    2.3k Posts 37 Posters 8.8m Views
    • DTEAMD
      DTEAM
      @valerino
      Very nice!
      Maybe it could be something like this :
      I forgot + systems from my tutorial 😉
      Or we could do 3 categories, Handheld, keyboardless (consoles) and computer? With a,b,c, d, ... classification?
      • FollyF
        Folly @DTEAM
        I know it can be confusing, but I think it is still :
        standalone mame does both arcade/console and regular
        arcade/console and regular are splitted into lr-mame and lr-mess
        Exactly what It is. MAME standalone is the most « up to date » one.... suppose to be ...
        We should keep both. Separately or not in the official Retropie package menu?.. I don’t know. If you do It separately, the user could install only one of those 2 emulators. It could be interesting.
        I want to keep them both in, I assume they both will be maintained.
        If something isn't maintained anymore in the future, we can just rename or remove easily.
        If I split it up, more scripts can be generated, I think, that is not what we want.
        Also, you have to go through the menu twice to install mame and lr-mess for 1 system, don't know if that is ideal.
        Agree ?
        An other solution can be, for example.
        Select mame and/or lr-mess first and then select the system we want to install.
        Perhaps we can use this idea.
        BTW, Nice drawing 👍
        • FollyF
          Folly @DTEAM
          If we want this, we have to extract more information somewhere.
          At the moment we have only 1 row(array) to use for the menu.
          I suggest we try that first.
          Agree ?
          • FollyF
            Folly
            I have updated the first post.
            Adding also the menu idea and adding some more points :
            👉 open : By @valerino / participants @DTEAM , @folly :
            Create a front-end module-script in RetroPie-setup for our scripts.
            • structure/plan ?
            • dependencies check
            • download the repository in /home/pi/RetroPie-Setup/ext/RetroPie-Share or try to run the scripts online ?
            • add a menu in RetroPie-setup using the dialog api 120
            • try to keep multiple emulator/lr-cores in 1 generated script module 125
            • try to use 1 existing array for the menu 125
            • push the generated scripts in /home/pi/RetroPie-Setup/ext/RetroPie-Share/scriptmodules/ ?
            I have tried to structure the information.
            We should decide/discuss if we want to add/change things.
            • DTEAMD
              DTEAM @Folly
              Agree ?
              Good point. I agree with you
              Or we could do 3 categories, Handheld, keyboardless (consoles) and computer? With >a,b,c, d, ... classification?
              Agree ?
              I also agree
              • FollyF
                Folly @DTEAM
                @dteam
                Thanks for letting me know.
                I put it in our plan structure
                We can always change the plan if something better comes up.
                • DTEAMD
                  DTEAM @Folly
                  @folly
                  Nice what you did with the symbols in your first post . It's easy to follow
                  • FollyF
                    Folly
                    @folly
                    Thanks !
                    I think this will help a lot to see what is done and what we want to do.
                    I copy and paste from :
                    https://fsymbols.com/emoticons/
                    or
                    https://en.wikipedia.org/wiki/List_of_emoticons
                    I am trying also to get different colored text.
                    This is done with placeholder :
                    https://placeholder.com/
                    Test with diff :
                    - highlighted red
                    + highlighted green
                    • DTEAMD
                      DTEAM @Folly
                      structure/plan ?
                      For this point, the user could install lr-mess and MAME like it is right now in Retropie. When the user will come back in the package list for Mame or lr-Mess, it could be the same options, but.
                      • re-install (from binary)
                      • Install from source
                      • Remove
                      • install new systems <------(our new thing)
                      • Package help
                      • Package version information
                      No mather if you select "install new systems" in MAME or Lr-mess, the systems selected by the user (like coleco, Jaguar, etc.) will be intall for both (lr-mess and MAME).
                      It could be managed like what we see on my sketch for the other steps.
                      Are you agree? Other suggestions?
                      • FollyF
                        Folly @DTEAM
                        @dteam
                        I have to read it a few times to get the aha.
                        I will get back to you.
                        I think I understand what you mean.
                        Your idea is to integrate what we want to do into the mame module-script and in the lr-mess module-script.
                        Afterwards when you have installed you get the option to install our generated module-scripts.
                        Did I understand correctly ?
                        • DTEAMD
                          DTEAM @Folly
                          @dteam
                          Yes it is, It will be on both menu and it will do the same thing no matter where you go after (lr-MESS or MAME). So that way, you will continue to generate your command lines for systems like coleco or others for lr-Mess and MAME in one time.
                          • FollyF
                            Folly @DTEAM
                            @dteam
                            Could we do it a bit different ?
                            I would suggest to make it possible to install mame and lr-mess though our menu.
                            But the menu will use the official mame/lr-mess module-scripts.
                            Then we keep it separately, our module-script and the mame/lr-mess module-scripts.
                            What do you think ?
                            • DTEAMD
                              DTEAM @Folly
                              @folly
                              good idea , sounds good!
                              At the end, It must be simple for newbies . I think It should be the target
                              • FollyF
                                Folly @DTEAM
                                @dteam
                                Indeed, we should make/keep it simple.
                                Ok, tomorrow I have to go with the boat to an island.
                                Then I have some time to make a summarize.
                                Then we get back to @valerino if this is doable.
                                • V
                                  valerino
                                  hi guys, sorry but today i've been very busy @ work !
                                  i think @DTEAM 's idea to integrate with existing mame/mess script is the cleaner .... no ?
                                  also in my fork i extended already present scripts with extra features when i needed, i.e. in some i added the option to install from source the most recent version from github instead of the branch officially supported by retropie, things like that.
                                  imho this is the clearer way ....
                                  v.
                                  • FollyF
                                    Folly @valerino
                                    @valerino
                                    Ok, if you think the @DTEAM is the cleaner way, we can do it like that.
                                    I have only one concern.
                                    When a generated module-script is generated, RetroPie-setup will not directly see it.
                                    So normally I have to restart.
                                    Does it have a way of refreshing ?
                                    If there is no such option we could use retropie_packages.sh to install it directly after generation.
                                    • FollyF
                                      Folly
                                      I copied generate-systems-lr-mess_mame-1v8-alpha.sh as generate-systems-lr-mess_mame-2v0-alpha.sh to my repository.
                                      I did this so we can make changes to that script which are possibly necessary to make our idea work.
                                      I already made some changes to the 2v0 script :
                                      • It will install the run_mess.sh script if not detected.
                                      • create extra platforms.cfg so we can run the script online with curl and also have a nice extra platforms.cfg
                                      • removed help / not necessary if used in the menu
                                      • date command removed / turn off generate all message shortened
                                      • generated files come in RetroPie-Setup/ext
                                        • found that if there are already module-scripts, with the same name in the original directory, then these will be used (you get a warning). So old scripts have to be removed if they were already there.
                                      This is how it will look like in the external repositiory directory :
                                      • V
                                        valerino @Folly
                                        @folly i will check asap, surely it's possible to refresh retropie's internal structures. look at what it does in its own startup: https://github.com/RetroPie/RetroPie-Setup/blob/master/retropie_packages.sh#L61
                                        • FollyF
                                          Folly @valerino
                                          @valerino
                                          That would be nice indeed !
                                          • FollyF
                                            Folly @Folly
                                            @DTEAM @valerino
                                            I have made some wonderful improvements !
                                            We can now generate without even having the script on the computer and it will place the generated scripts in the directory for external repository's. 137
                                            It will also install the run_mess.sh script if not detected.
                                            Try this command :
                                            curl "https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/main/00-scripts-00/generate-systems-lr-mess_mame-2v0-alpha.sh" | bash -s kgradius
                                            ps.
                                            We can use this now, but the normal way still works. So we can use it both ways.
                                            Edit :
                                            Updated quite a lot in the first post.
