    2.3k Posts 37 Posters 8.4m Views
    • FollyF
      Folly
      @DTEAM
      I just discovered how to make use of an extra help button.
      I already knew how to add it but I didn't know how to extract data when pressing it.
      I just got it working.
      So now it's possible to remove all the HELP lines.
      We can now add HELP to each line and select it with the HELP-button.
      More text can be added because a full message box is opened.
      I also improved the search in the restricted dl part as it had some issues.
      And I added a runcommand.log extractor in the restricted dl part.
      So if we run a system with mame or lr-mess without BIOS files we can notice in the runcommand.log.
      So this information can be simply extracted.
      Then we can use this to build up a matching list against the rompack.
      So when we run a500 without roms then runcommand will say it misses : a500.7z, a500kbd_us.7z and a2000kbd_us.7z
      If it's found in the rompack than the list will be made for these 3 items to get.
      Nice feature isn't it ?
      It's not yet on github, I will do this when it's more complete with the help.
      • FollyF
        Folly @jamrom2
        @jamrom2
        I found a repository with lua scripts for autobooting.
        I did some successful tests.
        I forked that repository :
        https://github.com/FollyMaddy/RandoMame/tree/main/autoboot_script
        Perhaps we can use this for adding autoboot lines using these lua scripts.
        What's nice about it, it can automatically press "tape play" and do a run after loading.
        I don't know yet how to write these lua scripts.
        So I have to experiment.
        • jamrom2J
          jamrom2 @Folly
          @folly
          Out of my league for sure.. but it looks like a pretty good option if you can get it to work. Remember what we talked about with the DosBox config files.. that would be something similar I imagine where if it sees a specific rom extension, it knows to use a specific load style.
          • FollyF
            Folly @jamrom2
            @DTEAM @jamrom2
            I just did a commit with many improvements :
            • Possible to add HELP to each csv line and select it with the HELP-button.
            • More HELP text can be added because a full message box is opened.
            • Improving the search in the restricted dl part as it had some issues
            • added a runcommand.log extractor in the restricted dl part so missing bios roms can be matched with a rompack dl search
            • the wget downloads now show a progress bar
            • the wget lines are improved with some more options, for example, continue
            I did not yet add all HELP parts yet, but I wanted to share this with you, both, first.
            Now you both can see what is possible.
            You can find it here :
            https://github.com/FollyMaddy/RetroPie-Share/blob/8d1086cd39f963ae5f0afcecc66d2de2fd55f5fe/00-workdir-00/add-mamedev-systems-0237.sh
            • FollyF
              Folly
              @DTEAM @jamrom2
              I had a few issues with the message-box in above version, that I found later on :
              • message-box not centred
              • no RetroPie backtitle
              • scrolling with page-up/page-down did not work
                ( and therefore adding more text wasn't an option )
              The next update will be fixed for this.
              @DTEAM
              Are you able to make some help texts for the handheld/p&p ?
              jamrom2J DTEAMD 2 Replies Last reply Reply Quote 0
              • jamrom2J
                jamrom2 @Folly
                @folly I've been setting up the Coco3 now using that method of placing the rom in another folder and using the links to point at it.
                I found an issue with the auto load command.
                using the game Androne and Arena the links named: androne.bin.zip and arena.bin.zip resepectively. It's adding a ".BIN" into the name and using LOAD for both.
                Androne is a machine language so it needs the M
                It types: LOAD"ANDRONE.BIN", R
                It should be: LOADM "ANDRONE" , then EXEC
                For BASIC programs it does the same, it adds in the ".BIN" into the name, so it fails. The LOAD statement is correct though as it should just be LOAD "ARENA",R
                It's that BASIC and machine language option again...
                • FollyF
                  Folly @jamrom2
                  @jamrom2
                  I did a commit and added loadm:exec lines for coco2/3 .
                  Let me know if it works.
                  If the file doesn't have an extension then don't add it in the link, that should work.
                  Then the link for arena should be called : androne.zip (that works for me using loadm"%basename%":exec)
                  My arena is a .bas and booted with : arena.bas.zip (using run"%basename%")
                  https://github.com/FollyMaddy/RetroPie-Share/blob/f7d6ea1ce3851bdf4f77ec844dea8beac9c1b441/00-workdir-00/add-mamedev-systems-0237.sh
                  https://github.com/FollyMaddy/RetroPie-Share/commit/f7d6ea1ce3851bdf4f77ec844dea8beac9c1b441
                  • FollyF
                    Folly
                    @DTEAM
                    Did you had some time to check out the help-button ?
                    I would like to know what you think of it.
                    • DTEAMD
                      DTEAM @Folly
                      @folly
                      No, Sorry for that. I'm pretty busy right now. I'll try to check it next week.
                      • FollyF
                        Folly @DTEAM
                        @dteam
                        No problem !
                        I had that feeling you were very busy because normally you are very quick.
                        Next week, will do. ;-)
                        • jamrom2J
                          jamrom2 @Folly
                          @folly Hi. Just wanted to check in and let you know the new script for Tandy Coco Floppy is working great.
                          Just like you said, name needs to be correct for it to work.
                          It is a lot of work to get the link setup and naming and all that, but once it's running... no issue. It's worth all the trouble to have these games now with a one click option.
                          Do you know if there is anything I need to add to make the Joystick work? So far, no matter what I do in MESS or the LR core, I can't get any directional response. Does it need a statement like the Apple IIe did?
                          thanks!
                          • FollyF
                            Folly @jamrom2
                            @jamrom2
                            Great to hear,
                            I was thinking perhaps we can make a basic structure database for creating all the autoboot links.
                            Something like using the sha1sum from the game-file and what the load command is.
                            If I have some time I will see if I can automate the idea ( I am not promising anything though ;-) ).
                            If that's an option we can share the data to automate it.
                            For the apple2ee I have added a line for "compact flash harddrive" support for the "TotalReplay" harddrive image.
                            You will see it in the next update when I update it.
                            TotalReplay will be in the restricted section also.
                            From the apple2ee "compact flash" add, I learned that mame can also-listmedia from added slotdevices.
                            So that would mean that, to some degree, it would be possible to automate that in the generating script part.
                            (which it doesn't do, right now)
                            Perhaps something for the future !
                            For the joystick part I will have a look.
                            Btw.
                            What is your experience with the added help-button ?
                            Is it an option that would help in the future ?
                            (you have to know, not all the lines have help yet, so not all lines will give you something)
                            • jamrom2J
                              jamrom2 @Folly
                              @folly I'm not sure about the Help key. I don't know that it will get good use... BUT
                              I think we're going to have to write very clear instructions on how this is all done at some point. Once others see there is a real "easy" way to run all this, they're going to want to know how and how to make it work on their own sets as well.
                              How about the DOS OS/9 issue?
                              When I run let say flight simulator II it needs OS/9.. however the auto command says "DOSN". Needs to say DOS and it will work.
                              • FollyF
                                Folly @jamrom2
                                @jamrom2 @DTEAM
                                Again, I did a huge update.
                                You can read all improvements in the commit-link.
                                I have finally got color artifacting working using balldozer.
                                We have to use an NTSC tano dragon 64 for that.
                                I found the driver name searching for (dragon ntsc) in the source code of mame like this :
                                https://github.com/mamedev/mame/search?q=dragon+ntsc
                                You will see the tano dragon 64 in dragon.cpp
                                For using dragon32 floppy files I had to use a dragon floppy controller (dragon_fdc) as extra slot device.
                                So the dragon32 floppies will only work if tanodr64 is installed from the systems with extras or the autoboot lines section otherwise it will boot with a wrong extended dos version.
                                I think many issues are resolved now.
                                Get the latest module-script here (with added autoboot for samcoupe) :
                                https://github.com/FollyMaddy/RetroPie-Share/blob/1429cc002c398df78464f86f76d73ecb3ea02b48/00-workdir-00/add-mamedev-systems-0237.sh
                                Here is more about samcoupe in this post :
                                https://retropie.org.uk/forum/topic/31702/replacement-emulator-available/4
                                Commit information :
                                https://github.com/FollyMaddy/RetroPie-Share/commit/e9d5b3dd40c9beb3112785ab0b6d48d4ec004f24
                                https://github.com/FollyMaddy/RetroPie-Share/commit/7a1d96fecac92c69b5ee47227afb10c0a1266c0c
                                • FollyF
                                  Folly
                                  Balldozer on tanodr64 :
                                  • mituM mitu referenced this topic on
                                  • FollyF
                                    Folly @jamrom2
                                    @jamrom2 said in Development of module-script generator for lr-mess and mame standalone:
                                    I read this from your post again.
                                    Check with the tab key in input(thismachine) on what keys are associated with the direction.
                                    I remember I had some trouble too on some systems, I think it was apple2.
                                    Sometimes the directional keys are associated with numpad keys.
                                    Hope it helps, otherwise we have to look at it once again.
                                    • DTEAMD
                                      DTEAM @Folly
                                      @folly
                                      Hi Folly,
                                      I'm back to help with the project today. I have reinstalled the handheld systems with your new script and it works fine. I am impressed every time I do this. I couldn't find your help menu. Where is it ?
                                      Another question, which machines are running MSX2.
                                      For help buttons, what kind of infos you want. Handheld description. How to use "basename lines" with MAME.ini. Systems who needs auto-frameskip, etc.
                                      • FollyF
                                        Folly @DTEAM
                                        @folly
                                        Hi Folly,
                                        Very pleased about that !!!
                                        There isn't a help menu.
                                        But in many lines I added some sort of help.
                                        You just have to go to a line and press the help-button beneath.
                                        If the help button doesn't work then there is no "help page" yet.
                                        Sony hbf700p for example.
                                        Added it in the systems with extras.
                                        Yes, something like that.
                                        I think that would be a good start ;-)
                                        • DTEAMD
                                          DTEAM @Folly
                                          @folly
                                          Quick question, when we use your script for Handheld. Does it generate a rompath like / home / pi / RetroPie / roms / tigerh in mame.ini or do we have to do it manually to be able to use the basename option. This is for the help menu.
                                          .. configs/mame/mame.ini
                                          • FollyF
                                            Folly @DTEAM
                                            @dteam
                                            Good question, actually I can't remember if the script automatically adds it.
                                            I think it was something that still had to be looked after.
                                            Because for other systems the basename option isn't perfect for many systems.
                                            So I think we still have to do it manually.
                                            When I can I will have a look.
                                            Edit:
                                            I deleted the tiger rompath in my mame.ini.
                                            After installing tiger again it's not added.
                                            So it still has to be added manually.
                                            I think I did some tests to add the rompath into the runcommand line.
                                            But I never added these lines because some systems needed an other solution, like the apfm1000.
                                            It should be somewhat a universal solution but never had clever idea for that.
