    2.2k Posts 36 Posters 7.1m Views
    • F
      Folly @DTEAM
      @dteam
      Ok, beats me, I have no clue why it isn't working.
      Was your retroach.cfg accidentally saved when you where in the retroarch UI ?
      Or did you perhaps create a game options file accidentally ?
      ( edit : I created a game option file, it's a core option file in /home/pi/.config/retroarch/config/MAME/.opt . It seems not the problem )*
      mame_cheats_enable = "disabled"
      This should be on enabled if you installed one of the install-system-cmd module scripts.
      My On-Screen Overlay setting looks like this.
      How is yours when you run a game ?
      If you do :
      ls -l /home/pi/RetroPie/overlays/konamih
      Are your permissions like this ? :
      -rw-r--r-- 1 pi pi
      • F
        Folly @DTEAM
        @dteam
        Maybe we have to leave it for now.
        Perhaps we will find the solution by accident.
        • F
          Folly
          If we want, it is possible to test the artwork download with this code again :
          https://retropie.org.uk/forum/topic/29682/development-of-module-script-generator-for-lr-mess-and-mame-standalone/37
          Matt has changed his program with my suggestions, accordingly :
          https://github.com/matthuisman/gdrivedl/issues/12
          • DTEAMD
            DTEAM @Folly
            Are you talking about the first version :
            #gets the artwork, about 42 files and puts in in the correct path (perhaps a bit more)
            #not ok, it has to get 162 files
            wget -nv -O /tmp/gdrivedl.py https://raw.githubusercontent.com/matthuisman/gdrivedl/master/gdrivedl.py
            python /tmp/gdrivedl.py https://drive.google.com/drive/folders/1sm6gdOcaaQaNUtQ9tZ5Q5WQ6m1OD2QY3 -P $HOME/RetroPie/roms/mame/artwork
            rm /tmp/gdrivedl.py
            F 2 Replies Last reply Reply Quote 0
            • F
              Folly @DTEAM
              @dteam
              Indeed, I will have a look at it now.
              Running it now, looks good !
              Successful !
              All 158 files in 28 minutes.
              Now we have 2 possibility's for downloading.
              • F
                Folly @DTEAM
                @dteam
                I added the download lines in the get-cheats-artwork-overlays.sh script.
                What it does :
                • download cheats for MAME standalone/lr-mess
                • download artwork for MAME standalone (@DTEAM handhelds)
                • create custom configs for retroarch overlays and extract backgrounds for running with lr-mess (@DTEAM handhelds)
                You can run it directly without even downloading it as a file, with this command :
                curl https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/main/00-scripts-00/get-cheats-artwork-overlays.sh | bash
                I used the gdrivedl.py for the artwork in above script to make it look really simple and it outputs just one line per file.
                My own google download code with curl is a bit more sophisticated, I have another idea with this.
                • DTEAMD
                  DTEAM @Folly
                  What it does :
                  It works !!
                  • F
                    Folly @DTEAM
                    @dteam
                    Damn, that's nice.
                    Tonight I had the idea to only let the the retroarch-overlays create when there is a Background.png available.
                    Then we don't get configs we can't use.
                    This way I can keep all game names in the array's
                    And then I don't have to remove the ones that don't use backgrounds.
                    Btw. we can also use it now for checking on which games we have to work on.
                    How does that sound ?
                    Edit :
                    I just added an if function in my script, and it's working.
                    (I do not have the possibility right now to add it on github, I will do that later)
                    • DTEAMD
                      DTEAM @Folly
                      @folly
                      For overlays, it's frustrating on my end for Lr-mess-cmd. It always points to / opt / retropie / configs / all / retroarch / overlay and not to your directories. I have to do it manually. I am looking to see if I missed something during the installation.
                      I'll re-install the all thing properly.
                      • F
                        Folly @DTEAM
                        @dteam
                        Indeed, I that is really frustrating.
                        Really, I have no idea what is causing this.
                        Have a look at /home/pi/.config/retroarch/retroarch.cfg
                        I remember I had some trouble adding options in the retroarch.cfg in /opt/retropie/configs/all.
                        So I did it in /home/pi/.config/retroarch/retroarch.cfg .
                        Perhaps you have options in there that's causing it.
                        You could rename it, to see what happens.
                        You can alway's rename it back.
                        I could also change the script, so all background files come in that directory.
                        Would that be a solution ?
                        • DTEAMD
                          DTEAM @Folly
                          @folly
                          I could change the script, so all background files come in that directory.
                          It could be good, because like that, you will use the default Retroarch overlay folder for Retropie.
                          I'm gonna try that
                          • F
                            Folly @DTEAM
                            @folly
                            Ok, I will make a commit when I can.
                            Then I will remove the subdirectory's also.
                            All overlays are saved in /opt/retropie/configs/all/retroarch/overlay
                            Basically it will look like the artwork directory but then containing .cfg and .png.
                            I was able to do a commit on github.
                            I did the change without testing, but should work. (did test : OK)
                            If you comment part 2 and 3 in the script it will not download all again.
                            I think you know how to do that.
                            You have to manually remove /home/pi/RetroPie/overlays.
                            • F
                              Folly @DTEAM
                              @dteam
                              I have rewritten the readme on the github page :
                              https://github.com/FollyMaddy/RetroPie-Share/blob/main/00-scripts-00/readme.md
                              I also reorganized the whole repository to get a better oversight.
                              Improved ?
                              • DTEAMD
                                DTEAM @Folly
                                I reinstalled everything and now all overlays working fine with retroarch. Great job.
                                Improved ?
                                Good "readme" on github. Everythings are easy to understand. It's fu%?$ng nice!
                                • F
                                  Folly @DTEAM
                                  @dteam
                                  That is really great to hear.
                                  We have done an incredible job here !!!
                                  I still have some ideas of implementing downloads into the module-scripts.
                                  So if we want, we can try that part in the future. :-)
                                  • DTEAMD
                                    DTEAM @Folly
                                    @folly
                                    Just a reminder
                                    for :
                                    bash $version ablmini # creates cmd script for all_in1 # bootable
                                    bash $version alnattck # creates cmd script for classich # bootable
                                    bash $version gnw_ball # creates cmd script for gameandwatch # bootable
                                    bash $version jak_batm # creates cmd script for jakks # bootable
                                    bash $version kgradius # creates cmd script for konamih # bootable
                                    bash $version taddams # creates cmd script for tigerh # bootable
                                    bash $version rzbatfor # creates cmd script for tigerrz # bootable
                                    and more ...
                                    you can get gamelist.xml files here
                                    and images, marquees and videos for those gamelist.xml files , here
                                    • F
                                      Folly @DTEAM
                                      @dteam
                                      If I have some time, I can try to add it in the get...script.
                                      • F
                                        Folly @DTEAM
                                        @dteam
                                        I had a quick look at the gamelist files.
                                        It's quite simple now to download them all in the correct place with these commands ( this can be added to the get script ) :
                                        python /tmp/gdrivedl.py https://drive.google.com/drive/folders/1f_jXMG0XMBdyOOBpz8CHM6AFj9vC1R6m -P /opt/retropie/configs/all/emulationstation/gamelists
                                        rm /tmp/gdrivedl.py
                                        This will not only download the handhelds but also the others.
                                        Is this a problem ?
                                        One problem I have is, I have .zip files.
                                        Gamelist files that only have .7z files in them, will not work for someone who has .zip files.
                                        Could you add them on the googles drive ?
                                        You can add them simply by using these commands once (!) on a gamelist and then putting them on google drive again.
                                        ( make a backup of the file before you use this ! )
                                        Go to the directory of the specific gamelist and do :
                                        (tested and should work)
                                        sed -i 's/..gameList.//g' gamelist.xml
                                        cat gamelist.xml | grep -v ?xml | grep -v gameList | sed 's/\.7z/\.zip/' >> gamelist.xml
                                        echo "</gameList>" >> gamelist.xml
                                        Explanation :
                                        • sed removes the last line because otherwise we have "</gameList>" end halfway after adding the ".zip" files
                                        • cat shows (pipes it now to the next commands) the file in the terminal, except the lines containing ?xml and gameList using grep
                                        • sed looks for ".7z" entry's and replaces them with ".zip
                                        • ">> gamelist.xml" will write and add all lines, that went trough sed and grep, to the same gamelist file
                                        • so all game entry's double, keeping the originals and adding the ones for ".zip"
                                        • echo makes sure the file gets the last line "</gameList>" end again
                                        Make sure you do this only once to the file, otherwise the game entry's will triple etc...
                                        ps.
                                        You can also do this with gamelist that only have ".zip" files, adding ".7z" :
                                        cat gamelist.xml | grep -v ?xml | grep -v gameList | sed 's/\.zip/\.7z/' >> gamelist.xml
                                        • DTEAMD
                                          DTEAM @Folly
                                          @folly
                                          Is this a problem ?
                                          No problem, but most gamelist.xml files are made for mess/mame romset (excepted pockstat and svmu). It doesn't work if people use No Intro or TOSEC romsets.
                                          I'll do the modification for 7z/zip this week.
                                          Regards
                                          • DTEAMD
                                            DTEAM @DTEAM
                                            @dteam
                                            sed fonction only works in Linux. Doesn't work in PowerShell or as a .bat
                                            Show me an example of that and I'll do It manually with the basic search and replace tool.
                                            Starting example :
                                            <path>/home/pi/RetroPie/roms/tigerh/taddams.7z</path>
                                            new edit
                                            I'll do it directly on the Pi
