms/apple2gsr1/1stltrwd.zip"
                            [libretro INFO] ARGUV[0]=apple2gsr1
                            [libretro INFO] Game name: apple2gsr1, Game description: Apple IIgs (ROM01)
                            [libretro INFO] SOURCE FILE: ../../../../../src/mame/drivers/apple2gs.cpp
                            [libretro INFO] PARENT: apple2gs
                            [libretro INFO] NAME: apple2gsr1
                            [libretro INFO] DESCRIPTION: Apple IIgs (ROM01)
                            [libretro INFO] YEAR: 1987
                            341-0232a.bin NOT FOUND (tried in apple2gsr1 apple2gs)
                            341-0124a.bin NOT FOUND (tried in apple2gsr1 apple2gs)
                            [libretro INFO] AV_INFO: width=704 height=231
                            [libretro INFO] AV_INFO: max_width=704 max_height=231
                            [INFO] [Environ]: SET_SYSTEM_AV_INFO: 704x231, aspect: 1.333, fps: 60.000, sample rate: 48000.00 Hz.
                            [INFO] [Video]: Does not have enough samples for monitor refresh rate estimation. Requires to run for at least 4096 frames.
                            [INFO] [EGL]: Current context: 0x267fe78.
                            [INFO] [udev]: Added Device Keyboard#1 CASUE CASUE USB Keyboard (/dev/input/event1) .
                            [INFO] [udev]: Added Device mouse#2 Logitech Lenovo USB Optical Mouse (/dev/input/event0) .
                            [INFO] [udev]: Added Device mouse#3 Sony Interactive Entertainment Wireless Controller Touchpad (/dev/input/event4) .
                            [INFO] [Input]: Game Focus => OFF
                            [libretro INFO] ChangeAV: w:704 h:231 ra:1.333333.
                            /home/pi/RetroPie-Setup/scriptmodules/run_mess.sh: riga 89:  3256 Ucciso                  "$@"
                            • jamrom2J
                              jamrom2 @isidoro80
                              Problem is here...
                              If you wouldn't mind, it's a lot easier to post all of this and any other logs to pastebin.com
                              So big question to you is do you have the most recent/good BIOS files in your mame directory in the BIOS directory?
                              you are missing: a2diskiing.7z(zip) and d2fdc.7z(zip) BIOS files.
                              use mame .231 and make sure you place them in ~/BIOS/mame
                              Google is your friend if you need help looking for the MESS bios files and they are listed along with the mame.231 roms. They are all lumped into the massive list, so you have to look through them all to find them. Sorry, but we're not allowed to say where you can get roms/bios files.
                              Once you have them downloaded and in the right place, try again.
                              I 2 Replies Last reply Reply Quote 1
                              • jamrom2J
                                jamrom2 @isidoro80
                                This is just a typo. Just about everything in Retropie supports zip, and 7z file structure. The emulator decompresses the file first, puts it in a temp directory, then runs it. All my Apple II games are zipped.
                                • I
                                  isidoro80 @jamrom2
                                  @jamrom2 ok i have only bios apple2gsr1
                                  do you recommend me to download all bios? they are really many
                                  • jamrom2J
                                    jamrom2 @isidoro80
                                    @isidoro80 no. find a good archive that has mame.231 files. Scroll through them and pick out the files you need. The whole download is over 65G...no need for that unless you're going full Arcade machine MAME or all out lr-MAME on your Retropie.
                                    That's all I can say about finding the BIOS files... honestly, I'm borderline getting in trouble here and I don't want that.
                                    • FollyF
                                      Folly @jamrom2
                                      @dmmarti
                                      Can you fix the typo in your spreadsheet ?
                                      • I
                                        isidoro80 @jamrom2
                                        @jamrom2 ok all right
                                        • I
                                          isidoro80 @jamrom2
                                          @jamrom2 for first game apple2ee now all right. For second game apple2gsr1 no work
                                          What are the bios that contain the files 341-0232a.bin and 341-0124a.bin?
                                          • jamrom2J
                                            jamrom2 @isidoro80
                                            @isidoro80 did you add these BIOS files?
                                            a2diskiing.7z(zip)
                                            d2fdc.7z(zip)
                                            If not, you need to. Might have to try a few variations of them. But .231 should work. If not, go with a lower MESS/MAME version.
