    Migrating from pi3 to pi4 mame2003plus not working
    migratingrpi4rpi3a+mame2003plus
    17 Posts 4 Posters 2.7k Views
    • O
      Ogroto
      Hello everyone. I have been migrating from my 4.5.1 build on rpi3A+ to a fresh 4.7.1 rpi4 2gb ram
      So far mostly straightforward, i copied the bios, roms, configs, have reinstalled every extra and optional packages. Everything goes ok except for mame. I had several roms configured to mame 2003 and 2003plus before. Now 2003 isnt available anymore on retropie, and i can only run mame2010 ok, but not any single mame2003plus rom.
      I remember copying almost everything through a usb drive, in the config folder i believe that is "to retropie" but maybe i have messed up copying some files manually through winscp.
      Any help is appreciated and sorry for my bad english. Have a nice day
        dankcushions Global Moderator @Ogroto
        @ogroto verbose log, please: https://retropie.org.uk/forum/topic/3/read-this-first
        lr-mame2003 is certainly available in the 4.7 pi4 image. 2003, 2003plus and 2010 use different romsets so your romset will only be appropriate for one of these. 2003plus's romset does change over time, also, so you may need to update it if that's what you're using.
        • O
          Ogroto @dankcushions
          @dankcushions Thank you! Didn't see the 2003 core. I indeed redownloaded the dkong.zip rom and replaced it but 2003 is not working neither, nor 2003plus. It is the third one i try i belive.
          Verbose log: https://paste.ubuntu.com/p/BPNtbXzdMp/
            mitu Global Moderator @Ogroto
            @ogroto Your issue seems related to the video driver chosen for this particular system.
            [INFO] [Font]: Using font rendering backend: stb-unicode.
            [INFO] [Video]: Graphics driver did not initialize an input driver. Attempting to pick a suitable driver.
            [ERROR] Currently active window is not an X11 window. Cannot use this driver.
            [ERROR] [Video]: Cannot initialize input driver. Exiting ...
            [ERROR] Fatal error received in: "video_driver_init_input()
            Do you have a custom retroarch.cfg for the mame-libretro system ?
            Reset it to RetroPie's defaults by removing/renaming /opt/retropie/configs/mame-libretro/retroarch.cfg and then re-installing lr-mame2003 .
            Try again after re-installation to start a Mame2003 game.
            • O
              Ogroto @mitu
              @mitu Thank you for your answer, as far as i remember i didn't edit that file. I only edited the emulators order in ES which is es_systems.cfg i believe.
              I did what you mentioned above and after deleting and reinstalling, it is still the same.
              New log: https://paste.ubuntu.com/p/JdyV5vPR5g/
              I'm using gpio arcade buttons, and xbox360 wireless. I have downloaded some launching images from the experimental packages, retropie-bgm-player , skyscraper, installed a modified openbor to show on ES and eazytools and well that's almost everything.
              I had to unplug the pi some few times, one being dkong on mame2010 launching but it completely hangs to the point of no f4 or reboot available. This also happened in my rpi3A previous build.
              Maybe this screwed some files? this indeed happened some times to me in the past, but to the point of no booting at all. Thank you for your time.
                Can you post the contents of the main RetroArch configuration file, from /opt/retropie/configs/all/retroarch.cfg ?
                • O
                  Ogroto @mitu
                  @mitu https://paste.ubuntu.com/p/HvjjyWWT3N/
                    Looks ok. Are you sure you removed the retroarch.cfg from the mame-libretro config folder before re-install Mame2003 ? Can you post the content of that .cfg file ?
                    • O
                      Ogroto @mitu
                      @mitu Yes, i removed the cfg file from winscp, removed mame2003 and 2003plus from the retropie-setup, reinstalled them, and rebooted. Maybe i need to reboot before reinstalling them?
                      Here is retroarch.cfg now https://paste.ubuntu.com/p/VNspyHbfTB/
                        BuZz administrators
                        This happens with old core overrides from the previous install. Make sure you delete any you have.
                        O 1 Reply Last reply Reply Quote 1
                          @ogroto said in Migrating from pi3 to pi4 mame2003plus not working:
                          No, no reboot is necessary. The config file look stock, but for some reason it's giving an error. Are you running EmulationStation from the desktop environment by any chance ?
                          • O
                            Ogroto @mitu
                            @mitu uhm i dont think so, i downloaded the latest retropiebuster img from retropie.org.uk and burned to my 32g sd card
                            • O
                              Ogroto @BuZz
                              @buzz Oh that might be my case, i used a lot of core overrides saves for inputs and shaders, could you point me what files or lines should i delete? inputs and shaders? Thank you
                                [INFO] [Overrides] core-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003 (0.78)/MAME 2003 (0.78).cfg.
                                Try renaming this file.
                                • O
                                  Ogroto @mitu
                                  @mitu Yes sir! i renamed this and the MAME 2003-Plus cfg and both are working now. You rock guys! i wish you all the best. Thank you so much.
                                  • O
                                    Ogroto
                                    Good day everyone, sorry for reviving this old post. I have now built a bartop and tried to go fullscreen 16:9 (small lcd screen 19')
                                    Every emulator i configure with retropie setup changes from old 4:3 to 16:9, except FinalBurn Neo
                                    This is my opt/retropie/configs/fba/retroarch.cfg
                                    input_remapping_directory = "/opt/retropie/configs/fba/"
                                    aspect_ratio_index = "1"
                                    video_smooth = "true"
                                    video_shader_enable = "true"
                                    video_shader = "/opt/retropie/emulators/retroarch/shader/zfast_crt_standard.glslp"
                                    They all look the same. But this one emulator does not work and stays 4:3
                                    Any help is much appreciated
                                    Found it, it is the first line in FinalBurn Neo.cfg aspect_ratio_index = "1"
                                      @ogroto You should start a new post for this new issue.
