    retroarch.cfg scripting help
    atari2600retroarch.cfg
    5 Posts 2 Posters 873 Views
    • DandelionD
      Dandelion
      Greetings,
      I have an iCode device which adds 6 buttons so I can better navigate Atari2600 games.
      One issue I had was figuring out how to simulate the Select and Reset switches. By playing around I came up with and added the following to my Atari2600 retroarch.cfg:
      input_player1_start_btn = 2
      input_player1_select_btn = 3
      That seems to work great! Then I thought I needed a button to exit the emulator. After digging around I ended up with a possible alternate method of doing the Select and Reset switches along with exiting the emulator:
      input_start_btn = 2
      input_select_btn = 3
      input_exit_emulator_btn = 5
      It exits perfectly! But the Select/Reset switch part didn't work.
      Is there a list or documentation somewhere that lists what the possible scripts could be?
      I'd also love to not have to use another controller to quit gaming for the day. I haven't explored the hot-keys, but could I somehow map one of the buttons (or better, pressing several buttons) to do a "Shutdown System"?
      Thank you
        mitu Global Moderator @Dandelion
        @dandelion said in retroarch.cfg scripting help:
         input_start_btn = 2
        That's not a valid configuration when entered in retroarch.cfg, it works only when added to a gamepad auto-configuration file. In which file are you adding those lines ?
        If you wish to have a button combo to exit, set one of the buttons as Hotkey and the other one to exit.
        Not sure what you mean here - you can shutdown the system by using the EmulationStation's menu (press Start for the menu).
        DandelionD 1 Reply Last reply Reply Quote 0
        • DandelionD
          Dandelion @mitu
          Thanks for the reply @mitu!
          @mitu said in retroarch.cfg scripting help:
          I added those lines in the retroarch.cfg file found in /opt/retropie/configs/atari2600. As I mentioned, only the last line worked.
          I guess that's what I'm looking for -> is there some master list somewhere of the syntax for the retroarch.cfg file vs. the autoconfig files? Or is that a learn linux kind of task?
          I was just thinking that instead of using the EmulationStation menu by pressing Start, scrolling down to Quit, selecting Quit, and then scrolling down to Shutdown System, et al. that I could hot-key/map some of the buttons to do ALL of that. Not necessary - just the cat's pajamas
            I think it worked just because 5 is already mapped through an auto-configuration file.
            It's not Linux specific, it's just the RetroArch configuration syntax. For auto-config files, you don't need to set the playerX part, e.g. input_exit_emulator_btn is ok, but when configuring the button in retroarch.cfg file you need to specify the player #, e.g. input_player1_exit_emulator_btn.
            In EmulationStation this kind of 'hotkey'/shortcut is not available, at most you can exit emulationstation (no questions asked) with F4, but you'd need a keyboard for that.
            • DandelionD
              Dandelion @mitu
              @mitu Thanks for all of your help mitu! You've been awesome!!
