    pi zero USB hub not working
    6 Posts 2 Posters 3.7k Views
    • N
      naddel81
      Hi @ all,
      I tried different USB hubs to get more controllers working on my retropie, but unfortunately only the recently configured controller works.
      What am I doing wrong? I tried different USB hubs, but it does not seem to work.
      best wishes.
      N S 2 Replies Last reply Reply Quote 0
      • N
        naddel81 @naddel81
        got the exact same hub as mentioned here:
        http://www.instructables.com/id/DIY-micro-USB-Hub-for-Raspberry-Pi-Zero/step7/Putting-it-back-together/
          skrapps914 @naddel81
          @naddel81 do yourself a favor, and get this. i have one, its amazing. works wonderful [undefined]http://www.ebay.com/itm/HubPiWi-1-3-Raspberry-Pi-Zero-Hub-with-Wifi-No-cable-connector-/191929470035?hash=item2cafe34c53:g:KiUAAOSwIgNXk2DJ(undefined)
          if you have pi zero 1.2, get the version for that one
          • N
            naddel81
            thanks! how do I find out which version of the pi zero I have?
            unfortunately that piece is more expensive than the pi zero itself. :(
              @naddel81 look at your pi it should have what version it is In White lettering.
              I think the part is worth it, considering its a hub and wifi built in
              • N
                naddel81
                ok. there is no cheaper way to get a few more USB devices onto the zero? I do not know why the first controller connected to the hub works, but the others don't. have I misconfigured retropie?!
