    Problem adding Favorites
    kioskfavoritestranslation
    6 Posts 2 Posters 926 Views
      Codafire
      After installing the translation to my ES, the adding favorites feature in KIOSK mode stop working. Any ideas?
        mitu Global Moderator @Codafire
        That's by design, Kiosk mode should be 'read-only', not allowing users to change the configuration - that includes adding or removing favorites.
        C 2 Replies Last reply Reply Quote 0
          Codafire @mitu
          @mitu Wow!!! I make an improvement withou knowing i!!! hehehe, if its like you said, all ok, that way its better if you have cousins or childrens than can change your favorites list.
            Codafire @mitu
            @mitu It's any way to add again favorites option in kiosk mode? Its because im alone and nobody its going to change it and i have all the bios, and mother roms requiered for some games hidded, so i prefer to use kiosk mode, and its a pain to exit kiosk for adding favorites, if i update emulationstation, favorites start to work but i lost spanish translation. Thats anyway to code something or edit any line to reactivate favorites in kiosk mode?
              @codafire said in Problem adding Favorites:
              There isn't a configuration switch for this, you'll have to modify the code.
                Codafire @mitu
                @mitu I downloaded the emulationstation for translate and compile it, what line i must change in what file? Thanks.
