    Help with Bootloader Error Message
    boot text
    2 Posts 1 Posters 436 Views
    • L
      lolkthxbai
      My RetroPie boots up and shows a raspberry pi logo on the top left and a QR code on the top right with a bunch of text. Next it goes to black screen, then my splash screen, then some login text and finally EmulationStation. How can I get rid of that stuff? It wasn't always there but I thought I'd look into how to get rid of it now that I have some time.
      I followed the instructions in the DOCS as far as adding parameters to the cmdline.txt and config.text files in the boot partition without any luck. Here is my set up currently:
      Pi 4B (4GB)
      Linux 5.4.83-v7l+ armv7l GNU/Linux
      64GB microSD
      cmdline.txt
      console=serial0,115200 console=tty3 root=PARTUUID=45bbd4a1-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait plymouth.enable=0 quiet loglevel=3 logo.nologo consoleblank=0 vt.global_cursor_default=0
      config.txt
      disable_splash=1
      shell
      $ touch ~./hushlogin
      EDIT:
      The managed to take a photo of the first screen as it's booting up and I noticed on the bottom it says this:
      recovery4.elf not found (6)
      recovery.elf not found (6)
      From what I found here it looks like the screen is the boot loader and it's showing up because it can't find those files.
      • L
        lolkthxbai
        Okay, so after some more searching I found out that the screen I'm seeing is the Raspberry Pi bootloader. I can disable it's appearance by editing it's configuration but I'm still concerned about the error message.
        Should I worry it can't find "recovery.elf" and "recovery4.elf"?
        By the way, I can still boot into RetroPie just fine play games.
