    Request for artists working on themes - needs for (lr-mess/MAME) additions
    lr-messmamescriptmoduletheme
    207 Posts 12 Posters 109.0k Views
    • DTEAMD
      DTEAM @jamrom2
      @jamrom2
      Your Coco2 system and Coco 3 System and logo are now on Cygnus Blue flames
      Thanks for your work !
      FollyF 1 Reply Last reply Reply Quote 2
      • FollyF Folly referenced this topic on
      • FollyF
        Folly @DTEAM
        @DTEAM @jamrom2
        A few days ago I went to the game-on exhibition in Groningen where you can actually play with all the stuff :-).
        I made some pictures from most of the things I saw there.
        I also made photo's of the Nintendo VS.
        Perhaps we can use some stuff.
        I place it all here :
        https://drive.google.com/drive/folders/1nlUjOQl4fPoXHg_jiMeBZmuYrwjfByP3
        DTEAMD 1 Reply Last reply Reply Quote 2
        • DTEAMD
          DTEAM @Folly
          @Folly
          Awsome!!!
          • FollyF
            Folly @DTEAM
            @DTEAM
            Yes, It was really cool.
            It's extended until mid June, I might go a second time.
            Are you planning on making a nintendovs section for our theme ?
            • DTEAMD
              DTEAM @Folly
              @Folly
              Yeah, but I'm pretty busy right now. I will try to do it by next week.
              • FollyF
                Folly @DTEAM
                @DTEAM
                Nice, no hurry ;-)
                • DTEAMD
                  DTEAM @Folly
                  @Folly
                  Nintendo VS. System (nintendovs) is now on Cygnus Blue Flames. I think it looks good.
                  I will have to look at my romset for Nintendo VS. I can't run these games.
                  • FollyF
                    Folly @DTEAM
                    @DTEAM
                    Cool, will have a look when I can !
                    Romset should not be that difficult, see in the restricted part of my script.
                    Edit :
                    Just updated the theme.
                    I must say it looks awesome ;-)
                    • DTEAMD
                      DTEAM @Folly
                      @Folly
                      You can update it again. I eliminated the empty space between the tire and the bottom line.
                      • FollyF
                        Folly @DTEAM
                        @DTEAM
                        Added a pull request for MTX512
                        • DTEAMD
                          DTEAM @Folly
                          @Folly
                          Done!
                          • FollyF
                            Folly @DTEAM
                            @DTEAM @eberhab
                            I added a PR for Olivetti M20 :
                            https://github.com/DTEAM-1/cygnus-blue-flames/pull/8
                            • DTEAMD
                              DTEAM @Folly
                              @Folly said in Request for artists working on themes - needs for (lr-mess/MAME) additions:
                              @DTEAM @eberhab
                              Thanks! System added!
                              • DTEAMD
                                DTEAM @DTEAM
                                @Folly
                                Hi Folly,
                                I saw your request on github for CD32/CDTV. CD32 already exist but not CDTV. Do you want a change on CD32 (The mascot sucks )and add CDTV or only CDTV?
                                https://github.com/DTEAM-1/cygnus-blue-flames/tree/master/amigacd32
                                • FollyF
                                  Folly @DTEAM
                                  @DTEAM
                                  I have both systems running now and they work very good with the new amiberry.
                                  The only thing is that the systems have to be added.
                                  And I have to figure out how to save the joystick port setting somehow it's not sticking with the new config methode.
                                  Stupid of me, I didn't see that earlier cd32 at all.
                                  All double work ;-(
                                  Surprisingly, I took quite similar images.
                                  If you like my mascot for cd32 then yes I would like that update.
                                  My logo is quite the same, only the text "CD" is in black.
                                  Pick the logo you want.
                                  It can be the old one if you like that one more.
                                  Mine is an .svg (vector)
                                  I would like the CDTV added.
                                  So basically you could add my PR and then revert the cd32 logo if you want, it's up to you.
                                  • FollyF
                                    Folly @DTEAM
                                    @DTEAM
                                    I searched for cd32 in the repository but couldn't find it.
                                    Now I have found it as "amigacd32".
                                    However I think "cd32" is more appropriate as the "add-mamedev-systems" will install it as cd32.
                                    So In that way we would be compatible for the future when cd32 becomes working in mame.
                                    Looked at the logo again.
                                    The one in "amigacd32" is a .png.
                                    The one with the white text is better. as you can see in my picture.
                                    So I can suggest to make mine white and do a second PR, if you like.
                                    Then we would have the better .svg image.
                                    Let me know what you think.
                                    (Edit : The cd32 logo with white "CD" text is merged into the PR)
                                    • DTEAMD
                                      DTEAM @Folly
                                      @Folly
                                      Thanks. Now done on Github.
                                      Do you have issues with savestates in AmigaCD32
                                      • testudoT
                                        testudo
                                        I have a few Carbon themed systems if they are of any use for the project (some better than others):
                                        • testudoT
                                          testudo
                                          • FollyF
                                            Folly @testudo
                                            @testudo
                                            Thanks for adding.
                                            Not sure but there might be some something useful stuff in there.
