    lr-PUAE Pi400 CD Audio jumps/mute in 50Hz
    50hzaudiopuaeskips
    22 Posts 2 Posters 3.1k Views
    • maxbeanzM
      maxbeanz
      Pi Model or other hardware: Pi 400 (Stock Speed)
      Power Supply used: Official
      RetroPie Version Used: 4.7.8 1268c480
      Built From: retropie-buster-4.7.1-rpi4_400.img.gz
      (Raspian updated)
      Emulator: lr-PUAE (commit d4057b3)
      Retroarch 1.8.8 (old ?)
      Hi, when using the Retroarch PUAE core when the TV is set to 50Hz, I get random Audio jumps/mutes when CD audio plays and also when the core changes resolution. (Using CD32 bin-wav and also tried chd). The CD Audio doesn't seem to skip/mute when the TV is set to 60Hz !?
      The default audio driver on Retroarch is 'alsa', if I do a core override and change it to 'sdl2' the skips go away but the audio sounds a bit like it's warbling.
      Can anyone confirm this for me please ?
      @BuZz
      Does the makefile seem OK ?
      https://github.com/libretro/libretro-uae/blob/master/Makefile
      There is no platform define for the Pi 4/400 and is there supposed to be a -fp-armv8 flag in there for Pi 3/4/400 ? Would this be the cause of this issue ?
      • maxbeanzM
        maxbeanz
        I take it nobody uses PUAE ! Here is a (very poor quality!) sample of what it sounds like. Is it another problem with alsa drivers and the Pi400 ?
        • maxbeanzM
          maxbeanz
          @mitu Do you have any ideas on this ? I tried to replicate the problem on Amiberry but I couldn't even get that to run in 50Hz !
            mitu Global Moderator @maxbeanz
            @maxbeanz Sorry, but I have no experience with P-UAE or amiberry. Try getting a verbose log and post it on pastebin.com to take a look.
            maxbeanzM 1 Reply Last reply Reply Quote 0
            • maxbeanzM
              maxbeanz @mitu
              @mitu Does the makefile look correct to you ? There's no Pi 4 defined and is there supposed to be a -fp-armv8 flag that i've seen other cores use ?
              Also, Retroarch is only version 1.8.8. Does the latest version not work on the Pi ?
                @maxbeanz said in lr-PUAE Pi400 CD Audio jumps/mute in 50Hz:
                It's not relevant, RetroPie-Setup sets the proper compilation flags automatically.
                1.9.0 has an issue on the Pi3, but it's fixed afterwards. Not sure if affects the emulation though or if the core needs a newer version.
                • maxbeanzM
                  maxbeanz
                  The runcommand log -
                  Parameters:
                  Executing: SDL_VIDEO_KMSDRM_CRTCID=87 SDL_VIDEO_KMSDRM_MODEID=6 /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-puae/puae_libretro.so --config /opt/retropie/configs/amiga/retroarch.cfg "/home/pi/RetroPie/roms/amigacd32/Pinball Fantasies (21st Century Entertainment).chd" --appendconfig /dev/shm/retroarch.cfg
                  the retroarch log -
                  https://pastebin.com/xAurTpig
                  What does CRTCID=87 mean in that runcommand ? I'm using a TV with HDMI.
                  I assume it could only be the 'alsa' sound drivers ? Is there a way to go back to how it was on the Pi 3 ?
                    the retroarch log -
                    The log shows some errors reading for chd file - maybe they are not properly supported or not correctly created.
                    It's an internal DRM ID, used for setting the resolution.
                    Why is that ? If other (non-50hz) games are working fine, then the sound (and alsa) is fine. Pi3 uses also alsa, I'm not sure what you mean by 'like it was on the Pi3' - did these games work(ed) on a Pi3 with lr-puae ?
                    • maxbeanzM
                      maxbeanz @mitu
                      I asked the dev about those 'PG missing sector: LBA 2208, trklog 2208' and he said it was nothing to worry about. The sound also mutes (for a fraction of a second) whenever the PUAE core changes the resolution on any game (ADF,LHA etc.)
                      It only seems to happen when the TV is at 50Hz (in PUAE). I tried a MegaCD PAL game on lr-genesisgx in 50Hz and it sounds fine. This is why it made me think the makefile was missing something.
                      • maxbeanzM
                        maxbeanz
                        Merged
                        • maxbeanzM
                          maxbeanz
                          I just dug out my old Pi 3 (not plus), installed the latest image.
                          This needs updating in the es_systems.cfg -
                          Add .chd to the supported extensions.
                          I notice that the default Retroarch Audio driver on the Pi 3 is 'Alsathread'.
                          On the Pi 400 it's just 'Alsa'. This makes the CD Audio jump/mute. Why has the Pi400 been set differently ?
                            I don't think it's ALSA - my guess is that the resolution change doesn't actually switch to a 50hz mode or the core tries to change the resolution to something else and the audio/video sync is broken, hence the audio jumps:
                            [INFO] [Video]: Average monitor Hz: 49.992501 Hz. (4.532 % frame time deviation, based on 2048 last samples).
                            Your verbose log is truncated, so I can't say which resolution is set up in RetroArch - can you re-upload the full log ?
                            • maxbeanzM
                              maxbeanz @mitu
                              @mitu How do I do a full log ? I selected '0 Debug' in Retroarch.
                              And the thing is, if I change the audio driver to 'alsathread' (which is how it's set by default on the Pi 3) or 'sdl2' then it doesn't jump/mute randomly but still doesn't sound quite right.
                              Are you thinking this could be related to the audio skewing option ?
                                See https://retropie.org.uk/docs/Runcommand/#launch-with-verbose-logging
                                maxbeanzM 2 Replies Last reply Reply Quote 0
                                • maxbeanzM
                                  maxbeanz @mitu
                                  @mitu Here it is -
                                  https://pastebin.com/WbCPkxdm
                                  • maxbeanzM
                                    maxbeanz @mitu
                                    @mitu No ideas then ?
                                      I haven't got to test the game on a 50hz display, just ran it normally (at @60hz) and the music seems fine to me - the intro plays without any skips or stutters. Did you try doing the same - just run the game without any special resolution set-up ?
                                      • maxbeanzM
                                        maxbeanz @mitu
                                        @mitu Yeah, as I said in my first post, it doesn't happen at 60Hz. (And also doesn't happen if you set the audio driver to anything but 'alsa').
                                          I managed to reproduce the issue on a 50hz resolution and it's strange that it only happens with alsa. Switching to alsathread as audio driver (you can do that from the configuration editor) fixes this.
                                          I don't know well enough how RetroArch configured both drivers and which parameters affect how they're configured, it looks like the threaded ALSA driver has a shorter buffer and may synchronize the audio better (?):
                                          • with alsathread
                                            [INFO] ALSA: Using signed 16-bit format.
                                            [INFO] ALSA: Period size: 480 frames
                                            [INFO] ALSA: Buffer size: 1536 frames
                                          • with alsa
                                            [INFO] [ALSA]: Using signed 16-bit format.
                                            [INFO] [ALSA]: Period size: 768 frames
                                            [INFO] [ALSA]: Buffer size: 3072 frames
                                          • maxbeanzM
                                            maxbeanz @mitu
                                            @mitu Thanks for confirming, now we know that it's a problem with Raspberry Pi. As I said, it's weird how a clean install on a Pi 3 sets it as 'alsathread' but the Pi 4/400 sets it as 'alsa' ('sdl2' also works better than 'alsa'). The CD audio still doesn't sound clean in 'alsathread' (like it does at 60Hz). Have you also noticed that the audio quickly mutes whenever the core changes the resolution ? This seems to only happen on the RPi too (can be quite annoying when watching demos that switch res a lot).
                                            I tried Android at 50Hz and it sounds fine, (Android uses 'opensl').
                                            I take it this is a problem that will never be fixed ? Is it RetroPie or Raspian ?
