    Using external repositories for scriptmodules and platforms.cfg
    setupplatforms.cfgemulators
    4 Posts 2 Posters 743 Views
      George
      Hello,
      I saw that there is a new feature in RetroPie where you can place scripts into an ~/RetroPie-Setup/ext/[reponame]/scriptmodules/ folder. This is a great way to add script modules to RetroPie without messing up the rest of your RetroPie-Setup directory and sometimes preventing you from doing updates.
      I noticed though that if I am adding a new emulator, I will still need to edit the file ~/RetroPie-Setup/platforms.cfg so that emulation station will recognize the file types that are associated with the new emulator. It would be great if one could create a ~/RetroPie-Setup/ext/[reponame]/platforms.cfg, which would be read by the RetroPie-Setup during installation.
      I noticed in helpers.sh there is getPlatformConfig(), but that is only looking in the main configuration directory and the top level script directory.
      Would love to hear some thoughts about this.
      - George
      BuZzB 2 Replies Last reply Reply Quote 0
        BuZz administrators @George
        @george I think it's a good point and I overlooked it. I'll see what I can do.
          @george although it should be possible for 3rd party modules to add extensions via addSystem (3rd parameter). I'll have a think though - maybe can incorporate multiple platform.cfg files also.
            George
            Thanks @BuZz! I had forgotten about the addSystem option. I'll have to test that out. Thanks for considering platforms.cfg too.
            - George
