    Request for artists working on themes - needs for (lr-mess/MAME) additions
    lr-messmamescriptmoduletheme
    207 Posts 12 Posters 130.3k Views
    • DTEAMD
      DTEAM @Folly
      @folly
      sure!
      FollyF jamrom2J 2 Replies Last reply Reply Quote 1
      • FollyF
        Folly @DTEAM
        @dteam
        Oh I forgot coco2 and coco3.
        While your busy can you also take a look at them ?
        I think both aren't in the theme also.
        DTEAMD 2 Replies Last reply Reply Quote 0
        • DTEAMD
          DTEAM @Folly
          @folly said in Request for artists working on themes - needs for (lr-mess/MAME) additions:
          In the theme list, we have trs-80. I thought it was a coco2. My mistake, it's different
          • FollyF
            Folly @DTEAM
            @dteam
            Indeed it's also tandy but quite different.
            Don't know exactly either what the difference is though, I have to investigate too.
            On some webpages of color computer they refer to trs-80 but the software of the color-computer doesn't work on the trs-80.
            Edit :
            Here is everything explained :
            https://en.wikipedia.org/wiki/TRS-80_Color_Computer
            • DTEAMD
              DTEAM @Folly
              Coco 2 , coco 3 and Dragon 64 are now on GitHub : cygnus-blue-flames
              • FollyF
                Folly @DTEAM
                @dteam
                Thanks for adding these 👍
                Looks very nice, especially the coco2 !
                Btw.
                There are a lot more that should be added looking at the directories.
                But I don's want to overflow you with work ;-).
                Perhaps I can do one or two.
                I Saw that the theme for fmtmarty is called fmtowns_cd.
                Can you make a duplicate of that and make a directory fmtmarty ?
                Then it is also compatible with the system-driver-name.
                • DTEAMD
                  DTEAM @Folly
                  @folly
                  I also changed Dragon 32 logo
                  • DTEAMD
                    DTEAM @Folly
                    I'm gonna change the name
                    • FollyF
                      Folly @DTEAM
                      @dteam
                      Ok, that's perfect.
                      Don't know why it was called fmtowns_cd.
                      Had it something to do with the Valerino scripts ?
                      • DTEAMD
                        DTEAM @Folly
                        @folly
                        In mame 0.233, in the hash folder FMMarty = fmtowns_cd.xml. That's why I have use this name. It fit with the Basename.
                        I made the change.
                        • FollyF
                          Folly @DTEAM
                          @dteam
                          Aha, I get it.
                          • jamrom2J
                            jamrom2 @DTEAM
                            @dteam Do you have a Dragon 64 logo? I just finished a Dragon by Tano logo...
                            I don't know if using the Dragon 64 is the way to go. Looks like many of the games out there are NTSC, which is the Tano version.
                            FollyF DTEAMD 2 Replies Last reply Reply Quote 0
                            • FollyF
                              Folly @jamrom2
                              @jamrom2
                              That's a nice logo, you made.
                              But is there a possibility to make it more universal for more dragon64's ?
                              I think you should also include the 64 part.
                              The trouble is more system drivers will use the RetroPie name dragon64 not only the Tano.
                              Do you agree ?
                              • DTEAMD
                                DTEAM @jamrom2
                                @jamrom2 said in Request for artists working on themes - needs for (lr-mess/MAME) additions:
                                @jamrom2 Unfortunately, the outline of the Dragon 64 logo is not perfect on a dark background. Are you able to improve it?
                                The real one is like this:
                                Note: finally, I used the last one for the theme
                                jamrom2J 2 Replies Last reply Reply Quote 0
                                • jamrom2J
                                  jamrom2 @DTEAM
                                  @dteam sure. I'll look at it. What font did you use? Or is it pulled from a graphic?
                                  • jamrom2J
                                    jamrom2 @Folly
                                    @folly yes. Looks like we can have both! Lol.
                                    • DTEAMD
                                      DTEAM @jamrom2
                                      For dragon , it's from an image. You can use WhatTheFont! webside to found a font on a picture
                                      Seems to be Helvetica-Black or similar (maybe not for "R")
                                      • FollyF
                                        Folly @DTEAM
                                        @dteam
                                        I am trying to do the fmtowns theme.
                                        But indeed the outlines are always an issue.
                                        Hoping to find a fast way of cutting out the desired things so you won't see a white rough edge.
                                        I am now trying the scissors option in gimp to cut out the computer with a smooth edge.
                                        • DTEAMD
                                          DTEAM @Folly
                                          This one has no white edge
                                          • FollyF
                                            Folly @DTEAM
                                            @dteam
                                            fmtowns is ready for a PR. (when I can)
                                            Do you like it too ?
                                            Btw, I used a vector .svg .
