    can i stop my battery bank from going to sleep?
    batteryshut offturn onpi4b
    2 Posts 1 Posters 486 Views
      krullbeast
      Pi Model or other hardware: 4b
      Power Supply used: https://www.adafruit.com/product/1566
      RetroPie Version Used : retropie-buster-4.7.1-rpi4_400.img
      USB Devices connected: Uctronics 5 inch led screen
      Controller used: Magicsee R1
      Is there a way to code in a command that will prevent my battery bank from shutting off? I'm trying to enclose it in a "case" and it shuts off after a while and my power on/off switch won't turn it back on.
      Thank you for any advice!
      Lee
        krullbeast
        never mind because i put the on/off switch in the middle. ugh. it says on the website that this battery bank stays on, but it goes to sleep after inactivity. does anyone have any reccomendations on a dual output usb battery bank that charges via a micro usb port and stays on? and is relatively small?
