    PS3 controller doesn't work in PS1 games
    ps3 controller
    29 Posts 4 Posters 4.1k Views
      I think the options you activated produce the log in a different place. Please use the launch menu to activate logging, instead of RetroArch, then post the runcommand.log on pastebin.com.
        alistairgd @mitu
        Hi - I am not clear what you mean by the launch menu.
        To launch a game the process has been to start retropie, select the platform from a carousel, select the game and click "O" onthe controller.
          alistairgd @alistairgd
          @alistairgd
          Ah the launch menu was deactivated in retro-pi settings, I reactivated it and activated verbose logging at the launch of the game.
          Here is the full log
          https://pastebin.com/xUVVCcdt
            mitu Global Moderator @alistairgd
            [INFO] [Menu]: Found menu display driver: "gl".
            Did you switch the display driver from the default ? Try putting it back to rgui, instead of gl.
              alistairgd @mitu
              We are making progress.
              Now that I have Launch Menu working, I had a look in there and found that the PS3 controller wasn't set as the first controller, so I selected it and restarted.
              Now I have access to the in game Quick Menu with PS+Triangle.
              The gamepad will still not start the game from the games main menu - noting happens - it just sits at the main menu no matter which button I press.
              I then went in hunt of the display driver, it is set to gl, but there is no rgui option I can see.
                @alistairgd said in PS3 controller doesn't work in PS1 games:
                RetroPie doesn't have that menu by default - are you using the RetroPie image from retropie.org.uk/download or a 3rd party image ?
                  alistairgd @mitu
                  The video settings I checked were in Retroarch, there were about 6 options but not GUI.
                  It's a 3rd party image.
                    @alistairgd We don't support 3rd party images, as outlined in https://retropie.org.uk/forum/topic/3/read-this-first.
                    You'll have to ask the image author(s) for support or use the image from retropie.org.uk/download.
                      alistairgd @mitu
                      Yeh, there's no chance of that.
                      I made a fresh install of RetroPie on a new card and installed 1 PS game on it. Without going into any drivers or any configs other than to configure the button presses on the PS controller at system startup, the controller worked perfectly in game.
                      This confirms that there is a config somewhere on the other card that is preventing the PS controller from working in PSX games. I just have to find it now.
